Old 07-09-2006, 10:59 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
- DISABLED DayTime Running Lights How To- 2007 Yaris! -
For those looking to disable DRL's on their new Yaris, look no further!
If your Yaris doesn't have DRL's, ignore the post.
If you don't want to disable your DRL's, ignore the post.
To those that have been searching for the cure, enjoy!
Simple 5 minute job. There is no TSB out yet from Toyota, but it doesn't get any easier then this!
Tools Needed:
Medium size phillips screwdriver... thats it!
To gain enough room to access the DRL Relay, you need to first remove the steering column plastic cover.. Here's how!
Now, look under your steering wheel, you will see the height adjustment lever to tilt the steering wheel column, up and down.
Just to the right of the lever, you will see a Silver phillps head screw, remove it.
Now, with your hands on the steering wheel, at 9 o'clock, and 3 o'clock, turn the wheel 1/4 turn to the right. You will see a Black phillips head screw, remove it.
Now turn wheel back to center, and repeat for other side. Turn wheel 1/4 turn to the left. You will see a Black phillips head screw, remove it.
The steering column plastic can now be removed.. pull it down and towards you, it will snap out of place.
Now look back behind the dash, up and over towards the radio, and you will see a black box about the size of a pack of cigaretts with a brown lable, "TOYOTA RELAY ASSY RUNNING LIGHT 82810-52040."
Depress the white tab, and unhook the plug from the relay box.
Your finished!
Pictures, and full review of my H4 HIDs and LED parking lights tomorrow.
Your welcome.
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
