Old 09-28-2007, 11:11 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by c-one yaris View Post
ok. now what's the widest i can go on 15", 16", and 17"?? better yet, is there an official tire guide for lowered yaris'?? that be a lot easier. Thanks Black Yaris!
That answer depends on wheel width and offset.
If you post those specs, we can probably help you with tire sizing.
Old 09-28-2007, 11:13 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
true... I was just giving general sizing options
Old 10-21-2008, 08:36 AM   #3
Energiser
Oh, Shiny...
Energiser's Avatar
Drives: 2005 Toyota Yaris YR
Hey guys,
I'm looking at getting some new wheels for my Yaris. It's been a fairly lengthy process with me finding something I like, then finding it isn't appropriate for one reason or another (usually associated to my expensive taste, and the fact I'm trying to get nice 16" wheels in Australia...)
The wheels I'm looking into at the moment are Enkei SC03's, 16" x 7", pcd of 4x100, and am planning to put 205/50/R16 rubber on them. The problem comes when I'm trying to figure out the offset.
From what I can find online, these wheels come in a +35 variety, and a +43 variety. I've noticed a few people on the forums with slightly larger offset on the front as opposed to the back (say +42 on front, +36 on back) and was wondering if it's worth going to that sort of trouble, or if I'm better off going +43 all around?
I haven't gone looking for quotes on these yet, wanted to finalise what I want before I start... so for all I know, these could be more expensive than I'm willing to pay, too.
Regards,
Energiser
Edit: Where on the Yaris is the tyre placard generally located? I can find a sticker inside the glove box which mentions my stock 14 x 5 steel wheels, but I thought they were supposed to list the range of wheels suitable for the car. Or at least the range available from the dealership as options (which are 15 x 6 here in Australia).
Energiser is offline   Reply With Quote
Old 11-14-2008, 05:48 PM   #4
darthbauer
Not really here...
darthbauer's Avatar
So will these fit and rub?
17x7.5 offset is 45 wheel with 215/40 rubber?
Liberate Tutemet Ex Infernis.
Old 09-28-2007, 11:09 AM   #5
Black Yaris
der Zeck
widest you realy want to go on the front is a 205 when you are lowered, you can go 215 in the rear... you want to run staggard or not?
here are some recs to run all the way around
15-205/50, 205/55
16-205/50
17-205/40, 205/45
Old 10-21-2008, 01:19 PM   #6
kimona
kimona's Avatar
ET43FR//ET35RR would make a great staggered offset with 205/50 rubber. I run a set of 45/38's on mine with 205's and the fitment is excellent. I'm not a fan of tyre rotation, so that's not an issue for me... but, it may be a consideration for you.
Old 11-03-2008, 06:24 PM   #7
arunto
arunto's Avatar
Drives: 2008 Yaris LB
Will 15x6.5" 38mm offset with 195/55/15's with Tanabe DF's rub?
arunto is offline   Reply With Quote
Old 11-10-2008, 05:30 PM   #8
mchllp925
Darrin
mchllp925's Avatar
Drives: 2008 yaris le h/b
Hello everyone.
So for clarification...I use racing discs over my 185/60R15's allseasons, can I put 205/50R15's on my Yaris without any issues such as rubbing? I do not intend to lower my car.
I just want wider tires. And if so, do you think it would throw off the speedometer?
mchllp925 is offline   Reply With Quote
Old 11-10-2008, 06:36 PM   #9
kimona
kimona's Avatar
Originally Posted by mchllp925 View Post
Hello everyone.
If you're not lowering, then install 205/55/15's with no worries. 205/50/15's are too short with stock suspension. Your speedo will be fine.
Old 11-10-2008, 08:05 PM   #10
mchllp925
Darrin
mchllp925's Avatar
Thanks for the quick reply Kimona.
Appreciate it!
Darrin
Old 11-10-2008, 07:19 PM   #11
Black Yaris
der Zeck
oh shit, i almost forgot about this thread.... I will do some updating to the first post
Kimona, feel free to make any edits you see fit
Old 11-14-2008, 06:48 PM   #12
kimona
kimona's Avatar
Okay. I'll take a peek later.
EDIT: I've made a few changes to the wheel/tyre guide. I'll get back to it another time and update tyre size recommendations.
Old 11-14-2008, 06:55 PM   #13
darthbauer
Not really here...
darthbauer's Avatar
Right now I am not lowered. If I do lower I will go with the TRD sportivo set up with the shocks and springs.
Old 11-14-2008, 07:22 PM   #14
kimona
kimona's Avatar
17x7.5 ET45, 215/40 rubber. Should be okay with TRD drop.
Old 11-17-2008, 09:31 PM   #15
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
u wont rub with that. any takers for my question above?
Old 11-17-2008, 10:33 PM   #16
kimona
kimona's Avatar
Here you go...777:
"...the one of a kind 15x8 has a 5 inch lip! This is done with a negative 27 offset, and can only fit the most extreme widebody fitments."
Old 11-24-2008, 06:39 PM   #17
DJexor
Drives: AE86´85 | Yaris T-sport '01
Hello there, I see all sizes for a new Yaris. Does anyone know what the max offset would be on an 2001 TS model (oldest model)? Would prefere 17". Thinking of Work CR Kai 17x7 off +42
DJexor is offline   Reply With Quote
Old 11-24-2008, 07:30 PM   #18
kimona
kimona's Avatar
Don't know what the min/max wheel/tyre fitments are for the 2001 model, but I believe that 17x7, ET42 should work... no worries.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
