Old 03-16-2009, 12:44 PM   #55
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I have a scangauge. Perhaps I'll make another video and strap the scangauge on top of the other gauges so that we can see how timing corresponds to AFR and boost levels.
What other scangauge settings would be useful to view? I have RPM currently showing also. I can ditch the two MPG settings for this video.
Old 03-16-2009, 12:46 PM   #56
LtNoogie
LtNoogie's Avatar
Originally Posted by camelll View Post
Long I would be curious what your readings would be if you moved the sensor to pre cat position? I would try that before buying a piggyback.
Mike, I would rather poke out my eyes than to try to get that bung moved and the cable moved with it. Getting everything in place once was damn difficult.
Old 03-16-2009, 12:47 PM   #57
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
That is great!
RPM, ignition advance, injector duty or latency, and if there is a load, or airflow parameter, that would be perfect.
Or if you want to post a list of everything it can do I can tell you which ones you will want to monitor.
You have an auto right?
Old 03-16-2009, 12:52 PM   #58
LtNoogie
LtNoogie's Avatar
Originally Posted by largeorangefont View Post
That is great!
Ok, I'll make a list tonight of the values it can display.
I know it can do RPM, ignition advance, and load. I don't think the other settings produce a value. Perhaps the ECU does not report them to the scangauge.
Old 03-16-2009, 12:54 PM   #59
largeorangefont
Break'em off some.
* Engine Speed (RPM)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Ignition Timing
If Manifold Pressure is not available, use Throttle Position instead.
Old 03-16-2009, 12:56 PM   #60
largeorangefont
Break'em off some.
The ECU does report them, but the Scangauge probably does something to the value to get the fuel economy/fuel rate numbers.
What unit does the fuel rate parameter use?
Old 03-16-2009, 12:57 PM   #61
LtNoogie
LtNoogie's Avatar
cpm... I think. I've never known what to do with that reading.
Old 03-16-2009, 12:58 PM   #62
LtNoogie
LtNoogie's Avatar
* Engine Load
* Ignition Timing
Wouldn't you get Manifold Pressure from my boost gauge or is that a different manifold pressure?
Old 03-16-2009, 01:00 PM   #63
LtNoogie
LtNoogie's Avatar
I have a tach, boost/vacuum gauge and I already monitor the timing and load. How does the throttle position fit in or correlate with the others?
You just don't have a video camera!
Old 03-16-2009, 01:04 PM   #64
LtNoogie
LtNoogie's Avatar
I just use my cheap Olympus digital camera and run it in movie mode. Most all of the cameras have that mode.
Old 03-16-2009, 01:05 PM   #65
I hear WalMart has a good deal on Hanna Montana designed vid cameras, lol.
Old 03-16-2009, 01:10 PM   #66
lol
Old 03-16-2009, 02:21 PM   #67
largeorangefont
Break'em off some.
It is the same, but it was hard to see in the video.
Old 03-16-2009, 02:26 PM   #68
LtNoogie
LtNoogie's Avatar
I'll try to do a better job next time. Thanks.
Old 03-16-2009, 02:34 PM   #69
largeorangefont
Break'em off some.
Where did largeorangefont go? I would like him to explain some of this shiiiiit to me cause I really don't know. I understand about timing, advancing or retarding and when I am under boost the load is basically on 99 percent. I just don't understand how all of these tie together with rpm and manifold pressure.
Sorry, Had to do some actual work. I gotta head out to a customer, so here is a brief overview.
In reality \keeping an engine alive comes down to EGT (exhaust gas temperature) and knock.
You use a balance of AFR and timing to keep both factors in check. You can't crank up both and expect an engine to live.
Think of fuel as coolant for the combustion chamber. Think of ignition advance as how hot the fire burns. Obviously if the fire burns too hot, bad things happen. If it burns too cool, the car runs like crap and is slow. The temperature of that fire is EGT. You can control EGT by adding more coolant (fuel) or turning down the intensity of the flame (ignition retard).
OEM supercharged cars will (generally!!) run low timing and a high AFR to increase fuel economy and reduce emissions. My Cobra for example ran in the high 13 AFR range under load, but only had 10 degrees of ignition advance from the factory.
I now run the AFR and 11.3:1 AFR under load, and 21 degrees of ignition advance, and picked up 30 some odd HP and torque. It runs like a different car. The increased timing makes the car more responsive on tip in (passing etc.), and much more driveable. Power "under the curve" is increased as well as peak power.
EGTs in both scenarios were VERY similar, at around 1300F. From this example, you can see there are many ways to the same end. Some produce more power than others.
Knock is another factor to be wary of. Again, to get rid of knock you can add more fuel, or retard timing. Strategies can vary on how to get rid of knock, especially in turbo applications.
Old 03-16-2009, 02:35 PM   #70
largeorangefont
Break'em off some.
No problem, you just have a like a 30 # boost gauge
Old 03-16-2009, 02:44 PM   #71
A very delicate balancing act
Old 03-16-2009, 06:24 PM   #72
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
so if we got the cam com we could adjust the cams to cope with the crazy a/f readings?
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
WTB or free front bumper any condition in SOCal Walter Items for Sale by private party 3 09-14-2007 12:56 AM
