Old 04-07-2013, 12:36 PM   #1
jetblast
Drives: Gen 1 XB
With that we'd be hangin' out in the FRS compression ratio arena.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 04-07-2013, 11:15 PM   #2
Viperoni
Drives: 2005 Toyota Echo
Or pretty much any other direct injection gas motors...
13:1 is nothing unusual if you have cams though.
2006 Saturn Ion Redline
Old 04-08-2013, 03:04 PM   #3
I can only assume the differences in the crankshaft are due to the differences in the weight of the pistons and the operating speed of the 1NZ-FXE vs. the 1NZ-FE. But all the other differences make sense.
Old 04-08-2013, 08:28 PM   #4
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
I bet it has to do with how the generator attaches to the crank (where the flywheel would normally sit).
Old 04-09-2013, 12:37 AM   #5
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Good point...
JustDidIt is offline   Reply With Quote
Old 04-08-2013, 08:34 PM   #6
Yeah, that makes more sense.
Old 04-09-2013, 12:23 PM   #7
I wonder how much a crankshaft would cost so I could compare them. I have a 1NZ-FE one sitting here.
Old 04-09-2013, 01:10 PM   #8
fast2882
Drives: Toyota Yaris 2012
so, what should i do then in order to swap the 1nz-fxe piston into my 1nz-fe?
fast2882 is offline   Reply With Quote
Old 04-09-2013, 01:14 PM   #9
fast2882
what i know is : 1nz-fxe has a greater effective expansion than compression—making it simulated Atkinson cycle, rather than the conventional Otto cycle. That difference makes the cam timing and lift different ( i think ). So, if we use 1nz-fe cam, which mean the ignition timing is more advance than the 1nz-fxe cam, do they still have a clearance between top of the piston and the valve?
Old 04-09-2013, 02:46 PM   #10
JustDidIt
JustDidIt's Avatar
THAT is still one of the bigger questions... prob best to clay the piston and find out b4 firing it up. Try it at your own risk...
....but I'm sure it would be fine....
Old 04-10-2013, 03:23 AM   #11
nanoss
Drives: Toyota yaris sedan
For those who think that i blewup the engine guess what it running good no problem just got the valve stems replaced to stop oil consume.... since august the engine has run like oem no problems like i said there no modification needed only swap your pistons for the prius one and u are set... i dont have the time to go to the dyno yet but i think the gains are 8whp only the piston the compression is 253 253 260 250 u are thinking that mod for only 8whp well i am trying to find better camshaft with more valve opening duration in order to gain the max hp with the compression.... some people said. To me that the scion xb exhaust cams haver more duration than all the 1nz fe engines
nanoss is offline   Reply With Quote
Old 04-10-2013, 12:25 PM   #12
Flipper_1938
When VVT kicks in, what does it actually change? Does it do anything for lift or duration? or does it just advance/retard the camshafts?
Would causing the solenoid to fire sooner make the motor think it had more cam?
Old 04-10-2013, 12:54 PM   #13
JustDidIt
JustDidIt's Avatar
Yes, if you don't mind, tell us more about this idea.
Old 04-10-2013, 03:29 AM   #14
nanoss
The moods in my car are thes 2 1/4 magnaflow freflow 2" catless exhaust pipe thinking of making 2 1/4 downpipe.... echo semi header, ebay cai, 3" velocity apex neo afc and prius pistons....
Old 04-10-2013, 11:19 AM   #15
JustDidIt
JustDidIt's Avatar
For those who think that i blewup the engine guess what it running good no problem just got the valve stems replaced to stop oil consume.... since august the engine has run like oem no problems like i said there no modification needed only swap your pistons for the prius one and u are set... i dont have the time to go to the dyno yet but i think the gains are 8whp only the piston the compression is 253 253 260 250 u are thinking that mod for only 8whp well i am trying to find better camshaft with more valve opening duration in order to gain the max hp with the compression.... some people said. To me that the scion xb exhaust cams haver more duration than all the 1nz fe engines. The moods in my car are thes 2 1/4 magnaflow freflow 2" catless exhaust pipe thinking of making 2 1/4 downpipe.... echo semi header, ebay cai, 3" velocity apex neo afc and prius pistons....
Good to hear back from you! Thanks for the follow up.
Old 04-10-2013, 07:10 AM   #16
8whp not too bad considering its just a compression bump. That IS about 8% gain (though I do realize you're guessing)
Old 04-10-2013, 01:02 PM   #17
fast2882
why don't you try to use higher octane or racing fuel like VP racing, and have your ignition timing and Air fuel ratio retune by piggyback ECU first? i think with this two modification, you'll gain some additional HP and torque
Old 04-10-2013, 01:03 PM   #18
fast2882
for racing camshaft, Jun auto already release a higher lift and timing camshaft, in indonesia, we use these cam when we race.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
