#1 |
Did the green ball!!!
Much better than the first one, makes me think about doing a third ball, maybe after a dozen I'll get them pretty good! I'll post pictures later! D. |
OK guys, I'm finally getting a replacement for the Bachuka! it will be an Image Dynamics IDQ12 V3.D4
Now it's time to think about what kind of box! Sealed? Ported? Bandpass Box? even Free Air, this sub is so flexible! Thanks to everybody help me narrow down my needs! many thanks to sqcomp, Palmer and others for your offerings and help, I appreciate it a lot "I'm very thankful" . ![]() LINK D. Last edited by derickveliz2; 10-26-2010 at 03:56 PM. |
#3 | |
Only Happy When it Rains
Colin Chapman disciple |
#4 | |
Secret Agent
Drives: 2008 Yaris Hatch Join Date: Feb 2009
I see them suckers ain't cheap! $280. Wow. Since you are picky, you are probably going to have to try both a "ported" and a "sealed" box... just to see which one YOU like better. I wouldn't even attempt to recommend anything to you. lol I seen your little pods. Really cool looking. They will look nice when you get them all sanded down and painted.
www.sonicelectronix.com for all your mobile audio needs! |
#5 | |
Secret Agent
![]() An IDQ in a bandpass box for an SQ system? Wow... and I got sh1t for recommending an ALPINE Type-R sub.
#6 | |
Alien Mantis... you made my day! I want SqComp to visit New England!!! Yeah!!! I was just checking the specs of the IDQ12 ![]() ![]() ![]() D. |
#7 |
Also for my Amp needs... I'm getting a PowerBass ASA1100.5x (5-Channel Class A/B Amplifier)
75 watts x 4 +250 x 1 LINK ![]() This leaves me with 2 amps to choose from to help either the tweeters or Midbass 100 watts x 2 (old Pioneer amp that I'm using for the Bachuka now and could use it for the Midbass drivers?) or 60 watts x 2 new class A/B Pioneer amp (this could power the tweeters) We'll see how it goes... D. Last edited by derickveliz2; 10-27-2010 at 01:44 AM. |
#8 |
Here is the other ball after applying fiber glass.
Now lets get the foam out and reinforce the MDF ring to the fiber glass sphere. I'm starting to like the funny smell! ![]() ![]() ![]() And todays photo! ![]() D. |
#9 |
Roadrunner Jr.
Apparently you called the shop two minutes before I walked in this morning. Good choice on the sub and amp, you'll like them.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#10 |
Thanks!
I'm very positive! I've been digging around and learning everyday, the sub and the amp will work great with my system, without breaking the bank. D.
. CLA 250, 4MATIC |
#11 |
![]() A little bit of ACETONE to melt the foam, it was actually a sad moment... ![]() After 5 or 10 minutes with the Dremel and a little sanding I did a test fit! Yeah!!! Can I use 5 minutes Epoxy to reinforce the spheres to the MDF ring? would the BONDO work ok over the Epoxy? After some structural reinforcements to the spheres I should start looking for a mechanical system to attach the spheres to the A-Pillars ![]() ![]() D.
#12 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I have a couple of noob question for you guys....it would be really helpful for me....i'm going to start my audio system upgrade soon and i'll do a little bit of deadending in the trunk and on the floor....welll i will put two 12''subwoofer and i want to replace and amplify my two 6.5 and my two 6x9 and add little tweeter at the front in the a-pillar...
well what kind of amp do i need for the low(tweeter), the mid(6.5) and the high (6x9) ? For the sub...Ported or not ? For the deadending...only CLD tiles will make a difference in the trunk and on the floor even if i do not put MLV ? Do i really need a audiocontrol like you are adding ? Do i really need to change the battery ? or the big three will be enough ? thanks to you and i'm sorry to disturb the tread but it's one of the most complete thread i found thanks again!!!
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#13 | |
well what kind of amp do i need for the low(tweeter), the mid(6.5) and the high (6x9) ? That depends on how much you want to spend $$$ For the sub...Ported or not ? Ported = bigger box! For the deadending...only CLD tiles will make a difference in the trunk and on the floor even if i do not put MLV ? CLD tiles + CCFoam + MLV it's a system, you will feel a big difference only if you use all three of them. Do i really need a audiocontrol like you are adding ? What is your goal and budget? Do i really need to change the battery ? or the big three will be enough ? Depending on your equipment, so far mine is fine with the Big 3 only thanks to you and i'm sorry to disturb the tread but it's one of the most complete thread i found Thank you and you are welcome |
#14 |
I have maybe around 1000-1200$ for the audio system....but I already have my heat unit and my big three
My goal is to get a loud sytem with a lot of bass I don't care of space I use in my trunk ...i'm a student so....i dont have a family....so ported or not ? for the best sub sound ! I would like to have a kind of 2500W peak of sub and have better sound by amplifying my tweeter, mid and high so.. Audio control or 2 amps will do the job ? Ported or not ? Deadending question...thanks you so much Battery...i'll change it if i see i have problem with power! I like fast answer like you did Thank You
#15 | |
I have maybe around 1000-1200$ for the audio system....but I already have my heat unit and my big three TELLS US ABOUT YOUR HU My goal is to get a loud sytem with a lot of bass EVEN MY 10" BAZOOKA DELIVERS GREAT BASS, TWO 12'S WILL WORK GREAT TOO, TELL US ABOUT THEM? I would like to have a kind of 2500W peak of sub and have better sound by amplifying my tweeter, mid and high RMS? so.. Audio control or 2 amps will do the job ? WHAT DO YOU MEAN WITH AUDIO CONTROL? Ported or not ? PORTED OR EVEN BETTER BANDPASS IF LOUD IS YOUR GOAL Deadending question...thanks you so much WHAT QUESTION? Battery...i'll change it if i see i have problem with power! IT'S NOT THE BATTERY YOU HAVE TO CHANGE, YOU CAN ADD A 2ND ONE AND UPGRADE ALTERNATOR. |
#16 |
My HU is a kenwood mp-345U ...only one rca output....
I was looking for Alpine Type R for the sub....they look great and i had nice comment on them Audiocontrol i mean...what you have already been talking in your thread....the one you have bought.....do i really need this I'll go for the ported sub boxes deadending i was just saying thank you...i will look at foam cld tiles and MLV i'll you use thos three Battery....i've seen people changing the battery for a more powerful on and adding the big three of course but not changing the alternator and adding a second battery......perhaps...how much for an alternator of 200 amp ? thank you!!
#17 | |
Alpine type R is a good choice. At some point a got an active cross over from AudioControl and I returned, and I'm very happy of doing so. After that I got a Pioneer P-99 with many features to control sound. Ported boxes are loud. If loud bass is what you want for the Trunk I recommend you 2 or 3 layers of Mat instead of CLD+CCF+MLV system. Search the forum for battery/alternator information there is a lot of info here. I hope it helps!
. CLA 250, 4MATIC |
#18 | |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
