Old 01-01-2020, 10:42 AM   #523
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I made it to Turbokits.com 2ZR turbo kit product page!
https://turbokits.com/Toyota/Corolla...urbo_Kit/1972/
Old 01-01-2020, 02:30 PM   #524
Where? I see nothing which spotlights you. Was expecting at least your engine bay featured.
Old 01-01-2020, 02:34 PM   #525
06YarisRS
Scroll about 1/2 way down the page. It's just my video linked. I think you may have already seen the vid. Still, I'm happy to have it up there. So cool! Haha.
Old 01-07-2020, 11:19 AM   #526
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
That is cool. Always fun when stuff like that happens.
I feel they owe you a bit of credit, though, as their description of the install doesn't sound exactly like your experience. Sounds like you had to do a little more of that R&D they mentioned
On Instagram
On Wheelwell
Old 01-07-2020, 07:41 PM   #527
myfirstyota
3 Yaris and counting..
I bet you're beaming...I would be lol
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 01-07-2020, 11:02 PM   #528
06YarisRS
Well, thanks ern-diz! For sure there were a lot of modifications, but I'd hate to think what a mess I would have been in building a scratch kit. To tell you the truth, I almost did. Some guy was selling both a turbokits 2zr manifold and downpipe on eBay - the two really essential parts. I could have built the rest of the kit from parts online. But, more time would be needed for fabrication, plus I wouldn't have had all the invaluable tech support.
Old 01-07-2020, 11:06 PM   #529
06YarisRS
Hell ya, dude! They did ask me to send pics and a short writeup, but I never expected to get onto the actual product page. I just figured it would go in the gallery. They did post in on Instagram and their Facebook page, but I think they do that for most builds.
Old 02-15-2020, 09:01 PM   #530
06YarisRS
Car out of its den for a warm-up. This happens about once a week.
https://www.youtube.com/watch?v=VTtp...BZua5M45dxSVm0
Old 02-17-2020, 03:52 PM   #531
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Old 02-17-2020, 06:05 PM   #532
06YarisRS
What do you guys think about running this 5W40 in the ol' turbo Yaris?
I was shopping around for a VW spec oil and stumbled upon this at my local Walmart. I don't think this oil is even available in the USA. And, $19.97 Canadian!!!
Video: https://www.youtube.com/watch?v=NZhEj3FjiaY&t=25s
Here's my current stash. The 5W20 is for my 2016 Kia Rio EX. Also, just placed a Rockauto order for filters for all vehicles - 12 filters in all.
Old 10-16-2020, 09:01 PM   #533
06YarisRS
Annual Maintenance Checkup
After a couple days of hooning around in the Yaris, I decided it was time to lift the car and check all the various systems. I'm getting the car ready for storage. I probably have about 2 - 3 weeks left before the first of the evil road salt is applied. The cooler weather has been awesome for boost, with intake temps in the low 60s F.
I checked the following:
1) turbo manifold to head stud nuts - one missing! I took one off my 1nz engine in my other garage bay. Pic below.
2) turbo to turbo manifold stud nuts - all in place and tight
3) Downpipe to turbo turbine stud nuts - all tight, no leaks at gasket.
4) Transmission cooler circuit - no leaks, no chafing, added one piece of split hose between the trans return line and the oil pan lip. There was no visible wear on the hose. Pic below
5) water injection system - all hoses good, no chafing, no leaks, clamps and fasteners all solid. Removed the nozzle from the charge pipe to check the spray pattern.
6) All added wiring harnesses and relays - no issues
7) Turbo charge piping, 3" intake and cone filter, oil supply and oil drain - no body contact, couplers and T-clamps in excellent shape, no leaks, cracks.
8) bellhousing and flex plate bolts - all good.
9) exhaust system - all good
10) brakes - all good. I replaced both front calipers this summer.
11) Coilover threads cleaned and re-lubed, spring perches tight.
12) Full undercoating and rustproof spray. The car has a nice black coat of rustproofing underneath. It only takes about 2 cans to touch up each fall.
The car has been driven a lot and the only repair required is the above mentioned manifold stud nut. Not too bad for the complexity and number of added systems.
Old 12-10-2020, 01:54 PM   #534
06YarisRS
Man, this 'winter' has been crazy! Still no snow and almost mid-December. Needless-to-say, the Yaris is getting lots of extra driving this year. Still...keeping my eyes on the weather network.
Old 09-02-2022, 07:30 AM   #535
06YarisRS
Well, it's been ages since I did an update. Not sure if anyone will see this, or care, but figured I'd update the thread.
The car has been running great with a less than perfect tune, but I've driven it more this summer and I ever have in the past. Still planning on eventually getting a standalone ECU - maybe next summer.
A couple recent mods:
Upgraded brakes - PowerStop Z23 pads and rotors
Dual Exhaust Tips/Chambered Mufflers
Old 09-02-2022, 09:47 AM   #536
Welcome back!
New exhaust looks rad. Can't wait to see installed pics on the setup. A few dual tip installs done here millennia ago, but I believe this will be the first that is actually two seperate mufflers rather than just a tip branch off of the tailpipe.
How's life in the new place?
Old 09-02-2022, 10:32 AM   #537
06YarisRS
Welcome back!
Hey bro! Haha. New exhaust should be cool, hopefully not too loud. Should have gone for two 3" tips instead of 4", but hey, we'll see. I have an appointment today for the exhaust guy to 'loose fit' the parts and take measurements. He already said the job can be done, but wants to mock it up first. Probably about 2 weeks before he can actually do it though. :(
Loving the new place. Move was the best thing we could have done, though I severely miss my 2 car garage. I have a single car garage now. Had to literally shorten the handles on my floor jacks to get them perpendicular to the car. Bummer. Lol. But, yeah, living in a city again has major benefits. Kids are thrilled.
How are things with you?
Old 09-02-2022, 11:39 AM   #538
Life is too rapidly moving along, but otherwise pretty damn good. Don't know how much longer the old girl is going to be with me. Rust is making its claim.
If it were me, I'd be definitely missing the big garage as well as access to Fundy. Kayaking with whales and porpoises would be a form of Utopia for us. If our stage of life had been slightly different, we quite possibly would have been putting in an offer on your old place.
I'll tell you what, it's really beginning to suck being one of only a handful of truly active OGs on here.
Old 09-02-2022, 01:58 PM   #539
06YarisRS
Yeah , it is a beautiful area, but we needed a change and the city offers so much more for the kids in terms of friendships, activities. Eric got a new bike and has already worn out two rear tires. Our daughter is enjoying a very bountiful social life. Such a vast improvement from the rural 'small town' scene.
Yes, I have been checking in on YW and it does appear to be just hanging on; a shadow of its former glory from not that long ago. Truly sad, and I hope that it doesn't go offline as a vast resource would be lost.
I'm going to try and post more. I don't find FB or Instagram very helpful. Neither have any meat to them from my experience.
Old 09-04-2022, 11:01 PM   #540
06YarisRS
A little Photoshop 'mock up'. The job will be completed on 15 Sept. Can't wait...
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
