#55 |
![]() ![]() ![]() Drives: 07 Yaris HB Join Date: Apr 2007
parking light question
there are two sets of parking lights....one is easy to change, directly beside the headlight itself, there is another one that is behind the yellow attached panel on the side...
a) which light bulb is this one? b) anyone have a DIY manual to putting it on?.. cause i looked at it yesterday and was soooc confused with changing that bulb...and is there a way to take that yellow panel out? without ruining my headlight? |
#56 |
Which? the parking light next to the headlight, or behind the ornage reflector?
If behind the reflector, why would you bother changing it at all? Unless your removing the reflector somehow like the oversea's headlights look, its useless to change that bulb.
#57 |
i wanted to know if the eagle eye LEDs on autoillumination.com work...they say 1157 on the bulb code..... and it was under the section 7507.... but im worried it wont fit in. anyone know if it will work?... its the newest LED on the top of that 7507 page...
#58 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I am sitting here comparing my bulbs that I have compliled in my bulb box 7507 is the one you need for the turn signal, the pins are slightly offset while the 1156 for your reverse has straight pins, both bulbs are single contact you need 7507 for you turns, if they don't have what you want you can buy the stuff and make your own or contact them they are very helpful also superbrightleds.com has some great stuff
SPONSORED BY
#59 |
Is 9003 and HB2 and H4 all the same? Just curious because I know of the HB2 and H4 are, but I wasnt for sure about the 9003.
#60 |
Opening this back up. Popped off my map light covers in my sedan and noticed they are not DE3175's. I couldnt get them out but I am sure they are not the same as the dome light. Just noticed that the Hatchback doesnt even have a number for map lights although dont some hatchbacks have the reading lights????
#61 |
Gas Guzzler
The sedan uses 194 wedge bulbs in the map lights. :)
#62 |
Lonesome Cowboy
so does the hatch
SPONSORED BY
#63 |
ONE LOVE...YARiS LOVE!!!
how about led sizes for a 2008 sedan....please?
#64 |
SRacer
awesome! thanks for the info...
very helpful...
"If I go down, I do time. I do real time. I don't know about your other drivers but when I see flashing lights in the mirror I don't stop." - Dominic, Fast & Furious ![]() Learn The Truth about Six Pack Fast! |
#65 |
SRacer
Where did you get this at?
and how is the lighting? would you say it's way better? or the same, but whiter? let me know, i think i might wanna get the one for mine... thanks
#66 | |
USAF_SrA_E-4
I tried to change the turning signal lights puting 2057 insted of 992(7440A) wich are the one for I think it might blown out a fuse but thats my asumption and I tried looking for the fuse but i dont know where they at.any pictures any one? or location?
#67 | |
USAF_SrA_E-4
#68 |
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
Not sure if this has been addresses before on this thread or not, but here goes:
The Climate Control knobs take a Neo Wedge Type B bulb. I discovered that the amber led's from autolumination.com are lighter than the Scion/Toyota amber, but the incandescent amber bulbs they sell are a perfect match. I have an amber scion radio, so this was important to me, as the 08 green bulbs were horrific with the amber radio. |
#69 |
![]() Drives: yaris sedan S VIOS Join Date: Nov 2009
are these the same as 2008 yaris's? and what size bulb is the courtesy side doors?
#70 |
![]() ![]() ![]() Drives: 07 4d yaris and 02 Trans Am Join Date: Jun 2009
i have the same problem. I bought a set of 7443 LEDs. When brakes are on, they work, but when they are suppose to be on during regular night driving, they don't work.
02 T/A AUTO Metalic Silver. 07 Yaris M5. ![]() Best ET is 11.13 @ 120 MPH with 1.47 60FT 11.13 sec vid BurnOut Vid |
#71 |
On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
#72 | |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
Yes, you must get the duel...what they end up doing is linking some of the LEDs that will run off the brake circuit and they some of them will be the parking light circuit.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
| Bulb sizes for all Yaris Models | DJ_SpaRky | Cosmetic Modifications (Exterior/Interior) | 16 | 07-22-2009 10:23 PM |
| Accessory Bulb Types, anyone know? | Ayka | Cosmetic Modifications (Exterior/Interior) | 135 | 04-29-2007 08:33 AM |
