Old 04-11-2012, 03:28 AM   #1
My Tagalog reading skills is horrible (can only understand it when I'm spoken to), but a drop in K&N filter will not give you any performance increase. It's still in the same restrictive intake box with the same carbon trap filter. It's usually only good for being a one time purchase filter that can be reused.
As for water, as long as you don't drive through a flooded area, you should be good. You can also get a hydroshield to prevent any drops of water from being sucked in (won't protect you if you try to drive through a flooded road). Mine works great. I don't bother to "bag" my filter when I wash my car.
Old 04-11-2012, 06:33 AM   #2
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
1.3L and 1.5L is different
in addition to above..
The header for 1.3L 2nz-fe yaris is not compatible with the one from US. US header are for 1.5L 1nz-fe in majority.
Unless, you have the yaris 1.5L sporty edition here in ksa, then its a bolt-on.
I don't know why in these country, they used to sell small displacement engines cars eventhough the gas is cheaper than water
ricepower is offline   Reply With Quote
Old 04-12-2012, 01:17 AM   #3
mikedizzle
Drives: 2010 toyota yaris sedan
what kind of intake you have?
mikedizzle is offline   Reply With Quote
Old 04-12-2012, 01:28 AM   #4
Me? I have the K&N SRI (Typhoon). I just wrapped it with some heat reflective material since the pipe is black and made of aluminum (which gets heat soaked easily).
The pipe wrapped:
Old 04-11-2012, 02:22 PM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
@Kaotic can you share the website where you got the hydroshield K&N
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 04-11-2012, 03:26 PM   #6
Find your filters measurements and look up the part number here: http://www.knfilters.com/search/wrap.aspx
Be sure you are looking under drycharger and not precharger filters/wraps.
Then you can find that K&N part number on Amazon: http://www.amazon.com/s/ref=nb_sb_ss...ry%2Caps%2C302
Old 04-12-2012, 01:30 AM   #7
Yes, I did notice a difference if how hot it feels. Before the wrap, touching the pipe was sometimes unbearable. I can now keep my hand on the pipe after I wrapped it.
performance-wise? Not really sure since I've always had HEAVY rims. lol
Old 04-12-2012, 02:25 AM   #8
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
i got mine from http://www.outerwearsracing.com/ They're all pretty much the same thing.. just branded differently.. got mine from 10yrs ago for my civic and still works great!
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 04-12-2012, 02:34 AM   #9
barebonedvitz
what's great about these guys is that they can make custom wraps!
I believe this will be beneficial for our radiators, evaporators and for some, intercoolers... so those poor bugs don't get stuck in between the fins and die a horrid death...
Old 04-18-2012, 10:15 AM   #10
syntax
syntax's Avatar
@ kaotic thanks for the clarifications, im sure we take notes on this one
Old 04-24-2012, 02:53 AM   #11
atvtorres
Drives: yaris yx 2009
Tanong lang po kung pwede to sa yaris 1.3L(2nzfe)? Thanks!
http://www.ebay.com/itm/290400046694...#ht_5655wt_905
atvtorres is offline   Reply With Quote
Old 04-24-2012, 03:25 AM   #12
ricepower
ricepower's Avatar
YES. It's bolt-on or plug n play to our 1.3L.
PM kiel12 for the experiences.
Old 04-24-2012, 06:07 AM   #13
atvtorres
Thanks sa info!
Old 05-05-2012, 09:51 AM   #14
levanz2007
levanz2007's Avatar
Drives: 2007 toyota avanza G m/t
your mod is cool dude!!!
levanz2007 is offline   Reply With Quote
Old 05-08-2012, 04:30 PM   #15
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
PWede ba ito sa Toyota Echo 2005 1.3 engine....
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 05-16-2012, 03:14 AM   #16
syntax
syntax's Avatar
pwede ang alin pre? dami mods ni kiel eh hehehhhe
Old 05-20-2012, 02:59 AM   #17
BoyMalambing
yung Air intake kit na naka-install.... Kapareho pala ng Echo and Toyota XA sa lay-out ng Air Filter.
Old 05-20-2012, 03:48 AM   #18
syntax
syntax's Avatar
yup magkapareho lang ang layout
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
Weapon-r sheet metal intakes 1/2 off (almost) H3LlIoN Forced Induction Forum 5 11-27-2010 12:21 AM
aFe intakes in stock! cali yaris Micro Image 66 02-11-2010 04:58 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
