Old 05-14-2010, 12:59 PM   #1
^ 19mm
Old 05-14-2010, 01:20 PM   #2
tomato
tomato's Avatar
^ Sounds like a good choice to me. Thanks
Old 05-14-2010, 01:46 PM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
I decided that I am using my car as a daily driver and am interested in stability, with an increase in handling. The "Iwants" told me to go 23, but the practical side said Barry, you dont "need" it at all, but want it, so why not get all the benefits and save a few bucks. I will probably NEVER throw my car into a corner hard enough to need the 23.
LOL, but there is that part inside that say "owww, shiny......" If this is good, thats better.
But reality set in....I'm still gonna paint it some shade of red though so it goes with my Mediterranean mica sedan,lol
Old 05-14-2010, 03:42 PM   #4
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Better to have it and not need it, then to need it and not have it.
Check out my Build thread:
Old 05-14-2010, 01:56 PM   #5
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
You are not going to believe it! It's awesome!!!!
I got the 19mm too and it's way cool! I could never ever live with out it! I mean drive it (o:
CLA 250, 4MATIC
Old 05-14-2010, 04:14 PM   #6
ddongbap
The sway bar doesn't help you drive. You drive as you drive. It just helps the car do what you want it to do.
Old 05-15-2010, 02:56 PM   #7
britishbikes
Drives: 2008 Yaris Sedan
The swaybar by itself makes a modest difference in handling, but will not affect the hobby horsing the car does at high speeds over undulating pavement. The TRD swaybar is 19 mm. I just put a caliper on it a few seconds ago.
Keep in mind the lowering springs are stiffer and the lower cg they give also add to the roll resistance of the car, the swaybar is about 1/3 of the total effect, it seemed to me. I added the rear springs and swaybar, drove it for a day, then did the shocks the next day and drove it, then the struts and front springs on the last day. Each modification added some roll resistance, the total effect of all parts it quite pronounced.
britishbikes is offline   Reply With Quote
Old 05-21-2010, 12:09 AM   #8
127.0.0.1
partly incorrect. it does help you drive.
it can help reduce fatigue on a long drive
(less demand and focus keeping the car planted on highway, easier cornering)
less fatigue = making you a better more attentive driver
sway bar owners...amirite ?
Old 05-21-2010, 06:18 AM   #9
ddongbap
I don't how a sway bar helps fatigue. Sway bars don't really do much in a straight line.
Old 05-21-2010, 11:11 AM   #10
127.0.0.1
it does nothing in a straight line.
but please, unless you are in Iowa, there is rarely 1 continual mile of highway when you are going exactly straight. you are always lane changing or the road curves, or there are ruts, crosswinds, truck vortex...
the sway bar helps with these minor turns too.
on the highways in NE I already notice:
less steering effort when I am buffeted by 18 wheelers
drag vortex
less steering input for crosswinds
less steering effort over the rain 'humps', and grooves from
'sun baked pavement and rush hour traffic' undulating ruts
and lane changes
so, I stand by what I said: less overall fatigue. your mileage may vary
it takes a lot of mental energy to take long trips in a Yaris HB
because it is squirrelly by default. the fat sway bar in back cuts that
way down.
I already tested my new sway bar in a lot of conditions (it has been installed for 16 hours now) and have 350 miles on it already. 40 in town, 310 on interstate highway and off ramps.
Old 05-20-2010, 09:25 PM   #11
127.0.0.1
just installed 23mm UltraRacing on 2010 Yaris HB
This is such an improvement to everything about driving the car I do not know
where to start other than say GET ONE. It makes cornering awesome and highway
stability vastly improved. My Yaris went from a marshmallow to magical. It now behaves
like a much sportier car. wow I am pretty blown away by the change.
I also went looking for the added harshness hitting asymmetric bumps or
diagonal cracks or bumps. Couldn't find any problem of added harshness. I felt
a more firm stance, but it didn't make the ride harsh at all. I have everything
else stock...springs, shocks, tires all stock. Huge improvement.
Old 05-20-2010, 09:33 PM   #12
glad you like it!
Old 05-20-2010, 09:38 PM   #13
sickpuppy1
Same here with the 19mm, more stability when lane changes, got rid of the wandering on the highway too, bonus! I kinda wish I'd gone with the 23mm now, but very happy with the change.Nicer car to drive. Although I do find myself taking the corners in the subdivision faster than I would have...within reason of course,lol
For what I was trying to acheive, it worked perfectly. 40 minute install taking my time.
Old 05-20-2010, 10:17 PM   #14
detroiter
detroiter's Avatar
My only warning to new owners of the bar is watch your speedo when taking corners. The car feels so much better going around corners that without care, you'll be wearing through tires a bit quicker ;)
Old 05-22-2010, 11:01 AM   #15
127.0.0.1
after further testing....
yes there are certain bumps which are a bit harsher than without the swaybar
there are certain chatter bumps that when hit while cornering the rear end may want
to skip a little
it is now possible to lift the rear inside wheel in corners, but when this happens
A) I am going waaaay too fast to begin with and B) when that wheel lifts it increases traction up front so if you do not panic and just go with the flow, it enhances cornering
I would not recommend the swaybar for a driving novice or common idiot, as it does
allow you to 'get giddy' easily and then you may end up beyond your ability or beyond
the tire capability. but I love the damn thing.
Old 05-22-2010, 12:12 PM   #16
RedRide
RedRide's Avatar
I agrere with your assessment.
As with any car, you have to respect its limitations and lean not to push it beyond it.
Personally, Ihe swaybay revealed just how bad the OEM "Goodear LS" tires are.
Monday, I wiil be getting "Yokohama Avid TRZ" tires installed and hopfully they will allow me to push it a bit further.
BTW, I would not recomed that a "common idiot" be allowed to drive anything on a public road.
Old 05-25-2010, 03:01 PM   #17
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
CTSCOTT... just got back from Saudi Arabia after a 27 hour one way road trip. Drove a Toyota Hiace high roof van. The winds in the deserts can get real nasty. The car kept changing lanes in gusty winds. Anyways, thats why I was not here for the last 10 days.
Sending you the money for the bar tonight! and my TNT account number for shipping. :)
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 05-25-2010, 04:12 PM   #18
syntax
syntax's Avatar
@Falconeer, we are from Saudi arabia ( workin' here anyway) any chance your goin' back here?
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
