Old 08-06-2009, 02:19 PM   #1
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
so a nitrous kit takes almost 2 seconds off your time on a stock 1.5?
Old 09-23-2009, 04:33 PM   #2
Liltoaster
Drives: 05 Echo H/B
That is correct, I went from 18.03 to 14.98 with my setup :)
Liltoaster is offline   Reply With Quote
Old 09-23-2009, 05:19 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You were running higher than 50hp shot for sure...
If you did a 75hp shot you got balls! props for that!
I'm helping a friend installing a NX wet kit on his Yaris on the next couple of weeks. But we will use 35hp nozzles for the street and 50hp nozzles for the track only... we will use some high octane fuel on the 50hp runs... just for extra safety...
Old 09-12-2009, 04:50 AM   #4
H3LlIoN
Drives: '09 Yarrrr hatch
I've got 17.54 @ 78.37mph in a bone stock '09 Yaris HB with the 5 speed. It'll be next week before I get the slip to a scanner though. No weight reductions, no mods whatsoever, not even a tach. The 60 foot times were off as I was running the stock rubbers... I'm gonna pick up some slick on wide steelies, and figure out a tach/shift light combo before I head back. Oh and, I don't fall under the "unseasoned" drivers group either.
H3LlIoN is offline   Reply With Quote
Old 09-23-2009, 05:24 PM   #5
I'll have times on Oct 31.
Old 09-23-2009, 05:32 PM   #6
CASTREX
CASTREX's Avatar
1/8 mile times or the real deal???
What mods are you planning for the track??
Tire compound and size?? Suspension set up? come on we want more info!!
You better get her low in the 12's....
Old 01-14-2010, 01:38 PM   #7
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Any times for us yet?
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 09-23-2009, 07:14 PM   #8
real deal 1/4 mile @ fontana.
http://www.autoclubspeedway.com/
You know all my engine mods, but I will be trying some drag slicks I got from Art IF they fit over my brakes. I'll get them out and measure them up tomorrow. Probably need spacers.
My suspension is:
Silk Road coilovers
TRD motor mounts
BeatRush trans mount
UR rear underbrace
Tanabe front strut brace
UR 23mm rear sway bar (like that will matter, LOL)
Old 09-24-2009, 01:42 PM   #9
CASTREX
CASTREX's Avatar
My suspension is:
Silk Road coilovers
TRD motor mounts
UR rear underbrace
You need to make them fit..!!! If not get others that fit... or get rid of the front BBK. Like you will need that on the track! Taking your car w/o a proper set torsion tires will be like not going at all. Is a most!!
Is important to dial the right pressure for the drag slicks. I'm sure Art can give you a few pointers as he has experience with the box.
Front: just high enough not to rub the tires. Stiffness Probably some where in the middle. Front suspension should allow for some travel but have good dampening to prevent bounce.
Rear: as high as the silkroads allow and full stiff. Over inflated rear tires...
Leave the rear under braces and sway bar at home!!
Go to the local strip to practice some launches!
Oh and please.... HD video!!!!
Old 05-21-2010, 12:31 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
Hey guys don't forget to put down on the "list" what type of tranny at least, and if it was n/a or boosted.
Old 10-05-2010, 08:28 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
18 sec
Burningbjorn 18.35 @ 78.7
17 sec
Silver echo 17.37 @ 79.4
Camelll 17.46 @ 78.18
16 sec
H3LlIoN 16.38 @ 84.02
Astroman 16.97 @ 81
15 sec
cdydjded 15.5 @ 92
14 sec
Chinocharles 14.93 @ 96.3
Liltoaster 14.98 @ ?
13 sec
jose 13.95 @ 95
Blown_xa 13.63 @104 (190whp)
12 sec
Scion Crew 12.97 @104
Garm 12.809 @107.3
somehow I was still listed in the 14's. Also added Garms time.
Ill post some crazy times next season, last time I went to the dragstrip recently I trapped 110mph, but didnt run too well haha. For now Im focused on track events and auto-x.
Ptuning.com
Old 10-06-2010, 12:51 AM   #12
Astroman
Modded Moderator
Astroman's Avatar
Awesome! I can't wait to go back to the track again to see how I do since the new mods. Can't wait to get boosted though somehow.
Old 09-23-2009, 08:43 PM   #13
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Make sure you turn up the dampening on you rear shocks all the way and put your rear tires at max PSI to try and keep weight transfer to a minimum. Have you been working on your launches?
Old 09-23-2009, 08:57 PM   #14
frownonfun
frownonfun's Avatar
subscribed
Old 09-24-2009, 02:18 PM   #15
I don't have a BBK - all else duly noted, thanks!
Old 09-25-2009, 03:13 AM   #16
Astroman
Modded Moderator
Astroman's Avatar
Come on guys, slips!
Old 09-26-2009, 03:45 AM   #17
ruimond
Drives: Yaris YR
17.4sec 1/4 Mile. Thought a S/C Yaris would be quicker then that. Haha. Hopefully you do better next time you go with less wheel hop.
Old 09-26-2009, 04:04 AM   #18
Hey Mike, did you lower your front tires' psi? I forgot to do that too, and I had a lot of wheel hop too. I need to repost my slips one of these days...but I have to find them first.
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
