Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 12-19-2008, 08:32 AM   #55
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
yesterday I found one foe $55......... I might go back and grab it....
I Drive a 129whp Yaris ;)
YarisPR is offline
Old 12-19-2008, 04:05 PM   #56
gwasabi
Drives: 07 Blazing Blue LB
The corolla TB throws a CEL light. T-T i dunno y
gwasabi is offline
Old 12-19-2008, 04:26 PM   #57
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Reset ECU and check make sure all the air bubbles are out of the coolant lines that go into the throttle body. Also check the connector the TB to make sure its on correctly.
Disconnect negative battery cable for a couple hours to completely reset the ECU. Usually leaving it disconnected overnight would be best.
FunctionSpec is offline
Old 12-19-2008, 05:05 PM   #58
gwasabi
how do i make sure all the air bubbles are out of the coolant lines?
I did reset the ECU though. it kinda like does this wierd thing when slowing down too. like it revs up then and down by itself. I dunno whats up with that but maybe I'll try reset ecu again
gwasabi is offline
Old 12-19-2008, 05:25 PM   #59
FunctionSpec
Super Newbie
Yeah sounds like theres air in your coolant lines.
Once the car cools down, take off radiator cap. Turn on car and let it run at idle. Let it warm up. You'll see air bubbles bubbling out of the coolant. GENTLY squeeze the smaller coolant tubes in various areas to help push the rest of the air out. It'll be kinda hot so don't burn yourself. Keep doing until you see no more air bubbles coming out and your done.
Old 12-19-2008, 09:33 PM   #60
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
pick it up for me and i'll buy it from you if it's legit.
PETERPOOP is offline
Old 12-20-2008, 02:31 AM   #61
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
I nabbed a corolla TB today for $45.00 plus shipping I want to see what this does. Peter I might sell it to you if I don't like it.
ztrack157 is offline
Old 12-20-2008, 03:22 PM   #62
PETERPOOP
PETERPOOP's Avatar
ah thanks for the offer, but i am wanting the xD throttle body,not the carolla.
Old 12-20-2008, 03:34 PM   #63
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I got a 05 Corolla TB and the instalation was clean, nice and easy. The car iddles normally but it won't go over 2000rpm.... What could be the problem?
YarisPR is offline
Old 12-20-2008, 03:53 PM   #64
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Possible vacuum leak.
anonymous user is offline
Old 12-20-2008, 04:12 PM   #65
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I just putted the intake just touching the TB I did't connect it. And as soon as I moved it a little the car turned off. I might have to try it with everything connected.
YarisPR is offline
Old 12-20-2008, 06:38 PM   #66
what did you use for a gasket?
thebarber is offline
Old 12-20-2008, 07:03 PM   #67
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I just tooked out the Yaris TB and place the Corolla TB. Do I need something else? What gasket?
I think I'am doing something wrong..
YarisPR is offline
Old 12-20-2008, 08:36 PM   #68
Old 12-22-2008, 03:51 AM   #69
gwasabi
i didn't really need to use gasket in a tube for the tb install....works fine. also this mod is pretty awesome. you can feel the difference. more responsive in higher rpms and sounds hella awesome.
gwasabi is offline
Old 12-23-2008, 09:08 PM   #70
anonymous user
Drives: 07yaris
How easy was the install, and where did you get the TB?
Old 12-23-2008, 10:02 PM   #71
gwasabi
got mine from barber. Install was SUPER easy. it goes right in. and just stick all the pipes back into the right places. took me about 30 min to install. shouldn't be too hard if you have aftermarket intake. If you have stock intake it might take u a little longer
gwasabi is offline
Old 01-01-2009, 03:11 AM   #72
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
i like the sound of this, lol
what is the size of the 1zz TB inlet compared to the 1nz? Would one need a different size intake tube for it, or would the rubber couplers for a CAI stretch over it neway?
AlexNet0 is offline
WTB: Modellista body kit Repofspeed Items for Sale by private party 4 08-31-2007 01:43 AM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
Scion xD Rudeshady Central and South America 1 06-25-2007 01:11 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
