#1 | |
![]() Drives: 2011 Yaris HB Join Date: Nov 2018
as long as the RPM stays around 500 to 550, it will not stall. I have found that TURNING OFF the defroster when you dont need it is the best way to fix the problem as it uses the AC condenser and the extra load causes the momentary dip in RPM. Wiper blades will do it too. It seems to be a normal function of the small engine. |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Put it in neutral while you are at the light...vibration should go away.
#3 | |
![]() ![]() Drives: Yaris Join Date: Oct 2017
#4 |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
I experienced this, the mechanic dismantled the Throttle Body and cleaned it. Put it back and everything went back to normal.. A lot of dirt accumulated in the plates and the sides of the airway of the TB.
Once in a while TB needs to get cleaned, for desert people, it is required often. I used original engine air filters from toyota and i normally blow them every 10kkm during change oil,,, however i replaced them every after 20-30k km just to be sure they are still efficient in filtering dusts... |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Waiting for the Taiwan Yaris | heybai | General Yaris / Vitz Discussion | 13 | 03-12-2006 07:26 AM |
