Old 06-19-2010, 02:00 PM   #55
ddongbap
Hey, I have a question about oil...
Me too. Is synthetic better than regular dyno oil? Tamago, can you chime in?
Old 06-19-2010, 06:28 PM   #56
djct_watt
Drives: 2010 NCP91 5spd
Originally Posted by ddongbap View Post
O. Maybe. The gearing is different. Thats all I was getting to.
According to these sites,
http://www.vibratesoftware.com/html_...ear_Ratios.htm
http://www.vehix.com/car-reviews/200...specifications
http://www.yarisworld.com/forums/showthread.php?t=4997
They are exactly the same. Maybe the sites are wrong? The only difference is the final drive (which is easily changed between transmissions). But the gear ratios are the same.
djct_watt is offline   Reply With Quote
Old 06-19-2010, 08:02 PM   #57
Billiam
Drives: '10 White Yaris 4D LB
BTW...rev-matching is just bringing the engine rpm up to match the tranny's output shaft speed...usually when down shifting. It's got nothing to do with "double clutching".
Old 06-19-2010, 09:13 PM   #58
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
after all the drama in this thread, and watching that video on how to shift without using the clutch, I decided to try it. It worked surprisingly well... no grinding, no loud noises, just a slight bump when shifting. I cannot vouch for it's long term reliability, but it seems like a handy skill if you ever need it (hurt leg, clutch problems etc.) Sayuki handled it like a champ.
Old 06-21-2010, 02:20 PM   #59
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
i tried it too and it works without any problem what so ever.
a good thing to know for sure.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 06-21-2010, 06:35 PM   #60
bronsin
bronsin's Avatar
...so who won...the clutchers or the anti clutchers?
Old 06-21-2010, 06:50 PM   #61
sickpuppy1
Drives: 2010 Yaris Sedan
Aamco transmission wins,lol
Old 06-21-2010, 07:07 PM   #62
Astroman
Modded Moderator
Astroman's Avatar
I tried it too and it worked. Wait, I have an auto
Old 06-21-2010, 08:08 PM   #63
CtrlAltDefeat
I ♥ Yaris
lol yea but manuals rule
Old 06-21-2010, 09:36 PM   #64
ddongbap
No. You are totally right. That final drive was different. I just forgot or didn't care. Hahaha
Old 06-21-2010, 09:37 PM   #65
ddongbap
FYI, shifting w/o the clutch pedal is going to ruin your exhaust hanger fluid.
Old 06-21-2010, 11:07 PM   #66
mario98c
mario98c's Avatar
I tried in my sedan and it works!
Old 06-21-2010, 11:10 PM   #67
SAV912
Pirate Yaaaaris
SAV912's Avatar
The argument was never whether or not it works. We knew it worked.
It's a matter of it being worth destroying your synchros. To me, it isn't.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-22-2010, 02:52 AM   #68
ddongbap
-SAV
Can you prove its syncro destroying?
Old 06-22-2010, 06:17 AM   #69
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Its obvious. Sooner or later you will miss the perfect shifting point. And sooner or later you will get the result.
Really, i can't believe people are testing to shift without clutch because of this thread now. Thats ridicolous and a shame. Thread should be deleted before something happens.
Old 06-22-2010, 07:24 AM   #70
sickpuppy1
Unless its done just exactly right, your putting more wear on the synchros. Done just right(usually learned on a non-synchro tranny) its not bad. But on modern car tranny's with synchromesh you may not be 100% right and that when the excess wear comes in. The synchros are there so that you dont have to learn proper technique, and when the clutch is used, they make up the difference in tranny/motor speed under no load situation. When rev matching is done you are for all practical purposes floating the gears like a non synchro tranny. Like I said, when done exactly right,its not bad, its just learning it 100% correct that cause expensive tranny rebuild jobs. Some guys here have apparently learned it well, others will create job security for local repair shops,LOL
Old 06-22-2010, 08:49 AM   #71
bronsin
bronsin's Avatar
None of the transmissions Ive shifted without using the clutch ever had a problem and some of them had 250k+ miles on them and were shifted like that several times a week. YMMV.
Old 06-22-2010, 02:46 PM   #72
ddongbap
Nobody here can give me proof. Only speculation.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
