Old 04-17-2016, 01:38 PM   #55
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I did it on the passenger side without taking the whole assembly or the front bumper off. I used this guys video and the eyes in my fingers: https://www.youtube.com/watch?v=rPpXkBBfYEU
The whole video is good, but especially 13:54 is the best part.
By the way, the fat tab went up and the clip flops down when you take the bulb out. It flops upward when putting the bulb back in. Don't put grease on the contacts until after you put the bulb in and the boot on. Use vinyl or nitrile gloves when handling the bulb. Use a flat head screw driver to gently pry the boot off. Watch the video. These directions I am giving are not in order. Look at the bulb and the clips through the front of the headlight assembly while taking the bulb out and putting it back in.
It took about an hour.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 05-01-2016, 05:06 PM   #56
robkay
Drives: Hatch
If you figure on having your Yaris for a while you can get a pack of clips cheap on eBay. Pick up a set now to have in your box for next time.
robkay is offline   Reply With Quote
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 08:30 AM
