Old 12-05-2012, 06:43 PM   #37
bambam28
Drives: Yaris Hatchback 2012 SE
Agreed the front wiper is not a trouble, but the rear one is just worthless weight :)
bambam28 is offline   Reply With Quote
Old 12-05-2012, 07:28 PM   #38
nookandcrannycar
Old 12-05-2012, 11:47 PM   #39
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Originally Posted by nookandcrannycar View Post
Thanks, good to know, especially from you. As a fellow picky negotiator/strong opinion holder, I would think you would critique this safety aspect with the same mindset I would.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 12-06-2012, 02:56 AM   #40
shrek
Drives: 2012 5dr Manual Yaris
I like the single wiper, but trying to find a cheap alternative to replacing the full wiper with just a slide in insert.
Also, going to put a longer rear wiper on as there is room for it.
shrek is offline   Reply With Quote
Old 12-06-2012, 03:51 PM   #41
bambam28
Let me know how the bigger wiper on the back works to see if I do it and then stop saying that is worthless weight :D
Old 12-08-2012, 07:18 PM   #42
imike929
Drives: '13 Super White SE
Yes what size wiper will fit in the back? The current is only 12"!
imike929 is offline   Reply With Quote
Old 12-10-2012, 10:52 PM   #43
imike929
Absolute, was wondering if you could provide video/pic instructions as to how you got that chrome trim piece off?
Old 12-10-2012, 11:16 PM   #44
Absolutely Red 12
Asshole
Remove the inside hatch panel with a clip removal tool.
http://www.amazon.com/Automotive-Mol...moval+tool+set
Remove screws and clips holding the trim piece on, from the insode!!
Old 12-10-2012, 11:24 PM   #45
imike929
Im sorry if this is a dumb question lol....do this with hatch open or closed?
Old 12-10-2012, 11:42 PM   #46
imike929
And with those tools (or a prybar) the hatch panel just pops off and back on when you're done?
Old 12-11-2012, 12:16 AM   #47
Absolutely Red 12
Asshole
Open the hatch, look up, remove the panel.
Looking up inside the cavity, find 4 to 6 bolts sticking through, along the imaginary line of the trim.
Remove nuts from bolts. The trim is now held on by two clips on either end, using needle nose pliers, from the inside, squeeze clips, to release.
As I stated earlier, you WILL NEED new sealing washers, between the trim, and hatch, on the through bolts.
I bought very thin 1/4" rubber washers at Lowes.
Old 12-11-2012, 12:17 AM   #48
Absolutely Red 12
Asshole
The hatch cover removes, and installs just like a door panel.
Dont use a metal panel remover, use a nylon one, else you will scratch the paint.
Old 12-11-2012, 12:20 AM   #49
imike929
thanks buddy, i'll try it out!
Old 12-17-2012, 06:32 PM   #50
imike929
Dumb question, but is that trim piece actually metal that could maybe be powder coated? Or is it just plastic like the badges/emblems?
Old 12-17-2012, 11:47 PM   #51
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
it's plastic.
b20vteg is offline   Reply With Quote
Old 12-18-2012, 10:58 AM   #52
Absolutely Red 12
Asshole
Originally Posted by b20vteg View Post
it's plastic.
^ What he said.
Chrome plastic, not plated. Just scuff it, spray adhesion promoter, 2 coats of primer, 3 coats of base, 3 coats of clear.
If youre car is red, I recommend pink primer.
Old 01-24-2013, 10:21 AM   #53
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I prefer a monocolor scheme on cars, but I find myself actually tolerating that one bit of chrome. Perhaps this is related to my overall satisfaction with the car itself. Quirky, yet a blast for a daily driver.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
2012 trim piece question Shroomster Third Gen Yaris General Discussion 12 09-05-2012 12:08 PM
2nd-Gen Yaris hatch at San Diego Comic Con 2012 Mitey Photo-Video-Media Gallery 4 07-17-2012 09:21 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
First Drive: 2012 Ford Focus Kal-El Off-topic / Other Cars / Everything else Discussions 18 02-25-2011 05:41 PM
Yaris sedan - how to remove chrome trim on trunk? Herbicidal Cosmetic Modifications (Exterior/Interior) 29 11-01-2009 11:05 PM
