#1 | |
#2 | |
97whp on a STOCK AUTOMATIC 1nzfe that is rated at 106 AT THE CRANK??????? sorry, i call B.S. edit: read that you had a muffler.. still isn't gonna make up for the 10 or so extra HP you show..
Been a long time messing with cars.. |
#3 | |
Second, my HB is the automatic and served as the subject car for development. The sedan on the dyno last night is a 5 spd.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
And interesting because one of the Matrix guys was pissed, claiming his tested much higher on another dyno so???In any case it's a know fact that no two dyno's will read the same. Different machine, different temps, different air, different operator... The purpose of these tests were to compare baseline hp and that generated with the Jet Stream Intake installed. The pulls were accomplished within minutes of each other with only the time to switch the intakes between tests.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#5 |
Vroom Vroom Beep Beep
Where do I need to send my arm and leg
Ever blown out an R-200 diff god know's I have
#6 |
lol, matrix guys saw you there last night too, eh?
#7 |
Yes, a couple Matrix were tested prior to my Yaris.
Regarding the Yaris results; If my baseline HP seems a bit higher than others results keep in mind that I had the TRD Axle-back in place. Otherwise no power-adders in place. Also the OEM air filter element was put back in for the base-line test. I normally run with a K&N drop-in.
#8 |
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
/\ /\ /\ mmm so angry
#9 |
nah, it's just a mis-calibrated dyno.. either way, good numbers from the intake.. even if they aren't accurate
#10 |
ya, i saw the dyno for that xrs...was woefully low
yours makes some sense for a trd axle back and 5spd...5whp over stock doesnt seem too out of the range of plausibility for the yaris... were you guys open to the outdoors? were the dyno's SAE corrected? how cold was it? likely about -10C and low humidity? not bad gains though muskoka
#11 | |
#12 |
just sayin that if the dyno wasnt SAE corrected, itll run a few hp higher....but given the matrix guys were runnin low....but in 4th gear doesnt make sense to me
anyways, the key is in the difference over stock anyhow....so the PRM like most other intakes at a few hp and tq at the wheels over stock..... sidebar: typically, the matrix guys use forrest and forrest racing in kitchener as their gospel. i dynoed my xrs in london one time and ran about 180whp while comparing 03 and 04 xrs ecu's. that was about 10whp higher than i ran at forrest and forrest. matrix guys wouldnt except 100whp/L, lol. so at any rate, i took it for what my test was originally for: and that was to compare power curves of 03 and 04 xrs ecu's....
#13 | |
Whether or not we are getting a 'true' whp reading for the Yaris here is not the point. This was a test to measure, back to back, the difference between two setups.
#14 |
have dyno sheet yet?
#15 |
Best I currently have is a crap scan. Had to play with colour hue to make both run lines visible.
Edit - 2008/01/18 new copy of graph received and is now shown.
Last edited by WeeYari; 01-18-2009 at 05:11 PM. Reason: new copy of graph received. |
#16 |
neato.
#17 |
Don't know how the xrs that was there felt about his numbers. Was interesting to see his results from 3 setups tho. I think these are the right numbers.
Stock 146.43 whp AEM SRI 149.34 whp AEM pipe + PRM filter 153.30 whp
#18 | |
here's mine from london
| looking for toronto car for prototype CAI | jetstreamer | Canada | 24 | 02-21-2009 02:02 PM |
| Which CAI and Exhaust should I purchase? | bakedwookie | Performance Modifications | 17 | 08-05-2007 02:00 PM |
| TRD CAI & TRD Qiuck Shift | Polar | Items for Sale by private party | 7 | 08-02-2007 06:03 PM |
| SRI vs CAI | sklau | Performance Modifications | 5 | 07-04-2007 01:24 AM |
| CAI Question? | falkor_99 | General Yaris / Vitz Discussion | 5 | 04-23-2007 03:59 PM |
