Old 11-24-2009, 12:22 PM   #55
v-tech
Drives: 2008 Yaris Sedan, 5 Speed
I read over this post and had the same problem. It was around 56,000 km that it started. If I shifted between 2nd - 3rd and 3rd - 4th then 4th - 5th. I took it into Toyota since the car was under the 60,000 km bumper to bumper warranty and I had only owned it for a little over a year. They went over the car, took them an hour. When they explained it to me I asked to talk to the mechanic. His words were "Lubed the linkage in the engine and around the transmission, but this didn't fix the problem. Took apart the center console inside the car, lubed around the stick and this fixed the squeaking". Toyota tried to charge me for the hours labor because they said "this is regular maintenance that I should be doing on my own" I asked for the service manager who said the same thing, so i told him, if you can find in my manual where it says to pull apart the center console and lube around the stick shift, then I'll pay you. after about 20 min of arguing they gave it to me for free. I really hate the dealerships.
No more squeaking.
v-tech is offline   Reply With Quote
Old 01-13-2010, 03:23 PM   #56
toyota
SRacer
toyota's Avatar
Drives: Toyota Yaris 2007
Send a message via Yahoo to toyota
hey can you use WD-40?
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop."
- Dominic, Fast & Furious
Learn The Truth about Six Pack Fast!
toyota is offline   Reply With Quote
Old 01-14-2010, 01:54 AM   #57
tk-421
tk-421's Avatar
Drives: 5D-07-LB
WD-40 is fine. Just don't expect it to be a permanent solution.
Old 01-14-2010, 02:54 PM   #58
MUSKOKA800
MUSKOKA800's Avatar
Mine just started squeaking recently. I'll hit with with some lube this weekend.
Thanks for the pic!
Old 01-14-2010, 10:23 PM   #59
toyota
SRacer
toyota's Avatar
awesome thanks, i'll give it a try!
Old 01-15-2010, 01:22 AM   #60
advocate
Drives: car
I have complained about this so regularly to my mechanic that he has decided to add it to the list of things he will do on my regular maintenance.
Now no matter what he goes in and puts a bunch of hard core axle grease to keep it from squeaking every time I'm in the shop.
I hate it because it makes the car sound cheap and crappy and that's DEFINITELY not the look i'm going for with my car.
Old 01-16-2010, 08:48 AM   #61
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
don't use WD-40 especially on rubbers. Use Silicone oil instead.
ricepower is offline   Reply With Quote
Old 03-19-2010, 08:26 AM   #62
watersoilair
Drives: 08-2DR-MT-LB-Red
Hello All,
I thought I'd give you a bit of an update. My linkages were squeaking last summer (09). I bought the car in the summer of 08. It was squeaking when shifting from: 1-2, 2-3 and 3-2. I sprayed the linkages with silicone spray, worked it in a bit and everything was great! HOWEVER, the problem reared it's ugly head again as things warmed up here two weeks ago. I sprayed the linkages again...but just a bit...and now the squeaking is back. I will not spray them again and will take the car into the dealership here shortly. (like within the next week or two) I am at 36,000km and my warranty is 60,000km. I will not pay a cent for the service.
I will give you all an update on the situation.
watersoilair is offline   Reply With Quote
Old 03-19-2010, 09:06 AM   #63
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
Talking
..... so true in so many ways.
zachryboles is offline   Reply With Quote
Old 03-19-2010, 01:50 PM   #64
MUSKOKA800
MUSKOKA800's Avatar
Finally sprayed my yesterday. Squeak gone. Shift action much smoother with less effort.
NOTE to Self: blast shift linkage at each oil change.
Old 03-22-2010, 02:22 PM   #65
meh.. sprayed mine and still does it. and i'm way past my warranty :(
Old 04-09-2010, 09:44 PM   #66
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I have a 2007 Yaris S sedan with AT, I have a squeak during shift too. But I cannot find anything under my hood that looks like this, do I have remove the battery or look from under the car?
198K Miles
N9QGS is offline   Reply With Quote
Old 04-09-2010, 10:57 PM   #67
luis30
Drives: Yarisito 07 negro
man thx work very well for me !!
luis30 is offline   Reply With Quote
Old 04-10-2010, 10:54 AM   #68
toast
Drives: 2007 LB
+1 on the don't use wd-40 to solve this or any squeak. wd-40 is a great cleaner and water dislpacer, but has no lube. so go ahead and clean stuff with it, but follow up with a good lube after. especially true on door hinges etc.
toast is offline   Reply With Quote
Old 04-10-2010, 12:09 PM   #69
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
+2 on don't use WD=40. It's not really a lubricant. It will dry and become gummy.
Old 06-17-2010, 03:00 PM   #70
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Originally Posted by AlexNet0 View Post
now that the shift squeak is gone, how do I get rid of the squeak when I press the clutch? lol
I just had this serviced today. The problem was the pivot point on cluch fork needing lubricant.
Apparently all you hafta do is lube the clutch fork pivot point. Et voila.
Hope that helps.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 06-17-2010, 03:04 PM   #71
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Originally Posted by Jem_hadar View Post
When had my car in for its regular 6 mo/8,000 km maintenance appt, i had them fix this issue. Just needed a little lubrication. All is fine now. :)
Well this issue magically re-appeared again on Tues night and has been off and on since then.
I actually asked a Toyota mechanic what the prob was, what was causing my shifter to be squeaking again when shifting into third and usually when shifting out of 2nd and 4th even.
He said that the shifter cables just need some lube, is all. Nothing really serious. When I take my car in for its 80,000 km at end of July, I'll have it taken care of then.
He said its nothing to worry abt, and that leaving it be until then wouldnt damage my car or cause any wear or trear (due to lack of lubrication).
(I just didnt feel like paying another $25 in labour to have it lubed today)
Ill deal with it / ignore it until next servicing in abt a month and a half.
Will update again once all is cleared up.
Old 06-21-2010, 06:23 PM   #72
jvgillow
Drives: 2008 Liftback S
My 5spd 2008 liftback started squeaking a couple weeks ago going into 2nd and 4th, I got some lithium grease & no more squeaking now.
jvgillow is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
