Old 06-29-2010, 09:11 AM   #577
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Hi to all, can anyone Thai made Yaris mount on the water pump & alternator pulley without any problem. All Thai Yaris with this mod, PLEASE advise & confirm...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 11-07-2010, 12:34 AM   #578
NonStopTuning
MIKE @ NST
www.NonStopTuning.com
Old 11-11-2010, 12:23 PM   #579
ja-cordero
Drives: Yaris Sedan Base 1.5 A/T
About NST (NonStopTuning) Pulleys, does anybody know if they work in a yaris sedan 1.5 a/t? I also ordered but not intalled OBX headers, K&N Typhon intake, Magnaflow muffler and the sprintbooster (electronic throtle accelerator).
I'll apreciate all your comments.
Thanks
ja-cordero is offline   Reply With Quote
Old 11-11-2010, 12:33 PM   #580
ja-cordero
Does it fit in yaris sedan 2007 1.5 a/t??
Old 11-15-2010, 05:10 AM   #581
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Where can I find one for a 1krfe?
In SA
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 12-11-2010, 12:52 AM   #582
modelista
Drives: 2008 liftback
For those who have the full lite pulley set, would anyone care to give their impressions? I'm interested in these.
modelista is offline   Reply With Quote
Old 12-11-2010, 02:03 AM   #583
yaris2010RS
yaris2010RS's Avatar
^ hey aurora, i have a cottage there (ninth line area)
as for the pulley set its really amazing. there is such a huge difference with them on. only issue is getting them on :p crank pully wasnt too bad to put on but holding it while tightning the blot was a challange. i also have lite water pump pully which took some time too get on but was very happy with the results none the less.
Old 12-11-2010, 08:29 AM   #584
The biggest bang comes from the crank pulley. The others in the set are mostly cosmetic.
Old 12-11-2010, 11:27 PM   #585
modelista
^ why are the others in the set cosmetic? Is there anyone that started with just a crank pulley and added the other two pulleys later? I'm definitely going to get at least the crank pulley, but I'm on the fence on the other two.
Old 12-12-2010, 12:33 AM   #586
yaris2010RS
i put just my crank on first and tested it out and i noticed a massive difference. put the water pump pully on and noticed nothing. the water pump pully i got was also grey so its not cosmetic at all..... i recommend only getting the crank and if i could do it all over again thats all i would get. the stock water pump pully is maybe only 1lbs difference then the lite one but the crank is almost a 20 lbs difference
Old 12-12-2010, 06:39 AM   #587
Klink10
Klink10's Avatar
Yes....however it was when they introduced the crank first. Then the others came out. I believe cheaper prices were in back then also.
Old 12-12-2010, 08:06 AM   #588
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
hey, when you are talking about things that rotate every ounce counts. It might not be a ton, but the lighter those pulleys are, the less effort it takes to spin them, meaning more power for what really counts.
Colin Chapman disciple
Old 01-10-2011, 09:33 AM   #589
sito
Drives: Toyota
MR/MRS NST,
Please reply to me back in email if you see this.
I sent dozens of emails to you, asking when will i get back my replaced water pump pulley. It's been 3 months and i'm still waiting for my PULLEY.
THANKS!
sito is offline   Reply With Quote
Old 01-10-2011, 11:31 AM   #590
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
even though its not really a huge wieght difference.. i compare it to running wide open with the A/C turned on and then doing it again with it turned off.. i got all 3 and i like it alot.. i really wanna do the lightwight flywheel and clutch set when i do the LSD also.. i hear that is a HUGE difference, 3x then the crank pulley
Old 01-11-2011, 06:37 AM   #591
sito
Drives: Toyota
Originally Posted by sito View Post
MR/MRS NST,
THANKS!
Anyone able to contact Mike from NST? I sent emails to NST and they didn't reply me anything till now. Can anyone help? Thanks.
Old 02-06-2011, 02:20 PM   #592
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
Looking at the http://www.nonstoptuning.com/NSTPULL...tToyYaris.html
website and i am not sure which to put into my 1.5L 3 hatchback Yaris.
I believe the 10% under drive pulley would make most sense but I'd like to hear someone's thought about this decision.
what is the WP-Lite & ALT-lite KIT for?
Trubin is offline   Reply With Quote
Old 02-15-2011, 04:39 PM   #593
car_buff
gm3 exw
Drives: 2007 yaris sedan
Water pump and alternator. They are not underdrives, just awesome looking lighter version of own equip. Lighter means faster response from your engine.
car_buff is offline   Reply With Quote
Old 02-15-2011, 07:20 PM   #594
ilikerice
ilikerice's Avatar
water pump and alt pulleys are more cosmetic.. they are lighter, yes. but not enough to make a difference.. i got the 10% crank pulley and the waterpump/alt pulleys as well. i barely can tell the difference from the oem.. but they look cool!
