Old 04-10-2011, 10:26 PM   #55
birdman
I wish I had the brains to do this and the seat warmer mod. CT Scott walked me through one mod and it worked great. This rear wiper mod is one I've waited for CTS to solve but it is beyond my mental limitations. I'm thinking of getting an IQ so I'll have more room to work on my Isetta project. The IQ is nearly 30" shorter than the Yaris. I wonder where the IQ crowd will get its problem solvers?
Old 07-14-2011, 05:30 PM   #56
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
I used the Prius one (the second one pictured on the 1st page). The only difference between it and the one in the 1st picture is the writing/graphics on it.
Thanks ctscott. I have been looking for months and finally found one on eBay.
Just ordered it and will be getting a stalk that came from a 2004-07 Lexus RX330. Hope everything works out.
Total cost is ~$62 shipping included.
-toy
Old 07-15-2011, 03:11 PM   #57
-toy
the seller have more than one? ive been on/off looking w/o a lot of love...
Old 07-15-2011, 03:34 PM   #58
toy_toronto
always toyin'
Drives: 2010 5-Dr
sorry adam, the guy only had one.
I was in the same boat but i'm sure eventually you'll find one.
-toy
Old 07-15-2011, 10:06 PM   #59
Klink10
Klink10's Avatar
Got caught in the rain and finally got to use mine. What a difference.
Old 07-25-2011, 09:50 PM   #60
toy_toronto
always toyin'
Drives: 2010 5-Dr
Just my luck, I couldn't get this stalk to work.
It's for an 04-07 Lexus RX330:
MIST, OFF, LO, HI mode all work normally, but when I set it to "AUTO" nothing happens. One other thing is when I pull up the lever towards me, the windshield washer shoots out but the wipers do not "auto swipe" to clear the washer fluid off the glass.
I guess its either the stalk is defective or it isn't compatible with the Yaris.
-toy
Old 07-25-2011, 09:59 PM   #61
-toy
What's the part number on it?
Old 07-25-2011, 10:28 PM   #62
toy_toronto
always toyin'
Drives: 2010 5-Dr
I'm not sure where the P/N is but here are some numeric markings on the stalk:
-toy
Old 07-25-2011, 10:45 PM   #63
The 0E020 is part of the 84652-0E020 part number. That stalk is for the RX330 that is equipped with "Rain Sensing Wipers", hence the "Auto" mode.
Old 07-25-2011, 11:49 PM   #64
toy_toronto
always toyin'
Drives: 2010 5-Dr
Thanks Scott --is there a way to trick the stalk's rain sensors / make it behave like stock?
-toy
Old 07-26-2011, 07:00 AM   #65
-toy
I am betting yes, but I haven't found an EWD for the auto wipers yet.
Old 07-26-2011, 10:53 AM   #66
Originally Posted by MickZEL View Post
This means that it will fit on the Yaris?
Step by step the delay will work?
The front wiper adjustable delay works by just changing the wiper stalk to one of the part numbers listed on the first page of this thread.
He bought a different one that is from a Lexus which had automatic rain sensing wipers. The automatic one had a sensor on the windshield and an ECU to interpret the sensor data and automatically turn on the wipers.
Old 07-26-2011, 06:17 PM   #67
toy_toronto
always toyin'
Drives: 2010 5-Dr
Thanks for all the info Scott. I should've verified the p/n with the seller first instead just relying on make/description (i.e. rx330)
I think I'm going to start toying around the idea of adding a toggle switch to my rear wiper delay module to control the fronts as well and see how that works out.
p.s. I'll hold on to the rx330 stalk in case you happen to find the ewd for it. thanks again =)
-toy
Old 07-26-2011, 07:51 PM   #68
-toy
I still haven't tracked down the EWD, but I definitely will. One thing I did find out is that with the stalk connected to the Wiper ECU, if you disconnect the rain sensor then the AUTO mode acts like normal intermittent.
Old 07-26-2011, 08:02 PM   #69
toy_toronto
always toyin'
Drives: 2010 5-Dr
So there is hope?
Just let me know what to take apart and I'm on it.
-toy
Old 07-30-2011, 01:30 PM   #70
sickpuppy1
Drives: 2010 Yaris Sedan
Has anyone figured a part number for the sedan? (since I dont need the rear wiper) I have a 2010 I'd love to do this to.
Old 09-02-2011, 10:31 PM   #71
siray06
2006 Silver Yaris LS
Drives: 2006 Yaris hatch
My beef from the day I bought it (Nov 2005) is the rear wiper washer switchology. Why on earth would it be wired to spray only when turning the tip of the stalk in one direction and spray with wiper whne turned against the spring in the other direction and then spring back to continuous wiper. One must then manually turn the wiper off once the window is clear.
I would like to be able to push/turn a switch to spray, then after releasing it, the wiper would run for 3 or 4 sweeps and stop (like almost any front windshield wiper washer switch).
Has anyone come up with a mod to accomplish this?
siray06 is offline   Reply With Quote
Old 09-17-2011, 03:39 PM   #72
Kluak
Drives: 2007 Yaris sedan charcoal
Would a wiper stalk from an 05/06 camry work on the 07 yaris sedan?
Kluak is offline   Reply With Quote
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
