Old 01-23-2011, 11:41 AM   #55
Fastskiguy
Drives: Caddie cts, Dodge ram 1500
Doesn't it take the same amount of energy to accelerate the car from 0 to 60 or whatever no matter how fast or slow that acceleration happens? And aren't motors a little more efficient in the rpm range where the torque is highest? And finally, isn't your top efficiency at the lowest speed where you can be in your highest gear? So....wouldn't relatively quick acceleration up to 40mph or wherever you drop into 4th or 5th (depending) be the best? I've heard 3/4 ths of the throttle mentioned before.
What's your take on this?
Joe
Fastskiguy is offline   Reply With Quote
Old 01-23-2011, 06:16 PM   #56
bankrobber
Drives: 2007 Yaris Hatchback
I also have a station close to me with ethanol free gas. I dont think the extra few MPG will be enough to offset the higher price. I dont remember for sure but I believe ethanol free gas here runs 30-40 cents higher per gallon
Old 10-31-2016, 11:16 PM   #57
rabbito
rabbito's Avatar
Originally Posted by osmoq View Post
If there is already a thread about this secifically, can someone point me to it? I looked, but couldn't find one.
From browsing the threads, it seems like peole with manual transmission get really good gas mileage, but I've seen some reports with the automatic that aren't as good. I'm trying to figure out if this is a coincidence based on what I've seen. Can people post whether they have a manual or automatic and their average mpg? Or if anyone knows real-world mpg manual/auto comparison reports, that would be great.
I ask because I was planning on getting a manual, but I'm looking at a specific automatic one, now, and I want to make sure I'll get the max gas mileage because that's one of the main reasons I want the car.
Thanks!
getting 9km per liter in the city...13km+ on the high way..E85s really good on the highway...
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
Old 11-01-2016, 10:43 AM   #58
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
You have a very highly modified car, so I don't think your results are very useful in the context of this particular discussion Apart from that, I love what you've been doing with your Yaris.
Sent from my LG G2 with CM13 using Tapatalk
Old 11-01-2016, 10:47 AM   #59
rabbito
rabbito's Avatar
its not highly modified...i dont even have any stage 2 parts...lol. .😅😅😅
you should see what they do down here in asia...pretty crazy..
Old 11-01-2016, 02:28 PM   #60
tarkus
tarkus's Avatar
No reprogrammed ECU? No funny gasoline? ;-)
Old 11-02-2016, 02:41 AM   #61
rabbito
rabbito's Avatar
cheapes ecu set up ever $300...early timing...thats it..thats like 10hp gain lol...E85 isnt even fuel tuned yet...
all the ecu were sold out except the cheapest ecu which was early timing advance...im waiting for 60mm throttle body to arrive so i can add fuel injection ecu...
the complete piggy back and standalone is way too expensive...😣😣😣
Old 11-02-2016, 08:19 AM   #62
jcboy
Drives: Sedan 07
Joe
Hey Joe, i'm Joe too.
No it doesnt. Physics alone will tell you that you need more force to accelerate a body with the same mass faster.
F=m(a)
Higher a, bigger F.
W=F(d)
Work is directly proportional to Force, hence higher a, more Work.
Work is practically energy, so theres your answer.
Sent from my G9208SS using Tapatalk
Old 11-09-2016, 10:22 PM   #63
sickpuppy1
Drives: 2010 Yaris Sedan
Joe
The basic is this,"A body at rest tends to want to stay at rest and a body in motion tends to want to stay in motion."
If you have a heavy object and you want it to go X mph in a hurry it takes multiple X time more energy to get it there.
If you have to push a car you can lean on it and get it rolling and then walk it forward . Or if your in a hurry and push real hard to get it going NOW it works too but takes alot more energy to do it that way. Its heavy and it doesnt wanna move so it take effort to get it going, much how much effort depends how power you throw at it.
Old 11-10-2016, 07:41 AM   #64
Zaphod
Drives: Big Yellow
When it comes mileage you can't beat a manual gear box. You can throw it into neutral and glide, or keep it in your tallest gear for DFCO, or even just engine brake every chance you get with DFCO to save gas. Of course idle can typically run lower in neutral at a stop with a manual. All of these things mean you have to think preemptively. My wife learned to drive a stick on the Yaris a year ago, and one of the comments she made after getting used to it was that you really tend to think ahead a lot more. As an avid cyclist and motorcyclist I can say that thinking ahead and reacting preemptively is definitely the safer way to go anyway
Sent from my SAMSUNG-SM-J120AZ using Tapatalk
Zaphod is offline   Reply With Quote
Old 11-10-2016, 01:18 PM   #65
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
That would be Trillian?
Unfortunately my wife refuses to learn to drive a manual, so I'm stuck with an automatic. I normally drive the Yaris, and she drives our other car, a Toyota Aurion (that's the V6 Camry here in Australia). It has a long term fuel average display (digital) and a string of LEDs as an instant fuel usage display. At least that has taught her to be a bit more gentle on the throttle....
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-10-2016, 02:54 PM   #66
tarkus
tarkus's Avatar
I often coast in neutral on an auto gearbox. Legality be damned.
Ha ha, good one!
Having two heads means he can avoid accidents by looking two different directions at the same time. Just as long as he doesn't switch on his Yaris' Infinite Improbability Drive
Old 11-10-2016, 03:24 PM   #67
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Have towel. Will travel.
Old 12-09-2016, 01:28 AM   #68
roachslayer
Drives: 2013 SE
I'm a little shocked by the claims in this thread about 30 MPG+ in city, and even 40/70. What?? Either I'm reading this wrong, or I've got quite a different setup.
Here is my situation:
  • 2013 Yaris SE, 4 door
  • Auto Trans (don't laugh, its the only way the wife would go for the Yaris)
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
  • 23 MPG City (according to Yaris computer)
dunno about hwy yet, nor have I calculated my own fill ups to compare with what Yaris thinks - haven't owned it long enough. But assuming the computer is even in the ball park, this is a far cry from what folks are claiming here, no?
roachslayer is offline   Reply With Quote
Old 12-09-2016, 01:31 AM   #69
rabbito
rabbito's Avatar
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
i was getting 11-12km on normal gasoline..octane 91...-_-
now about avg 10km with E85...sometimes more than 12km on the highway...
Old 12-09-2016, 03:04 AM   #70
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
  • 34k miles
  • 85 octane gas
  • 5000 ft elevation
Is this gasoline you are using E85 which is bio ethanol ?
Ethanols consumption is said to be 30% more than normal additional gasolines !
If so then your readings are not bad at all !
KimmoKekki is offline   Reply With Quote
Old 12-09-2016, 09:57 AM   #71
roachslayer
Drives: 2013 SE
EDIT:
No, it's not E85 bio. It's just petrol (which apparently is mixed with maybe 10% ethanol around here). I run 85 octane because that is normal at this altitude. When I lived at sea level the lowest you could buy was 87. (Utah vs Seattle, WA)
Old 12-09-2016, 10:18 AM   #72
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I know that back in the day when this forum was loaded with hyper-milers, many reported upwards of 46-48 mpg. Fifty was the holy grail. Again, that was by applying aggressive hyper-miler techniques.
I have always clocked between 30-33 mpg with my car. That's with over-sized wheels/tires and driving everywhere with a healthy pace. I'm sure I could get closer to 40 mpg with OEM wheels and by taking off my lead shoes.
On Instagram
On Wheelwell
automatic, manual, mpg
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 10:57 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 06:02 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 07:14 PM
