Old 02-25-2007, 07:39 PM   #55
ChinoCharles
Drives: LB
DIBS!
Old 02-25-2007, 07:40 PM   #56
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Already had you in mind.
Old 02-26-2007, 01:21 AM   #57
ChinoCharles
Drives: LB
Old 02-26-2007, 05:48 PM   #58
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Question for something I also have in mind....does the stock rear badge have a slight curve in it or is it pretty much flat??? I'm hoping its flat as Calista Flockhart.
jdubau55 is offline   Reply With Quote
Old 04-12-2007, 12:03 AM   #59
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
bump...I'm getting my Vitz "bolt" rear emblem and front emblems in soon...and need this for pointers.....
Old 04-12-2007, 05:34 AM   #60
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
whats their to know about badges...u can even rip it apart from ur hands....
Old 04-12-2007, 08:12 AM   #61
Shroomster
Shroomster's Avatar
what can't keep at least one of the badge threads at the top so people don't come and ask everyday?
Old 04-12-2007, 08:18 AM   #62
yarisuzr
Drives: 2007 Blazing Blue Yaris
Any chance I could get a how to on this process? I would like to take the front and rear off and do the same. Primer? Paint? How to get the badges off?
yarisuzr is offline   Reply With Quote
Old 04-12-2007, 09:53 AM   #63
Chris07LB
Chris07LB's Avatar
Front emblem can be removed from the black housing (go look at yours to see what i mean), by gently heating and "sawing" away from behind with fishing line.
Same exact procedure for the rear, except there is no housing, it is attached directly to the hatch.
You will need to find some 3M body tape to reinstall the emblems. DO NOT use regular double sided tape from the hardware store, its way too thick, wont be as strong, and will look like shit.
Body tape is whats used to install spoilers, body kits etc. Its super thin, and SUPER strong, so be careful when you are placing the emblems.
That should cover it, now go do it.
Old 04-12-2007, 12:51 PM   #64
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Thanks Chris... I'm hoping to do the rear emblem this weekend.
As for painting, do you suggest sanding it a bit first to prep, then using a primer, then paint? I'm assuming spray cans for both primer and paint, with paint specially formulated for plastic. Any top coat?
Thanks!
Z
2006 Red Blitzed RS 5-door
Old 04-12-2007, 01:01 PM   #65
Chris07LB
Chris07LB's Avatar
800grit wet sand > plastic adhesion promotor primer > base coat > clear coat.
Let it settle a few days, then compound pase the emblem, buff clean, then wax.
Install.
Old 04-12-2007, 04:29 PM   #66
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
deff do the above, or else you'll have to redo them... (dont look at me...)
will work for parts
Old 04-13-2007, 08:14 AM   #67
yarisuzr
What is "compound pase" the emblem?
Old 04-13-2007, 08:32 AM   #68
Chris07LB
Chris07LB's Avatar
Remove fine scratches, oxidation, coarse swirl marks and water spots!
Here’s your antidote for the mildly neglected car. 3M’s most versatile rubbing compound is aggressive but safe against fine scratches (grade 1200 or finer), light to medium oxidation, pesky water spots and coarse swirl marks. The super-fine cut abrasive wears down sharp edges and smoothes out the paint’s surface, preparing it for a polish or glaze, followed by a protective wax.
Old 04-13-2007, 09:55 AM   #69
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Cool!
Old 04-13-2007, 10:23 AM   #70
mygfdrivesayaris
Drives: 2006 Scion XB
I'm a big fan of Black Emblems on white, but normally shave them altogether - that looks damn nice
mygfdrivesayaris is offline   Reply With Quote
Old 04-13-2007, 10:35 AM   #71
Chris07LB
Chris07LB's Avatar
Its actually been changed up a little while ago.. but Ive since removed the NETZ badge, and going back to a color matched toyota emblem.
Old 04-13-2007, 05:35 PM   #72
Shroomster
Shroomster's Avatar
ok am I missing something isn't what is in your pic called the "lightning bolt"? or are the netz and the lightning bolt the same thing?
Response from Toyota Driver New YARIS Purchase Forum 22 09-04-2006 07:44 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
