Old 10-30-2008, 02:15 PM   #37
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
this is wicked... so was that the right part #
Old 12-09-2008, 04:13 PM   #38
IsLNdbOi
IsLNdbOi's Avatar
Here's an alternative way of doing this:
http://www.soffseal.com/SearchByPart.asp
Part #: E006A
I ordered 4ft. of the stuff, but ended up having to shorten it.
This weatherstrip comes pre-attached with 3M weather-proof double sided tape:
Old 12-09-2008, 04:58 PM   #39
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Part #: E006A
Nice got a pick closed?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 12-09-2008, 05:10 PM   #40
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
nice.....
may i ask what is the length you measured....
Old 12-09-2008, 05:18 PM   #41
IsLNdbOi
IsLNdbOi's Avatar
Can't really see it from the outside / when the hood is closed since I have the hood deflector on there now. These are the best pics. I could take of it while the hood is closed:
It makes a nice, tight seal for the front of the hood. Before, I could just lift the hood and drop it to close it. Now, I have to actually push the hood closed.
I purchased 4ft. of this weatherstrip. Didn't measure the final length after cutting because most of it was already stuck on and I didn't want to remove it to straighten it out and take a measurement.
Old 12-09-2008, 05:27 PM   #42
jinxor
jinxor's Avatar
ok... thanks
Old 12-10-2008, 05:07 PM   #43
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Hmmmm? How about sticking it to the Hood? I think most cars have it on the Hood.
R-CaT
Project Yar 2ZR
Old 12-10-2008, 05:12 PM   #44
YarisSedan
Drives: 08 Yaris Sedan
I ordred the same thing from softseal. Only 6 bucks shipped. Cant beat that. cant wait to install. Maybe will cut down on wind drag and improve my gas milage by .5 percent.
Old 12-10-2008, 05:24 PM   #45
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
It's $3.70 / FT
How much did you buy? tell me if I'm wrong.
CLA 250, 4MATIC
Old 12-10-2008, 10:44 PM   #46
sticking it on the hood is probably safer for the paint. Plastic don't rust, whereas the hood would rust if the paint is gone...
Old 12-11-2008, 01:37 AM   #47
IsLNdbOi
IsLNdbOi's Avatar
I don't understand why it would be better to stick the weatherstrip in the underside of the hood...
Old 12-11-2008, 07:08 AM   #48
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Most cars which have this seal from factory have it clipped into the underside of the hood. Also, I don't think the factory paint would rub off that easily. If it does then you've got serious issues, and should take the car back to the dealer.
Old 12-11-2008, 07:41 AM   #49
bobselectric
Kickin' Yaris
bobselectric's Avatar
Drives: 07 Yaris liftback
UH-OH--- sounds like a VPCORP answer
Old 12-11-2008, 08:01 AM   #50
spookz
JDM yO!
LOL, what's that mean?
Old 12-11-2008, 09:24 AM   #51
Well, try it, you will see. My echo had the rubber underside of the hood, and when closed, it sits on the METAL raidator mount... let's say it was pretty nasty afterwards.
Also, my yaris has 2 small rubber strips on each side of the hood just above the headlights. With time, it did get the bumper pretty scratched.
i have no idea what that means lol.
Old 12-11-2008, 10:09 AM   #52
dybbuk
dybbuk's Avatar
Drives: 2008 Yaris HB
Be glad you don't know.
dybbuk is offline   Reply With Quote
Old 12-11-2008, 04:31 PM   #53
spookz
JDM yO!
Hmmm, that's strange. Because our Corolla and Camry here in Australia have this rubber strip on the underside of the bonnet. Though I don't think it's for sealing the hood, but it seems to just sit between the car chassis frame and the bonnet, to give a bit of cushioning?
Old 12-12-2008, 12:49 AM   #54
IsLNdbOi
IsLNdbOi's Avatar
Seems like the seal / weatherstrip being on the underside of the hood would eventually lead to the seal rubbing off its color on the part of the fender it smashes onto whenever the hood is closed...
underhood weather stripping drifto General Yaris / Vitz Discussion 3 04-18-2007 09:36 PM
