Old 07-06-2009, 11:31 AM   #55
Astroman
Modded Moderator
Astroman's Avatar
I had mine out for a while (made new ones), and had a musty smell when using the AC. Now that I have a new filter in, the smell is gone.
Old 07-06-2009, 12:30 PM   #56
PatrickJohnson
Drives: 2008 Yaris LB
the filter is post-ac, it only filters the air coming out of the blower of the ac unit. as such, the unit's operation is unaffected by leaving it out, it just means that whatever allergens/dust your external ac air intake suck in will end up in some amount inside your cabin. with the filter in place, the dust that makes it to your cabin is greatly reduced, and with an allergen rated filter you can cut down on pollen and the like. helps allergies while driving.
PatrickJohnson is offline   Reply With Quote
Old 07-15-2009, 09:52 PM   #57
LilBlue
Drives: 08 2dr
Hey, found this site today. It's amazing what all you guys do - providing so much information. I was looking for a new cabin filter at a local parts store, couldn't find the part number in the book. A quick goog brought me here, and after just a few minutes I had discovered that the cheap skates never even put one in from the get go, made 4 filters myself, installed one, and took most of the dash trim out just to look around with a flashlight and see what I could see.
Awesome.
Oh, and I only got 4 filters 'cuz my house A/C filters are 20x20 so that's what I happened to have laying around. Could -almost- get 6 out of it, but so what. I get the nice allergen filters in bulk so the final cost for 4 was under $1 each anyway.
Again, awesome. Thank you so much for this.
One tip that might help somebody else - the 3/4" thick house A/C filter can be squished down if you have extra like I did. As long as you cut your duct tape to the right length and hold the pleats when you are "assembling", then you'll get more surface area in there and you still end up with the target size. As far as getting it into the fan box, it's not a perfect fit and I expect some air will find it's way around. Maybe a high-performance version of this idea would be to make a nice well-fitting/sealing "tray" that replaceable filters could be shoved in there with. For now I am quite happy with my cut up filter and tape. It is vastly better than _nothing_...
LilBlue is offline   Reply With Quote
Old 07-15-2009, 10:22 PM   #58
BailOut
Steals terrorist's lunch
BailOut's Avatar
Hi LilBlue,
Welcome to YarisWorld. I'm glad you found this DIY useful, and there are lots more here to keep you entertained for days on end.
- Brian
Share the Road
Old 07-16-2009, 02:36 AM   #59
b_hickman11
Drives: 08 Sedan
Actually the filter is between the air inlet and the blower. The air comes in, goes through the filter, through the blower fan, and then through the rest of the AC and finally the vents.
Old 07-16-2009, 10:58 AM   #60
PatrickJohnson
that is not accurate. The air is blowing upward from the blower, into the filter, and out the vents. I promise. I tested. Open your filter housing and turn on your AC. a quick hand over the blower motor while running (CAREFUL!) will confirm that the air hits the filter after the blower, and mere visual inspection will easily show the path of the air once it passes the filter.
Old 07-16-2009, 12:51 PM   #61
b_hickman11
Drives: 08 Sedan
I tried that the very first time and I also thought the air was blowing up. But after looking at all of the parts a little closer, it actually blows the other way.
You might want to check that again. Look under the dash while turning the knobs that selects re-circulate or fresh air. You will notice that this will move the plastic door that is right above the filter. When the door moves to the back, it closes off the outside air inlet and opens the re-circulate inlet. When the door moves to the front, this closes off the re-circulate inlet and opens up the fresh air inlet. If air was blowing up into the filter, the air would always blow into the car from underneath the dash or would blow cold air outside the car, and would never go out the 4 vents on top. You will notice that the vents are not connected to the system here. They are connected on the bottom side of the blower, not the top.
Old 07-18-2009, 11:18 PM   #62
RomGrr
RomGrr's Avatar
Drives: 2007 Yaris HB
You are correct. I finally had a chance to try this today. Yanked off the glove box and tested things. Turn the car on and go sit in the passenger seat with the A/C blowing full blast on recirculating (so you have access). Go get a tissue or toilet paper. Hold it close and see which way it wants to go. It's definitely sucking, which I'm guessing means the car is sucking unfiltered air into the compressor. Regardless, the A/C unit has to be filtered somehow. Show me in the factory manual where this filter is, otherwise it has to be this cabin filter. Take the filters off your home air conditioner unit and see how long it lasts. I'll definitely be adding a filter from now on. I'm pretty damn pissed that the car shipped without one. For such a cheap price, this little paper filter could easily add years to the life of the compressor.
RomGrr is offline   Reply With Quote
Old 07-19-2009, 01:29 PM   #63
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The compressor doesn't compress air. It compresses refrigerant. That air only goes through the fan, AC evaporator and/or heater core.
Old 07-29-2009, 05:30 PM   #64
yarisBMD
Drives: 3dr hatchback
Thanks, this is great! I just picked up my new 3dr 09 LB and checked at the dealer before I left the lot. They claimed they don't have any on hand (?) but that they would be in contact. I'm making my own as we, uh, text! Thanks!
yarisBMD is offline   Reply With Quote
Old 08-11-2009, 09:42 AM   #65
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
All you have to do is look at the fan blades and note the direction of rotation. I'll be making some filters when I get off work. Yum!
RUFFSTUFF is offline   Reply With Quote
Old 08-14-2009, 10:22 PM   #66
Boost Addicted
Drives: 2008 Yaris 5spd, 2005 GLI 1.8T
Interesting... I'm not trying to insult anyone here, but the directions for this are actually in the Yaris manual.
However, they call it an A/C filter? Which is why I was stumped and just didn't put anything in there.
No auto place sells these filters? You have to buy one from a hardware store?
Boost Addicted is offline   Reply With Quote
Old 08-14-2009, 11:32 PM   #67
BailOut
BailOut's Avatar
Yes. It is actually a home furnace/central air filter.
- Brian
Share the Road
Old 08-15-2009, 08:28 AM   #68
Yaris Hilton
Smile
From post #69 in the "cabin filter missing" thread:
Originally Posted by 08YarisAZ View Post
If you need to replace the cabin filter, there is a good thread about making your own, or you can go to a parts store - I used Advance Auto Parts, and picked up the Purolator C35667. It costs around $15. You can also get them at Pepboys and sometimes Checker. I have also used the Wix version, but it wasn't as good.
Old 08-15-2009, 10:55 AM   #69
1stToyota
1stToyota's Avatar
Depends on what you're wanting. DYI, or install one already made by Bosch, WIX, Fram, Beck/Arnley, etc...
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-15-2009, 11:16 AM   #70
Boost Addicted
lol thanks man. I'm not gonna lie to ya and say I read through this whole thread, and should've saw that post before I posted lol.
Old 04-26-2010, 08:57 PM   #71
fratzica
Diesel Inside
fratzica's Avatar
Drives: Yaris 1.4 D-4D
Got a question.
I want to install my carpc into the glove box compartment. Please tell me, is the air heater placed before or after the cabin air filter? I wouldn`t want to fry my computer during winter time..
Thank you!
fratzica is offline   Reply With Quote
Old 04-26-2010, 09:36 PM   #72
b_hickman11
Drives: 08 Sedan
Originally Posted by fratzica View Post
Got a question.
Thank you!
Air flow goes down so it is heated after it goes through the filter and after the fan.
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
cabin air filter kaboom DIY / Maintenance / Service 108 03-31-2009 09:00 PM
DIY: Changing Your Cabin Air Filter tk-421 DIY / Maintenance / Service 0 06-30-2007 06:40 PM
CA: Free Cabin Air Filter, Socal only. kunfuzion Items for Sale by private party 6 03-24-2007 11:34 PM
