#1 |
The Beautification of Car
how about MPG?
#3 |
![]() ![]() Drives: Yaris 3Door YRX Join Date: Mar 2007
... ... AWESOME Now have ZPI come over to the gold coast so I can get one of their kits!!! = P |
#4 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
nice speakerman, 2 things, engine light? and not so much a bolt on when welding is required....
#5 |
the need for the welding was because of the difference in body styles between the liftback and sedan I am sure. So for the remaining customers I would bet it is a bolt on process, seeing as they have now fitted it to a sedan and a liftback.
#6 |
Down With the Sickness
yea why is the cel on? and whats the code
Strength - Determination - Merciless - Forever |
#7 |
well for one the front oxygen sensor has been removed as kenny has said (i believe in the other post) another could possibly be for the larger injectors.
#8 |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: May 2007
Ok, so is this an Auto transmission yaris? The Launch from the vid was pretty mild. 0-60 time looked about 8 second, but at 182 FWHP in a 2200 lbs car it should be sub-6 with a manual. BOV sounds great and the exhaust note is TUNERIFFIC! Now, about the first 25 seconds of fumbling and lense cleaning ;)
I can't wait to get mine!! Last edited by Vanderkitten; 05-11-2007 at 03:23 AM. Reason: TYPOS!!! |
#9 | |
The biggest thing with the launch, though, is getting 105lbs of wheel spinning... lighter wheels I would imagine would help a ton there. |
#10 | |
#11 |
still not sold on the idea of turbo, especially with stock internals, w8n for better internal parts to come out if not 3.5k can get me a jdm 2zz w/tranny
#12 |
#13 |
Honestly, 190HP is not a big deal for the internals on these motors. I can imagine that if you went hi-comp on the pistons you might want to look into better connecting rods, like you would with any motor, or just have the stockers balanced at least. VW's get 240+ out of a 1.8T all day long with a stock K03 turbo, chip, intake and exhaust with stock parts. Those motors are 10:1 compression as well, so it's fairly hi-comp for a turbo motor!
Beyond a good ZPI clutch and limited slip diff and bigger brakes, you're probably set. If you wanted to pump a 30psi Turbo, Nos and hi-comp pistons you might want to look for some new internals... or a different car. =)
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass! Many thanks to our sponsors: Weapon-R http://weapon-r.com Megan Racing http://www.meganracing.com Les Schwab Tires http://www.lesschwab.com 317 graphics http://www.317graphics.com |
#14 | |
Novice Hypermiler
#15 |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
Guy... the Yaris has a 10.5:1 compression ratio. Stock. And the rods a built like toothpicks.
I'm not sure you can compare a factory-turboed engine made for a performance(ish) car with an engine built to be light and for fuel economy. Apples and oranges.
2006 Red Blitzed RS 5-door |
#16 | |
I'm sure it shortens the life of the motor, but we are talkin a motor that would run until eternity :) |
#17 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
Pimpin....
Baggs are next....
#18 |
Drives: AE86, UZZ30 Join Date: May 2007
what turbo manifold did you use? one for a xB or xA?
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
| Vitz Rs turbo vs U.S. Yaris add turbo? | weaponrcamry | Performance Modifications | 18 | 08-09-2006 08:45 PM |
