Old 02-13-2007, 09:02 AM   #55
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
Originally Posted by St_G View Post
Got mine in the mail today (Thanks Jimcat, that was amazingly fast service). Now I just have to decide whether I'm up to the task if installing them myself or not.
Its very nice
jimcat is offline   Reply With Quote
Old 02-13-2007, 11:57 AM   #56
St_G
Drives: Black 2007 Yaris Liftback 1.5
No, the shipping on that auction is listed as $20.
Originally Posted by jimcat View Post
Is this USD86.00 included shipping ???
St_G is offline   Reply With Quote
Old 02-13-2007, 01:20 PM   #57
Treyz
~ ambient one ~
Treyz's Avatar
OK after remembering to search for the spray that Yaris TTE JWRC posted .. here is what I finally found ...
http://www.tunerzimage.com/Vans-yell...-lenspaint.htm
Did you pay that much for this bro?
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 02-25-2007, 10:14 PM   #58
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
Finally put on the fogs and the painted oem mudguards. Here's pics:
No DIY, I just followed the install instructions by the first poster. Difference in mine is I hooked up 12v switched wire to the park lights. That way park lights on (or headlights on), I can switch on/off fogs. If park lights off (or headlights off), fogs are also off. I also put the switch near the side mirror controls. That way all the light switches are within reach of my right hand.
as400g33k is offline   Reply With Quote
Old 02-26-2007, 01:06 AM   #59
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Question Install Fog Lights.
Looks good. Quick question? How did you get the wiring from the engine compartment into the cabin? Did you enter trough the firewall? Did you add additional length to the original wiring? Thanks.
rwseattle is offline   Reply With Quote
Old 02-26-2007, 02:48 AM   #60
as400g33k
as400g33k's Avatar
I used the hole that is used by the tube that leads the water out of the aircondtioning system. This hole leads to the engine bay. I cut a small piece out of the rubber to allow the wires through. I placed the wires above the tube so that the water won't drip into the wires. Bear in mind, RHD setup is quite different from LHD so the hole I'm talking about might be in a different place for LHD versions.
Yes. The original wiring was insufficient to set up properly. You'd probably need about several meters of wire:
- about 1.5 meters for the thick black 12v wire connecting to the + battery terminal
- about 2 meters for the thick red 12v wire connecting to the fog lights
- about 2 meters for the thick red switched 12v wire (I used the same thick red ones but you can use thinner ones) to reach the park light wires near the headlight assembly.
- about 1 meter of the ribbed tube to cover the wires.
Instead of splicing wires, I used connectors and a crimper to make it safe and secure.
Old 02-26-2007, 02:49 AM   #61
as400g33k
as400g33k's Avatar
oh and thanks jimcat for the fog lights and thanks violin for the mud guards!
Old 02-26-2007, 02:10 PM   #62
rwseattle
Rwseattle
rwseattle's Avatar
Great. Thank for the feedback.
Old 02-28-2007, 05:54 AM   #63
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Welcome,
so happy to see the result
Old 02-28-2007, 08:09 PM   #64
LoK.
Drives: 3dr YRS
as400g33k, where did you source the +12V parker light wire? Behind the steering column, behind the glovebox, or behind the headlight itself?
Do your fog lights work in all headlight switch positions (i.e. parkers, low beam, high beam)?
LoK. is offline   Reply With Quote
Old 02-28-2007, 09:37 PM   #65
as400g33k
as400g33k's Avatar
behind the headlight itself.
Yes on all.
Old 03-05-2007, 07:22 AM   #66
Speedz
Will work for Yaris...
Speedz's Avatar
Hi just would like to ask where did you get the fog light covers? From toyota dealer or was it included in the package?
Cheers
Speedz is offline   Reply With Quote
Old 03-05-2007, 06:12 PM   #67
as400g33k
as400g33k's Avatar
yep, its included in the package.
Old 03-07-2007, 01:08 PM   #68
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Cheers
Yes, please see PM, thanks
Old 03-12-2007, 09:02 PM   #69
jdf01
Drives: 2007 BlazN Blue hatchy
thanx jimcat, they seem to look great. but, no instructions.... can someone please post up some info on hot to get them in the bumper. my friend will wire them up, but I like doing some things myself. remember, I am a girl I looked under the bumper, do you remove the center section, or what... any help would be appreciated... I think I may also look into the grounding thing! is it a big help??
jdf01 is offline   Reply With Quote
Old 03-13-2007, 11:26 AM   #70
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Look at the first post in this thread. Installing the lights and the trim pieces in the bumper is the easiest part (I did have to remove both front wheels one at a time to get to the space however)...
Talking tiksman into doing my wiring is the hard part!!!
Old 03-13-2007, 01:22 PM   #71
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
That should be the easy part
tiksman is offline   Reply With Quote
Old 03-13-2007, 03:41 PM   #72
Kitt
Kitt's Avatar
QUESTION:
I have mine installed this way:
I purchased the base for the bulbs but when i removed the bumper i found that the factory harness and plug was already there, followed the cable inside the dash and removed from the plug, connected that cable to a relay and from the relay to a fuse and that to a live line to the battery. The relay is powered by the key switched line and then to a switch. Problem is that the line marked in red in the diagram gets hot. Is this normal or what should i do to prevent this???
Kitt
Ebay OEM style fog lights installed fantabulousbaby Cosmetic Modifications (Exterior/Interior) 29 04-28-2009 10:14 AM
EBAY OEM BUMPER FOG LIGHTS Wayside General Yaris / Vitz Discussion 41 01-09-2007 12:52 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
"OEM" fog lights from ebay drell42 Cosmetic Modifications (Exterior/Interior) 5 07-28-2006 09:21 AM
Liftback Fog Lights on eBay Chris07LB General Yaris / Vitz Discussion 8 07-24-2006 07:06 AM
