Old 04-21-2013, 08:10 PM   #55
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
anyone drill a couple of small holes in the bottom of the AFE airbox for drainage?
Just get a air filter cover , i have used one and its fantastic keeps water off and dirt too with out performance loss and its like 20 bucks.cover 2.jpg
Old 04-22-2013, 02:42 PM   #56
attickt
attickt's Avatar
Drives: 2009 toyota yaris S/JDM Vitz
do any of you have any pics of the white spacers you speak of, i have been getting check engine light on and off ever since installation of my AFE....im sure i can figure out these spacers but a pic would help....
I yell out YARIS! every time i see one, like its a game!
yaris+induction= baby supra!
Originally Posted by brg88tx View Post
i can just hear the rednecks behind me grumbling "g-damn fag car" before they pass me.
attickt is offline   Reply With Quote
Old 04-22-2013, 07:59 PM   #57
nookandcrannycar
That quote from brg88tx is hilarious.
Old 04-25-2013, 02:02 PM   #58
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I don't have a picture but I can describe them. There is quantity of two of them. They are cylinders. I believe they are each a little less than 1 cm in diameter. They are white in color. They are probably less than a cm long also. The location that the MAF instructions tells you to put them in would be surrounding the screws that hold the MAF sensor in place, so they go in between the sensor and the hard black tube that came with the AFE system right where the screw holes are.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 04-25-2013, 02:07 PM   #59
bad
Winterizing
bad's Avatar
If my MAF sensor is truly bad, and I replaced it with a new good sensor, how long should it take for the CEL to turn off?
If I am currently driving with a bad MAF sensor, what kind of negative side effects can that have on my car?
If I am currently driving with an air intake system that is faulty, maybe letting air in somewhere besides through the filter, what kind of negative side effects can that have on my car?
Thanks.
33.7 mpg in PA
Old 04-25-2013, 02:15 PM   #60
YarisSedan
Drives: 08 Yaris Sedan
-depending on how many miles you drive it should take about a week once the computer detects the fault is gone after 2 drive cycles
-loss of power, fuel economy, can potentially damage catalytic converter if driven long term, typically you will feel a difference before this happens.
-See above typically reduction in fuel economy, 02 sensor will pick up the extra oxygen and attempt to correct the vehicle by dumping more fuel in the cylinders leading to incomplete combustion so reduction in fuel economy the unburned fuel will get cleaned up by the cat but long term can cause it to fail typically if driven for many many months this way.
Thanks.
Old 04-25-2013, 02:45 PM   #61
bad
Winterizing
bad's Avatar
thanks alot YarisSedan
33.7 mpg in PA
Old 04-25-2013, 03:15 PM   #62
bad
Winterizing
bad's Avatar
I am going to put my original air intake system back in before I buy a new MAF sensor.
Do you guys think I should take off the negative battery terminal for a couple minutes and see if the CEL comes back on, or do you think I should not take off the negative battery terminal and wait and see if it clears itself?
33.7 mpg in PA
Old 04-25-2013, 04:38 PM   #63
djhuddy2442
djhuddy2442's Avatar
Drives: 2008 toyota yaris hatchback
i replaced my seal gasket to a bigger one to make sure it was snug and maybe disconnect your neg terminal for a couple mins that could have thrown the check engine light
djhuddy2442 is offline   Reply With Quote
Old 04-25-2013, 05:25 PM   #64
bad
Winterizing
bad's Avatar
I just put the original intake back on and will remove neg term for a little while. then will drive for a month to see if CEL comes back on. If not would you agree the MAF is fine?
33.7 mpg in PA
Old 04-25-2013, 05:47 PM   #65
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That's an excellent test...
...as it will definitively indicate whether the issue is with the intake itself or with the MAF. Do keep me posted as to the results.
Old 04-25-2013, 08:28 PM   #66
bad
Winterizing
bad's Avatar
OK I will. 10 miles so far and no CEL light...
33.7 mpg in PA
Old 06-09-2013, 12:13 PM   #67
bad
Winterizing
bad's Avatar
My OEM air intake system is not causing the CEL to come on and my gas milage seems to have improved but it hasn't been long enough to say for certain. Has anyone ever sprayed ether or something else around their air intake system to try to find a leak?
33.7 mpg in PA
Old 02-16-2014, 10:02 AM   #68
YarMatey420
Drives: Silver 08 2DR Hatch
Afe intake on 2008 yaris LB
I already purchased the afe intake from garm at microimage , but the instructions that came with it said that the intake is for 2006-2007 yaris. I have a 2008 . Will it still fit ?
YarMatey420 is offline   Reply With Quote
Old 02-16-2014, 10:20 AM   #69
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yes...should fit even in the 2012 up
Old 11-15-2014, 10:53 PM   #70
268i
Drives: 06' Yaris 1.3l
"Imported from New Zealand" Omg. I need this. But doesn't it seem somewhat impractical to buy something from USA and have it shipped back to the country of origin :P
268i is offline   Reply With Quote
afe power cold air intake, air filter, air intake, check engine light, mpg
Check Engine and Traction Control Light On limey163 DIY / Maintenance / Service 21 07-14-2013 03:03 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
AFE cai intake....pros/cons severous01 Performance Modifications 21 06-30-2009 02:55 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
