Old 03-06-2009, 10:33 AM   #55
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
ummm...
i was wrong? :(
taKuto is offline   Reply With Quote
Old 03-06-2009, 10:45 AM   #56
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by taKuto View Post
i was wrong? :(
If it would only be that simple....
We would have 20 turbo Yarii on this forum by now...
Old 03-06-2009, 10:47 AM   #57
Tamago
Tamago's Avatar
Drives: UZJ100
i was wrong? :(
you and i share like-ECU's
the new yarii ecu's are pansies
Old 03-06-2009, 11:28 AM   #58
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I have a question maybe someone can answer, hopefully Tamago or Cali, but these ECU's i have been thinking they make corrections based of the O2 sensor readings, but is it possible they read off the MAP sensor as well? Do these cars even have one or do they manage without it?
because i know there is a way to trick the O2 sensor, and i read of people tricking the MAP sensor by putting a restrictor in the line...
Old 03-06-2009, 12:02 PM   #59
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
less things to worry about for me then
what's the main differences with the yaris ECU over the echo/scion ECU which prevents a piggyback from functioning? Fooling the MAF isn't enough for low boost? I know greddy makes some sort of o2 sensor adapter they recommend for the 1nzfe, which I'd guess is just an expensive resistor, wouldn't that work for lowering o2 sensor readings? Not sure what else these ecu's look at other than MAF and o2, still new to the snail game.
Old 03-06-2009, 12:16 PM   #60
CASTREX
CASTREX's Avatar
The Yaris ECU is just a bit more smart. And when a piggyback is trying to mess up with is normal functioning it will self adjust to bring the car to it's original parameters.
The AEM FIC is supposed to be the hottest latest thing out there in regards to piggy backs. 2 or 3 people have tried to tune a Yaris with them with out succsess.
I believe succesful piggy backing can be done... I mean is a Yaris, not a space rocket. Just there are not that many people trying out there. So there is not a proven way to do it yet.
People in Asia are using the Dastek Unichip to tune the Yaris... So it can be done.
Is just that no one has come yet with a clean effective way to make an Emanage or a FIC work on the Yaris.
There are a lot of getto ways to go around this... but must Yaris owners are concerned with reliability....
Old 03-06-2009, 12:19 PM   #61
CASTREX
CASTREX's Avatar
Talking about piggy backs....
The Infamous POwer Enterprises SC comes with a split second unit right?
Has anyone contacted split second regarding that particular unit???
Old 03-06-2009, 12:40 PM   #62
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
if it's adjusting to stock, then it has to be reading some value that the piggyback is not intercepting in order to adjust accordingly? But if you modify the O2 and MAF, what does that leave for the ECU to base its adjustments off? The ecu can't be completely closed-loop i'm sure it relies on feedback off other values if it's smart enough to adjust to changes.
Old 03-06-2009, 12:46 PM   #63
Nexus1155
Drives: Audi
Says you...
MAP sensor is another thing that most cars read off for boost? like i asked before but it was disregarded lol i guess
Old 03-06-2009, 12:55 PM   #64
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
I think the yaris only has an MAF on the intake, but for boost applications a MAP is the preferred way to go, though I wonder if its worth it to trick the ecu MAF while running off an addon MAP at the same time.
Old 03-06-2009, 01:12 PM   #65
Nexus1155
Drives: Audi
it might be depending if you can add one on there, but i wouldve figured all cars had a 1 Bar MAP, how is it going to detect manifold pressure? I think the pressure is displayed in scangauge?
http://www.go.jeep-xj.info/HowtoMAPsensor.htm
Old 03-06-2009, 01:31 PM   #66
Four, actually.
LOL so true and so sad.
Takuto, I know you're trying to gain information, and that's cool -- but there are those of us who have tried and failed so far, so please accept that information as valid.
My suggestion is GO FOR IT, and teach us something. The fact remains that there is no tuned turbo Yaris in the USA at this time, unless there is one I don't know about. Mine will be soon, but at the cost of going full standalone. That's not the solution most have been looking for.
Unless more people try, we won't get anywhere.
(I said Yaris, Tamago -- you're one of our inspiring 1.5L exceptions )
Old 03-06-2009, 01:51 PM   #67
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
any prospects on swapping out the yaris ecu with an echo ecu, with just some rewiring for the harness?
Old 03-06-2009, 02:09 PM   #68
Tamago
Tamago's Avatar
Drives: UZJ100
not worth the effort.
you'd need to replace multiple sensors, lengthen the harness, drill a hole in the firewall.
all that and you could have got a standalone.
or a faster car
Old 03-06-2009, 05:51 PM   #69
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
or a faster car
Any other 1nz-fe car we could swith the ECU with or would it be the same?
Off of Wiki
1NZ-FE
The 1NZ-FE is a 1.5 L (1497 cm³) conventional Otto cycle variant of the 1NZ-FXE. It has the same bore and stroke, but the compression ratio is lowered to 10.5:1, and it features VVT-i. Output is 80 kW (106 hp) at 6000 rpm with 140 Nm (103 ft·lbf) of torque at 4200 rpm.
Applications:
* Toyota Yaris/Echo
* Scion xA/ist
* Scion xB
* Toyota Vios
* Toyota Raum
* Toyota Porte
* Toyota Platz
* Toyota Auris
* Toyota Fun Cargo
* Toyota Premio
* Toyota Allion
* Toyota Sienta
* Toyota WiLL
* Toyota Probox
* Toyota Ractis
* Toyota Corolla Axio
* Toyota Corolla Fielder
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-06-2009, 07:57 PM   #70
CASTREX
CASTREX's Avatar
or a faster car
You will also have to figure out way to handle the drive by wire.
Echos / xA / xB have all conventional cable throttel.
Old 03-06-2009, 08:04 PM   #71
CASTREX
CASTREX's Avatar
There are alot of tuning devices out there... is just that only a few people have tried it so far.
The new Scion TC's shouldn't be that different from the Yaris in regards to the ECU tunning...
And look at them... bunch of them running turbos with piggy backs.
Some one should just take a Yaris to Dezod or something...
Old 03-06-2009, 11:28 PM   #72
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Well once Titan Motorsports (Deals with Big Scale! Toyota Projects) here in Orlando gets their new shop open, I might just knock on the door and ask what the can do again, since the will have a new shop with more toys at their disposal. they do Unichip tunes,so that might be an option once more; but when I asked about it before...they said the gains werent worth the money.
Plus they work on so many TC's and Celica's they might just have a trick up their sleeve, or know someone who does.
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Carpet floor mat protection Jungle Rot Cosmetic Modifications (Exterior/Interior) 12 02-01-2009 05:14 PM
DIY Floor mats chadmw06 DIY / Maintenance / Service 5 08-30-2006 12:47 PM
For Sale: Yaris floor mats msagowitz Items for Sale by private party 9 08-25-2006 01:32 PM
