Old 04-19-2015, 05:55 PM   #55
Sdelliott
Drives: 2008 Toyota Yaris Hatchback
Thank you CTScott. Installed in my 08 hatchback NP.
Sdelliott is offline   Reply With Quote
Old 05-16-2015, 09:37 PM   #56
Secretblend
Drives: 2009 Yaris
CTScott, Thanks for all the help and sending the parts. Got them installed and working great today!
Secretblend is offline   Reply With Quote
Old 06-05-2015, 08:01 PM   #57
Wincharger
Drives: 2007 Yaris
Just did my 07 hatchback, took 2 hours. Only problem, the butt connector was too small for the third wire from the LED and the eye ring was also too small for the bolt shown in the instructions. Other than that I have cruise for $93 with the LED indicator. Awesome considering I've known of and owned a Yaris for about 9 days.
Wincharger is offline   Reply With Quote
Old 08-01-2015, 07:05 AM   #58
Originally Posted by ttpmurphy View Post
Bought the parts from CTScott for a 2011 toyota yaris sedan, power package, automatic. Parts arrived very fast. Worked great! To clarify the guide, the only thing you need for my same car configuration is the control stalk, wire harness (connects cruise control and horn to rest of car), and 2 screws. No need for the D3 stuff like the guide says.
Pics: https://www.dropbox.com/sc/4jufdp0gb...I0EfMPWuFQ-vta
Correct - For a 2011 Sedan with power you do not need to make the D3 connections as they will already be complete.
Old 08-01-2015, 07:08 AM   #59
masterpipo1 - Those are the same pictures (and for some reason you posted them three times) as what you PMed me. As I told you in the PM you are looking in the wrong place for connector D3. Again, as I stated in the PM - Look at my cruise control DIY for simple instructions on how to remove the lower steering column cover to access D3: http://www.yarisworld.com/forums/showthread.php?t=33750
Also, I don't know what that floating relay is for in your pictures, but the twisted bare wire is not a safe thing to have under your dash.
Old 09-16-2015, 06:15 PM   #60
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
Scott...i sent you a pm
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 09-25-2015, 06:49 AM   #61
metalshark
MetalShark
Drives: 2008 Yaris LB
Hi Scott. I installed the Rostra cruise on my 2008 Yaris. I have a 2012 automatic Yaris now. I have a stalk for it. Has anyone done a 2012 yet.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 09-25-2015, 10:46 AM   #62
Yes. Same OEM stalk is used for 2012 as for 2008. Other than the different release of the airbag, there is no difference for 2012 from 09-11. I have the parts required if you are interested.
Old 10-29-2015, 10:19 PM   #63
thomascuba
Drives: Wife's Red Yaris 2007 AT 5D
Dear CTScott;
I would like to install the CC on my wife's 2007 Yaris Base A/T (Hatchback).
Do you still have OEM parts available?
What parts do I need and how much will it cost me? I will prefer not to drill holes on the wheel cover.
Thanks!
thomascuba is offline   Reply With Quote
Old 10-30-2015, 05:31 AM   #64
Originally Posted by thomascuba View Post
Dear CTScott;
Thanks!
Yes. PM sent.
Old 11-11-2015, 08:02 PM   #65
thomascuba
Wiring Missing
Dear CTScott;
I have sent you a PM. I will go ahead and install the CC. But I need to purchase some wires from you.
Thanks Thomascuba.
Old 11-11-2015, 08:16 PM   #66
thomascuba
Missing Wires and Pictures of the Stalk I Got from Friend
Hi CTScott;
Here are the pictures of the Stalk I got.
Thanks, Thomascuba
Old 11-14-2015, 02:33 PM   #67
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
The cruise control light comes on my dash but I cant get it to activate. 2010 LB 5spd MT power package so I alreadt had the clutch switch wiring.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 11-14-2015, 09:59 PM   #68
Did you actually install the clutch switch and is it properly adjusted, where it is fully pressed when the clutch pedal is not touched?
Old 11-15-2015, 08:03 AM   #69
soldout
soldout's Avatar
Yes, the switch wiring was taped up under the dash right above where the switch mounts. Im going to try and re adjust the switch but Im pretty sure the button is fully depressed when my foot is not on the clutch.
Old 11-15-2015, 09:49 AM   #70
I don't recall having sold you the kit, so you may want to check to make sure that the clutch switch is correct (there are two types that operate in the opposite way of each other).
Old 11-15-2015, 10:57 AM   #71
soldout
soldout's Avatar
Silly me, the first time I went to test I forgot to plug in 1 cable for the steering wheel sensor so my traction light was on, doubt CC will activate under those conditions. 2nd time I went out I plugged it in but just went around my neighborhood and wasnt going fast enough. Im my Yaris I think I have to be traveling at least 30mph to activate CC. Thanks for your help Scott.
Old 11-17-2015, 12:24 PM   #72
Eduardo_mty
To install Cruise control on 2016 yaris sedan automatic transmission, i only need
846330821 Cruise control stalk
84633-02020 Cruise control wire
90080-15079 screws
Eduardo_mty is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
