Old 05-12-2010, 09:25 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Talking
OHH I'm so happy! the rubbing it's gone!
I installed my new O.Z. Ultraleggera 16x7, 37mm offset, with 195/50/16 rubber! they are awesome, and about 7 pounds lighter than the OEM with snow tires I use. I also added a 10mm spacer in the back.
BUT... I was having rubbing issues on the rear axis. And thanks to people here in Yaris Wold, I got many possible solutions:
1. Take out 10mm spacers (for some reason there are stuck) and I really didn't want to do this.
2. Roll the fenders
3. Add a Camber Kit
4. Add a RING-TYPE COIL SPRING STABILIZER
So I started with number (4)- Spring Stabilizers, I installed them last night, put one OZ and went for a ride!
NO RUBBING, ok I went back home and put the other OZ and test them this morning on my way to work.
NO RUBBING!!!
The rear suspension got a little harder (not as soft) but feels really good! Lift UP the rear about 1/2 inch bringing the car to almost level with the front suspension the NF210s really make the car look like if I had something very heavy in my trunk, and now my car handles so much BETTER! like Loren told me about the Spring Stabilizers:
"Just jack up the car and squeeze on in on each rear spring. Will raise the ride height a little, and by removing an active coil from the spring, also raise the spring rate."
I'm still going to do the Camber Kit (there is no rubbing with full tank and my self but I bet once I add weight the tires will hit the fenders again) so this may help, I'm going to load my car and test it before adding camber. Roll the fenders as well! and if everything works well under LOAD I'm going to try to keep the spacer because looks so GOOD.
Thank you YarisWold!!!
Derick.
CLA 250, 4MATIC
Old 05-13-2010, 11:43 PM   #2
StragglerX
StragglerX's Avatar
Drives: Yaris Sedan S
08' Sedan S, 5 spd w/ 205/50/16 Yoko S.Drive on 16" Drag DR9s w/ 40 offst. Clearance on full turns were tight but no rubbing on full loads and over humps. GPS reading same as speedo or no noticeable difference. Stock 15s weighs 31.8 lbs (w/ 38k miles), new wheel/tire w/o TPMS weighs 41.2 lbs. Rides nice, awesome grip. Did a 40 on a 20 turn like nothin! A 1" drop will complete this project.
StragglerX is offline   Reply With Quote
Old 05-14-2010, 04:49 AM   #3
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
Originally Posted by grampi View Post
Also post what type of rims you have (size, brand, style, etc), and which tires you have (size, brand, etc). This will help all us who are contemplating wheels and tires as to which size and style we might like to go with. Thanx.
got a 17" bersaglio covered with 205/40/zr17 firenza
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 05-14-2010, 04:10 PM   #4
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
Hey StragglerX, love those rims. I've always been a fan of the black rim with the red stripe!
Old 05-15-2010, 04:10 AM   #5
StragglerX
StragglerX's Avatar
thanx landrym28, had a hard time deciding between high gloss finish and flat black. picked the flat coz i thought glossy is a bit too flashy like chromes. flat shows dirt easily though and harder to clean. what do u think of my clearance? should i just leave it alone or drop? what lowering spring should i get if i decide to drop? i'm thinkin a 1" to 1 1/2" drop should even it all around.
Old 05-17-2010, 03:15 AM   #6
jpadua
http://www.viosgen2.com
jpadua's Avatar
Drives: Vios 1.5G
Send a message via Yahoo to jpadua
18x7.5 Sato5 Wheels +40 offset
215/35/18 Firenza ST-08
Tein S.Tech with Spring Cushions on the rear
Just recently removed 5mm spacer on the rears now I have no rubbing what so ever. I do have some occasional rubbing when making turns on high speeds, very minimal though
A there is a site for Vios, Belta and Yaris Sedan owners! DIY Articles Etc.
http://www.viosunderground.com
Wheelsearch Classifieds (Beta, need help guys!)
http://www.wheelsearcher.com
jpadua is offline   Reply With Quote
Old 05-22-2010, 10:39 PM   #7
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
^very nice. goin for the VIP style?
SLIK4 is offline   Reply With Quote
Old 05-23-2010, 05:37 AM   #8
minired5stby
minired5stby's Avatar
Drives: Yaris S liftback
Looking good man any plans for the interior or engine bay?
Old 05-23-2010, 08:38 PM   #9
Palmer812
Drives: 2010 Meteorite Metallic LB
Finally after waiting 6 weeks for wheels. Konig Lightspeed 15x6.5 +38 10.8 lbs. Falken ZE-502 205/50/15 lowered on Tigertecs. no rubbing at all.
[ATTACH]33956[/ATTACH
Palmer812 is offline   Reply With Quote
Old 05-24-2010, 08:23 PM   #10
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Nice wheels! Are those tires rubbing in the front?
marlondog is offline   Reply With Quote
Old 05-24-2010, 09:40 PM   #11
Palmer812
Thanks. No rubbing. The tires are new and only had 10 miles on them when I took the pictures.
Old 06-01-2010, 08:19 PM   #12
mario98c
mario98c's Avatar
Konig Heliums 15x6.5 195/55/15 and 2 inch drop.
Old 06-01-2010, 10:13 PM   #13
3stars_n_a_sun
3stars_n_a_sun's Avatar
Drives: 2008 yaris sedan
@mario98c: what springs are you using? or are you on coilovers?
3stars_n_a_sun is offline   Reply With Quote
Old 06-01-2010, 10:21 PM   #14
mario98c
mario98c's Avatar
The car have Ag kit lowering Springs.
Old 06-01-2010, 10:17 PM   #15
derickveliz2
Very nice! I really like the "Lip" effect.
CLA 250, 4MATIC
Old 06-02-2010, 02:27 AM   #16
PerfectoII
PWN'ING NOOBS SINCE PONG
Very nice!!! Been looking at the very same Drags as my next set...I like the look...although...I'll be going 17"...
PerfectoII is offline   Reply With Quote
Old 06-05-2010, 03:54 AM   #17
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
RAZE R24 17x7 +40 GOLD NEXEN N5000 205/40r17
OTA'sTOY is offline   Reply With Quote
Old 06-08-2010, 01:42 AM   #18
suprajoey
Drives: 08' Yaris
My Little Egg'ie.
Just installed the wing, and the new wheels.
Wheels are XXR 006, 17x7
Falken 912 tires, 205/40/17
suprajoey is offline   Reply With Quote
