Old 04-23-2007, 09:10 PM   #1
wagoneer
wagoneer's Avatar
Drives: 07 Liftback - Red
I seriously considered it. It is perfect.
However, I noticed that the windows on the driver side were fogging up the other day while driving in the rain, even with the vent pointed that way. I can't imagine how bad it would be without an air vent.
DRL removed
rear debadged
Tachometer installed
Mudguards installed
Rear Bumper Guard installed
FUTURE = Fog Lights, arm rest, RS spoiler, cruise, black 17" wheels
wagoneer is offline   Reply With Quote
Old 04-23-2007, 09:19 PM   #2
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
true. o so very true. I noticed that the windows tend to fog up relatively fast compared to other cars.
Old 05-01-2007, 03:13 AM   #3
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
how about in the compartment? :P just in case u wanted to go sleeper :P
barebonedvitz is offline   Reply With Quote
Old 05-15-2007, 11:57 PM   #4
KSIbucky
KSIbucky's Avatar
where did you hook up the illumination wire and HOW did you do
im new to the hole wiring thing and a step by step diy for just hook the two wires would be cool
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 05-16-2007, 08:21 AM   #5
joey1320
joey1320's Avatar
Drives: Yaris LB
Attach the tachometer "Illumination" (yellow wire) to the other add a fuse circuit. Install this add a circuit at terminal 8 or 9 (the red 10amp circuit across from #24 location). This will ensure that the tachometer "remembers" what color it was last on after you shut the car off.
Old 05-16-2007, 10:49 PM   #6
KSIbucky
KSIbucky's Avatar
how do you find a terminal # and how do you add a number go to page 11
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 05-19-2007, 04:20 PM   #7
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Thanks for the DIY!
just installed my glowshift 7 color tach.
gotta love wire testers :)
posting pics after i make the wires invisible.
woot woot
yariSB86 is offline   Reply With Quote
Old 05-29-2007, 07:35 AM   #8
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
I installed my Speedhut gauge this weekend with the help of this DIY. However, my gauge has two Illumination wires and two grounds. I guess one for the gauge and one for the shift LED. The LED's light up fine and so does the needle, but the backlight is very very dim. Any advice?
Ran Kizama is offline   Reply With Quote
Old 05-29-2007, 04:56 PM   #9
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Bumpity Help Me!
Old 06-01-2007, 09:36 PM   #10
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
Originally Posted by Ran Kizama View Post
Bumpity Help Me!
i just got my speedhut guage in the mail today im installing it tomorrow. ill let you know what i find
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 06-04-2007, 12:07 AM   #11
glowshift coming next week, will post install pics also. I want mine on the other side of the steering wheel if possible though, that's where I'm used to looking on my other cars.
Old 06-04-2007, 07:40 AM   #12
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
you know i was just thinking that and i had a thread posted for it under cosmetics and in the a-pillar guages thread
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 06-06-2007, 07:15 PM   #13
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Yes, post pic. I'm interested in the speedhut tach.
rwseattle is offline   Reply With Quote
Old 08-02-2007, 06:46 PM   #14
kapo
Argentina Presente!
Drives: 07 White LB
one small question.. how do you guys attached the green tach wire? I know where it goes, but how is the best way to attach it? cut the blue-green wire from the ECU, then attaching all 3 ends together?
thanks!
kapo is offline   Reply With Quote
Old 08-02-2007, 07:43 PM   #15
drifto
drifto's Avatar
best way is to soldier it/ shrink wrap together, but they also sell 3-way t-type crimp connectors that will work good too. whatever you prefer. just dont twist it and elec. tape it
07 Yaris LB 5spd
Old 08-04-2007, 12:24 PM   #16
kapo
Argentina Presente!
Drives: 07 White LB
well.. i followed the instructions and the tach is not working.. one stupid question, the fuse (#24) i took from the box i need to attach it to the "add a fuse".. right? (i did it), is any special direction the fuse goes?
another question.. for the ground I needed to add some wire... but the wire is thicker that the tach black wire... that is a problem?
I tried everything... and nothing, the needle doesnt move, and no ilumination also.. Im using the glowshift. Any has this problem?
Old 08-04-2007, 01:01 PM   #17
I've sent one glowshift back already, but yours is probably not the unit. Shouldn't be a problem with your ground wire size.
Have you hooked up 12v to the tach to make sure it lights up?
Do you have a way of testing a wire to see if there's juice in it?
Old 08-04-2007, 01:11 PM   #18
kapo
Argentina Presente!
Drives: 07 White LB
Red wire in #24.. with the 7.5 amp.
Yellow wire in #9 with the 10 amp.
* what happen if i do a wire jump in the "add a fuse" instead of puting the fuse?
i guess i will need to buy a tester to see what is going on..
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
