Old 10-29-2008, 11:56 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Most important guages for boosted engines?
Once I install the Blitz, what three guages are most important for monitoring the health of the engine?
I already have a ScanGuage so I can monitor water temp.
Old 10-30-2008, 12:19 AM   #2
not critical with supercharging, but I would say a boost gauge and oil pressure, since you already have water temp.
Old 10-30-2008, 12:31 AM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
boost, oil, pyrometer so if you hold it long you dont fry your pistons
i run all three for my turbod tc and water temp, and wideband,
my old supercharged delsol i ran those three and a wideband
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 12:49 AM   #4
oh yeah, add a wideband A/F that one is fun to watch too
Old 10-30-2008, 01:23 AM   #5
LtNoogie
LtNoogie's Avatar
Ok, but other than fun to watch, will the A/F wideband warn me that something is about to blow up? I can see the point of oil pressure and water temp. Never knew the purpose of wideband.
Old 10-30-2008, 06:16 AM   #6
battleversiontc
the pyrometer will tell you if your pistons about to melt. a/f wideband would tell you if its to lean or to rich or right on the money
Old 10-30-2008, 10:14 AM   #7
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
i would say boost/oil pressure/AFR.... any car that you plan on tuning correctly NEEDS a wideband... people think they can use the narrowband signal to tune... thats a bunch of hoohah, but the wideband will cost you a pretty penny over the others
Old 10-30-2008, 11:35 AM   #8
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
who makes a good wideband AFR gauge
Old 10-30-2008, 12:08 PM   #9
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
AEM, Dynojet, Autometer, Innovate, Dynotune. You can get one from $250-$350 it just depends on what features you want.
Old 10-30-2008, 08:42 PM   #10
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
PLX Devices
They make a lot of different products. They are popular in the 300ZX and 350Z arenas. If I were to get a wideband Id get on of theirs, AEM or Innovative.
nemesisz is offline   Reply With Quote
Old 10-30-2008, 12:06 PM   #11
largeorangefont
Break'em off some.
If you have a turbo you will want:
Boost, EGT, oil pressure, water temp
If you are supercharged you will want:
Water temp, oil pressure, EGT, boost if you have extra $.
Wideband is fine for both, but EGT is going to be more important, especially in a turbo car.
If you have a scangauge, I would not waste the cash on a wideband. The scangauge should be able to monitor fuel pressure, which will give you a window into the fueling system. Between fuel pressure and EGT you will be able to tell if you have a fueling problem. EGT is more critical to the health of the engine, especially with a turbo.
If you are doing your own tuning however, then you will definately want a wideband.
Old 10-30-2008, 12:10 PM   #12
largeorangefont
Break'em off some.
Originally Posted by kurokoma-kun View Post
where are the rest of you locating the wideband a/f O2 sensor? header or midpipe? i really hate to drill a new hole on my header if i can locate it on the pipe
It needs to be before any cats, and clocked above 9 and 3 on the pipe to avoid sensor damage.
Old 10-30-2008, 12:25 PM   #13
largeorangefont
Break'em off some.
on that nitto midpipe there's a few inches of pipe right behind the collector b4 the first resonator, that'll be a good spot... now if only i could weld
a muffler shop will be able to handle it.
Old 10-30-2008, 01:30 PM   #14
whooppee777
what should the AFR be on a blitz supercharged yaris?
Old 10-30-2008, 01:20 PM   #15
Nexus1155
Drives: Audi
i use innovate LM-1, but it is handheld and i have an extra one lying around somewhere... but on cars that people dont feel like getting a bung welded in, i use the exhaust clamp which gave me a steady 14.5 AFR reading at idle out of the Envoy i drive... and that was at the end of the tailpipe but the HPtuners scanner software read 13.06 :-/ whacky interfaces
Old 10-30-2008, 05:28 PM   #16
battleversiontc
i use plx
Old 10-30-2008, 07:41 PM   #17
LtNoogie
LtNoogie's Avatar
And what would be considered too hot on an EGT guage? Do they typically have a green and red zone?
What would be the remedy?
Old 10-30-2008, 11:09 PM   #18
largeorangefont
Break'em off some.
I'd say 1500 F is time to start to be concerned. This is probably a bit conservative for the Yaris, and it varies depending on the car, piston type etc.
My WRX could hit 1600 no problem, and my Cobra rarely breaks 1400.
Turbo cars can get you into trouble because you can hit full boost at less than full throttle. An example would be going up a hill. If you go part throttle up a hill in a turbo car the boost will rise and you will see EGTs climb. This is where you can cause engine damage. This is precisely why EGT and boost gauges are needed on a turbo car.
The solution for this is to let off the gas and not make any boost, or floor it to get the car to the open loop fueling map and bring down the EGTs with extra fuel.
Supercharged cars do not have this problem because boost is limited by engine speed.
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Gauges! Gauges! Gauges! at Blow Out Price. MC-BPT Sponsors Classifieds Area 5 06-07-2007 09:55 PM
