Old 11-18-2008, 05:29 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Doc, thanks for the tips.
How's the car driving? We haven't heard much about it other than you said it goes "wahhh".
Old 11-19-2008, 01:18 PM   #2
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Don't be scared! Just take your time and double-check things. And yeah, a 2nd pair of hands is almost required for most of this install!
Well, the car is driving great. I keep the switch (which I still haven't installed yet) set to "high". That way, the power comes on nice and smooth. For a while it was set to "medium", and you'd get that huge jerk of power when it switched on. Not smooth. I'm thinking I might leave it turned off for the winter... don't really need boosted performance in the snow. Plus, I could run regular gas too.
But yeah, the only big issue that I'm a concerned about right now is that with the cold weather, the car is getting really hard to start. I mean, I used to just twist the key, start would crank maybe twice, and it would go. In the winter, it was sometimes 3-4 times. Now (we're still only in November!) and the car cranks for about 3 seconds before it catches!! I'm wondering if I'm losing fuel pressure somewhere and the fuel rail has to re-pressurize? Or if it's the fact that there's extra stuff on the accessory belt (although, it should be free-spinning when I'm starting).
Anybody else with the Blitz having engine starting problems now that it's getting colder? I'm really concerned that the car is not going to start at all once it's actually COLD.
2006 Red Blitzed RS 5-door
Old 11-19-2008, 09:33 PM   #3
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
i leave mine on medium, and it is possible to get it smooth, it all depends on how you put pressure on the pedal, i had no problems starting her up in the cold so far, but its only been in the 30's, i installed the new perrin catch can and it doesnt get hot whatsoever as the greddy can does. and runs smoother imo with it installed, maybe camelll can chime in on this. i guess it doesnt help that we
have to change to colder plugs either
staypuft is offline   Reply With Quote
Old 11-19-2008, 09:04 PM   #4
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
Spoiled California people!
It was 20 when I went to work this morning...
Lisa
aka SIPNGAS
Old 11-19-2008, 09:17 PM   #5
LtNoogie
LtNoogie's Avatar
Not spoiled. Delicate.
Old 11-20-2008, 01:55 AM   #6
LtNoogie
LtNoogie's Avatar
Tonight started out Ok but spiraled downhill until it became a disaster. Pictures will posted shortly.
Old 11-20-2008, 02:09 AM   #7
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
are you lying
Old 11-20-2008, 03:55 AM   #8
LtNoogie
LtNoogie's Avatar
The manifold/blower slips onto the three studs, thanks to Camell for the tip. The two outside Torx tip bolts are replaced with the hex head bolts.
The fuel rail gets wiggled loose until the injectors can be popped out to make room to install and tighten the top manifold nuts. Gasoline drips onto the valve cover and we breathe fumes for the next half hour.
The injectors are lying willy-nilly.
DO NOT TIGHTEN THE MANIFOLD NUTS AND BOLTS YET!
There are two bolts that need to attach the pulley side of the blower to the alternator bracket. I did not take a picture so here is one from the installation manual.
Since I had already tightened the five manifold nuts and bolts (f**k-up #1), there was no way for the other bolts to line up. BTW, we could not find those two bolts in the packages. Luckily, last night I bought a box of metric hardware at Pep Boys for $9.99. That came in very handy.
We install two bolts from the opposite side as the instructions said to kinda work their way and line up the holes.
I start cranking away at one of the bolts, not paying attention. (f**k-up #2). Instead of causing the alternator bracket to line up, the bolt pushes the top of the alternator bracket to towards the fender. I've bent the damn thing and the alternator is now crooked!
I don't have a picture of the messed up situation. We carefully send the second bolt through the second hole and miraculously, it makes it through both holes. I attach a nut and start tightening which pulles the alternator bracket back in line. The Moron dodges a bullet.
The picture shows the alternator bracket firmly attached to blower and there is no gap. Earlier, there was a 1/4 inch gap which was all alternator bracket being bent towards the fender.
Ok, back when I attached the blower to the intake manifold, I did not pay attention to the hint below so now I have no place to attach my dipstick tube bracket. My brother will fab something for the dipstick tube to attach to so that it doesn't pop out and fall off. (f**k-up #3 but done earlier)
The compressor inlet pipe goes on and it nows looks like a supercharger! Time to attach the vacuum lines to the inlet pipe.
I think others have mentioned it but one of the original vacuum lines is too short to go to its inlet pipe nipple. First picture show the vacuum line before the teardown. Second picture shows where it needs to go.
So close to attaching the throttle body and the CAI! Now I have to go to Pep Boys tomorrow to buy some vacuum line.
Since we can't close her up, we start to route the belt through the maze of pulleys. It's now really tight in that area and it takes two of use to snake through its path.
DISASTER! The metal A/C lines that we were afraid of before get in the way of the belt! I think Doc had problems with his A/C lines too.
The only thing we can figure out is to try to reach into the impossibly tight spaces to remove a screw holding a bracket that holds the A/C line. We might be able to yank the lines out of the way and tie them down somehow with nylon straps.
While backing out one of the screws, I realize that the screw is very long and now I can't get my ratcheting box end wrench off the head because I am too close to the NST water pump pulley. It's one of those ratchets that you have to turn around to tighten, so any movement I make keeps backing out the screw. I now have a freaking tool stuck down there. I did not know whether to laugh or to cry.
My brother will try to buy some big ass needle nose pliers tomorrow to try to turn the srew back in until the wrench can come free. If that doesn't work, he may have to run a hacksaw blade down there and hope to cut the screw. Did I mention it is really tight down there?
We have no idea what to do next because you cannot get your hand in there. Tomorrow's another day.
Old 11-20-2008, 09:09 AM   #9
LtNoogie
LtNoogie's Avatar
Originally Posted by camelll View Post
That is what I thought........... Until that damn second B spacer. It is alot easier the second time as you know what to expect and have all the tools.
I cannot imagine what it was like taking it apart and putting it together a second time just for that Spacer B but I know that there was no other way for you. You should advertise yourself as a qualified Blitz installer in the Midwest.
The mechanics around here wanted $950 to do the install. That almost sounds cheap by now.
Old 11-20-2008, 09:58 AM   #10
LtNoogie
LtNoogie's Avatar
No problem. How did that center nut tighten up? That thing gave me a massive headache until I went out and bought a ratcheting swivel box end wrench.
I used an open-end wrench. The head of the ratching box end was too big. The nut tightened up as easily as the other two on top.
I did not put those bolts in, I did the same thing and when I got done I realized that I missed that step. I tried but the holes did not line up. I figured that the alternator bracket and the compressor are both attached to the engine block and move together anyways and there is no gap in mine either. I might buy some smaller bolts someday and do what you did, but I am not having any problems after I put that second B spacer in.
I am guessing that those bolts keep the top of the alternator bracket from vibrating from side to side. Bolting it to the rigidly mounted blower makes sure that you don't get that movement. Anyhow, I have one bolt in there now. The second hole is stripped and we could not start a tap through it.
That sucks, I did not have as much trouble with my ac lines, I just pushed mine out of the way and that was that, maybe the sedan has a little more room in the engine compartment.
A/C lines are gonna kill me in the end.
Old 11-20-2008, 12:51 PM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Are you serious?! Wow... lucky guy! I ended up getting my girlfriend (with small hands) to get that nut on the bolt, and get the threading started.
What'd I tell you, man? Getting in there now to fix the A/C lines is gonna be wicked hard.
But yeah, this has been like a trip down memory lane. I remember about the dipstick bracket... I managed to get a shorty 14mm (I think?) wrench under there and loosen it up so I could attach it. Bummer about bending the bracket... I'm glad it straightened out! And remember to put a little lubricating fluid on the O-rings when you pop the rail back on the injectors. My friendly neighbourhood Toyota tech told me to always use something when fiddling with the injectors, otherwise the rings might pinch and not seal properly.
Agreeing with camelll, it's definitely not as hard to undo and redo the 2nd time. For your A/C lines (and those two bolts) (AND the dipstick), it might be easier to take the 'charger back off, fix everything, and then put it back on. Seriously. I know it sucks! But those lines are really in the way!
And for the ECU, it's only held to the firewall by three 10mm nuts & bolts... getting it off is pretty easy. The two big connectors on top of it, the left one (the bigger) won't clear the cowling... so either you take off the whole cowling like camelll did, or pop the ECU off the firewall, undo the connectors, and put the ECU on a table while you do your splicing. Either way...
We all had our struggles putting this thing on. I didn't tighten my stud bolts on the 'charger as much as I wanted, and then ended up stripping a nut (so I'll never get it off). Keep going! Good luck!!
Oh, and thanks for the responses guys about your cars starting fine in the cold weather. It's been happening here even when it's only in the 40s. So maybe I did something wrong. I'll have to pop the hood and have my girlfriend start it while I try to see if everything is ok. Hmmmm!
Old 11-20-2008, 09:22 AM   #12
LtNoogie
LtNoogie's Avatar
kurokoma-kun and whooppee777, are you guys taking notes?
Your turns are coming up next and I don't want to have come out there to get you out of trouble. Especially if you repeat the same f**k-up I did.
Old 11-20-2008, 09:24 AM   #13
LtNoogie
LtNoogie's Avatar
1,369 views so far! I am grateful that there is so much interest.
It must be like watching a train wreck in slow motion. LOL
Old 11-20-2008, 09:40 AM   #14
LtNoogie
LtNoogie's Avatar
It's funny how you and I can laugh about stuff like the non-existent fuel pump relay now that it's past us. That was the first day and the first step of the install and I'm saying to myself WTF!
I think all the views are from the same 10 people. 5 of them going ... "I'm not doing a supercharger". The other 5 like yourself going "oh yeah, I forgot about that nighmarish step. Good times."
Old 11-20-2008, 12:35 PM   #15
PETERPOOP
PETERPOOP's Avatar
stay strong
Old 11-20-2008, 12:46 PM   #16
well, it may read like mostly bad news to some, and mostly good news to others, because you got it done and you're closer to finishing.
So far, you've resolved every problem you encountered, so I have faith in the big finish!
I'm taking you out for a nice sushi dinner when you're done -- you can drive, or course.
Old 11-20-2008, 01:42 PM   #17
LtNoogie
LtNoogie's Avatar
No, YOU can drive. I'll be behind you in MY car as you tow it with my shiny new tow hook.
Old 11-20-2008, 04:06 PM   #18
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
A yaris towing a yaris, that will be a hoot to see...the car explode from its insides out! :P
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
