Old 04-07-2010, 12:45 AM   #55
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Originally Posted by H3LlIoN View Post
Bill emailed back and said to expect about a 15hp gain from cam kit alone.
is that whp or just crank?
Old 04-07-2010, 12:45 AM   #56
H3LlIoN
Drives: '09 Yarrrr hatch
no clue, will ask.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 04-09-2010, 10:40 AM   #57
H3LlIoN
and he responded "This reading was at the wheels, dyno’s from one to the other very rarely read the same."
Toyota
Moving Forward
Old 04-09-2010, 03:18 PM   #58
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Originally Posted by rob323 View Post
Any idea where abouts in the rev range the cams are designed to produce power?
This will be important to those that don't have the facility to change their rev limit.
rob323 is offline   Reply With Quote
Old 04-10-2010, 11:34 AM   #59
d1nzfe
Drives: 1NZ-FE
i guess the cams will be sleeping before 5500rpm, so rev cut removal is needed.
d1nzfe is offline   Reply With Quote
Old 04-12-2010, 03:16 PM   #60
H3LlIoN
Alright, asked him for a graph showing just cams, and this is what he sent back...dyno'd at wheels.
Toyota
Moving Forward
Old 04-12-2010, 04:10 PM   #61
red is with the cams?
This is on an xB? with any other mods?
Old 04-12-2010, 04:12 PM   #62
rob323
I assume red is the power and black is the torque. But the graph is pretty meaningless without a stock cam baseline to compare it against. Although at least it is still making power right up to 6000 rpm, so that's a good sign.
Old 04-12-2010, 04:39 PM   #63
looking more closely, it does say hp and torque on the red/black lines.
116 whp / 107 torque is what it says, I think?
does that O2 say 10.35?
Old 04-12-2010, 04:50 PM   #64
H3LlIoN
You guys are killing me. I'm done until my stuff comes in...I'm tired of all the back and forth.
Toyota
Moving Forward
Old 04-12-2010, 04:50 PM   #65
rob323
Yeah, I noticed that too. It's running pig rich, even if not naturally aspirated.
Old 04-12-2010, 04:57 PM   #66
rob323
Sorry about that H3LlIoN, but if someone wants to sell a product, you shouldn't have to milk them for all the relevant information.
Things like duration, lift, spring requirements, adjustable cam gear requirements, baseline and upgrade graphs, engine management mods, dialling in instructions etc should all be readily available and if offered up front, would save the milllion and one question being asked later.
Old 04-12-2010, 05:16 PM   #67
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
What's his email? Just have these guys email him and ask instead of being middleman.
Old 04-12-2010, 05:41 PM   #68
Yoda
Yoda's Avatar
Old 04-13-2010, 05:37 AM   #69
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I want to see a dyno till 7500rpm! My setup is with stock head and since now I make power till 6300rpm for sure. My main interest on these cams is that it can make power within range of 7000rpm - 8000rpm if not they aren't worth the price.
Of course a stock cam baseline versus gude cam will be more reliable to compare
Old 04-13-2010, 09:26 AM   #70
If you don't want the back and forth, don't post until you have the product in hand with some results, or be prepared for a lot of questions -- which is exactly what happened.
Mostly, I think people are excited that SOMEONE finally went for this, period.
Old 04-13-2010, 08:00 PM   #71
H3LlIoN
I know, I know. I'm thinking I'm gonna swap factory airbox back in for the baseline run. If the heads come with cams already installed, then I'm gonna throw it on there and run it again. If not, I'll run the cams separately in my factory heads w/ factory airbox for you guys.
Toyota
Moving Forward
Old 04-13-2010, 10:16 PM   #72
Head Liner / Ink removal bikegerm Cosmetic Modifications (Exterior/Interior) 11 06-23-2009 03:56 PM
Fitting amplifier to Yaris head unit nish1979 In Car Entertainment + Electronics (audio / video / alarm) 3 04-08-2009 06:18 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
