Old 10-02-2006, 09:58 AM   #685
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Originally Posted by nsmitchell
Break-in time is definately a factor in MPG. I have 2200 on the ODO and my MPGs seem to be going up by about 1MPG per fillup lately. 31,32,33...
Also try switching to synthetic oil at your first oil change. Folks have been reporting increased MPGs just by doing that. Mobil-1 or Amsoil is your best bet with a good filter.
thankx for the reply. I figure the little guy just needs the engine to be broken in for a little longer. I'll do the switch to synthetic aswell and see what kind of role that plays. Maybe an intake to help the engine breath better, should help with mpg aswell.
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-02-2006, 10:00 AM   #686
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Actually
Amsoil, Redline or Royal purple is you best bet for synthetics
Mobil 1, unfortunately like castrol syntec is a group III mineral oil based synthetic with a speacial blend of synthetic base stocks.
But mobil 1 is still a MUCH, MUCH better oil then the dealer uses or most group I, II or III oils.
Here in Ontario it's just bulk Shell oil
Old 10-02-2006, 10:07 AM   #687
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Originally Posted by 07WYarisRS
Actually
Wow is the dealer oil really that bad. The car is a daily driver, and usually I do all my own oil changes on all my cars, but now I can get free oil changes at toyota when ever I want. I used to work for a toyota dealership, and my mechanic friends there give me free services.
But if factory oil isn't good enough for a daily driven car that is babied then I'll switch to synthetic.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-02-2006, 12:09 PM   #688
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Actually
Agreed.
I'm also in the Mazda RX-8 forum ( www.rx8club.com ) , and there are some over there that are absolute nuts about debating oils, headed-up by a dude going by the name of RotaryGod. He swears by Royal Purple and nobody can dispute the merits of that oil. I loose interest kinda quickly in that topic (and I'm a mechanical engineer). I'm actually not a synthetic oil user, I use Castrol GTX. I might go Royal Purple with this Yaris though.
Long (very long!) story short - regular oils work fine in normal use, but if you want even better performance, go synthetic, and if you want to go synthetic, then buy Royal Purple. That's the way I see it.
Racer X-8 is offline   Reply With Quote
Old 10-02-2006, 12:27 PM   #689
nsmitchell
nsmitchell's Avatar
^ Performance equating to bettter MPG.
I might try Royal Purple to see how it goes. Either that or Grape Kool-Ade! :)
One benefit of using Royal Purple is that if you buy the oil and let someone else (dealer) change your oil for you, you will know they didn't switch oils on you by putting conventional oil in your car and keeping the synthetic for themselves. Check your dipstick for the purple oil.
Old 10-02-2006, 12:45 PM   #690
Racer X-8
Racer X-8's Avatar
Yeah, but check quickly, I understand the purple color goes away in a fairly short amount of time, then it looks like regular dino.
Old 10-02-2006, 01:36 PM   #691
nsmitchell
nsmitchell's Avatar
Just did some research on Royal Purple vs Amsoil. It looks like Amsoil is still superior. This discussion needs to go over to the Synthetic thread.
http://www.yarisworld.com/forums/showthread.php?t=1690
Old 10-02-2006, 01:47 PM   #692
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
This is the best tank I've gotten so far:
435 miles / 700.48km
10.57 gallons (US) / 40.03 liters
That's about: 41.15 MPG or 17.49 Km/L
On this tank, I babied it big time and the results were evident.
Also about 85% highway and 15% city.
No A/C used.
redglare45 is offline   Reply With Quote
Old 10-02-2006, 04:40 PM   #693
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
What's being said about Royal Purple and past quality issues?
tomjasz is offline   Reply With Quote
Old 10-02-2006, 04:53 PM   #694
Racer X-8
Racer X-8's Avatar
Sorry, not sure of your querry. What you quoted is just about the color of the oil and that has no effect on its performance / quality.
but yeah, it's real good stuff.
And also, yeah, this oil stuff needs to go to that linky that nsmitchell has given above a little...
Old 10-02-2006, 07:43 PM   #695
Racer X-8
Racer X-8's Avatar
The telltale tale of one Yaris... bought on 4-18-06 and now at 10,485 miles. I just filled her up tonight...
Old 10-03-2006, 12:11 AM   #696
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
US gallons I assume? Or imperial!
I really drives me nuts about how both systems use "gallons" but they're different measures!
Ugh.. just annoying trying ot figure out which one often ppl are referring too!
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 10-03-2006, 07:37 AM   #697
Racer X-8
Racer X-8's Avatar
I'm in SC - that's South Carolina. I realize my "location" maybe obscures that little tidbit of information to where ppl aren't sure what the SC means - so sorry. US gallons. Now, go get some sleep. :p
Old 10-03-2006, 05:07 PM   #698
blommer
blommer's Avatar
Drives: Yaris MAN RED 3DR LB
woohooo yaris rulez
blommer is offline   Reply With Quote
Old 10-04-2006, 08:46 AM   #699
nsmitchell
nsmitchell's Avatar
31MPG - Drivin' it hard on this tank, but no AC. Sprint starts and high speed driving. I need to mellow out some...
Get YarAss in gear!
RIP - Casey Tatum
Old 10-04-2006, 09:04 AM   #700
Racer X-8
Racer X-8's Avatar
I once tried taking a trip with 4 ppl and a luggage carrier on the roof. The poor thing was really struggling, I had to floor it a lot. The darn luggage carrier really did need a roof rack, so I deemed it unsafe and returned home after about 30 miles of trying. My point being, loaded-down like that, it really is underpowered so badly, the mpg would have probably been like 20-25.
Old 10-04-2006, 10:33 AM   #701
nsmitchell
nsmitchell's Avatar
I was considering taking the Yaris on a camping trip with the wife and 2 kids this weekend. I just don't think we could stuff 4 sleeping bags and our tent in the hatch. I will try though. And a cooler. Maybe one of those folding coolers and I will just buy food after we set up camp. Thinking about Loft Mountain Campground in the Shenandoah National Park, Virginia. I may end up taking the Odyssey though. It gets about 20-25MPG on the HWY...
Get YarAss in gear!
RIP - Casey Tatum
Old 10-04-2006, 10:48 AM   #702
Racer X-8
Racer X-8's Avatar
Darned luggage carriers are almost always designed to be strapped-down to a roof rack. I bungee-corded mine thru the windows, hooked inside to each other. I thought it would work, but the air pushed it back almost to the antena and the front of it made a "wall" that the air blew against. Argh, and the buffeting was getting pretty bad above 60 mph. I was extremely relieved to get it home unscathed, we threw the bags in the trunk of our 32 mpg Infiniti G20T and re-started the trip 1 hour later than expected, all the way to Kissimmee, FL. We would have been in big trouble if we didn't bail.
