#55 |
Drives: LB Join Date: Jul 2006
4.5" exhaust tip?! I'd pull you over based on principle alone. Thats just weak.
#56 |
![]() ![]() ![]() Drives: 00 itr Join Date: May 2006
exhausts, at least in the us, cannot get you pulled over unless you have removed the cat or you are in violation of the sound level law. i drive a yellow itr with a rather loud exhaust and have never been pulled over, it all depends upon how you drive.
#57 |
![]() ![]() ![]() Drives: Scion FRS Join Date: Aug 2006
based on the chart... the car produces 118 hp stock :x
Is it me.. or is that awfully high for a standard yaris. |
#58 |
could be... because I didn't think stock exhaust hit almost 100 dbs.. then again I'm always sitting inside the car so I wouldn't know :x
#59 | |
![]() Drives: 07YarisVitzBadgingTRDsportivo Join Date: Aug 2006
07 Toyota Yaris (MonoculusJoe is... 86 Toyota MR2 ...JoJoAW11) |
#60 |
![]() ![]() ![]() ![]() Drives: 240sx, 00 Celica Join Date: Apr 2006
Todd I saw you yesterday on the 91!
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL 24711 Redlands Blvd., Ste. I Loma Linda, CA 92354 T: 909-796-8189 E-mail: info@c2auto.com AIM: wide180sx |
#61 |
Hope I didn't cut you off. How did the exhaust sound?
#62 |
haha you were driving in the right line behind the big rigs. I exh seems pretty loud. Its nice though, doest sound raspy or anything.
#63 | |
![]() Drives: Toyota Vitz Join Date: Jun 2006
The "Under 93db" that we state does not mean that the exhaust operates at 93db at all rpms. When we are developing the exhaust system, we calculate an SAE db average using the same method of testing that is used by referee stations to test sound output from automotive exhausts. What this means is that 93db is the maximum allowable averaged db rating of the exhaust at all rpms. The exhaust system may be 85db at idle, 88db at cruising, and 92db at high rpms. Under 93db means it will not exceed this. 95db is the legal limit of most states, and every 2db generally represents a doubling in audible volume, putting our exhaust systems well within the scope of legal operation. Sound clips must be listened to subjectively, as the sound clips we record were using lower tech digital cameras, and only high end equipment can capture the lower, more bass sounding frequencies. Under 93db means that our exhaust systems are tested to and will conform with SAE db testing procedures used by agencies such as CHP referee stations. Our exhaust systems are able to acheive this type of sound compliance due to the design and packing material found inside the muffler. We use a highly unique muffler packing material that differs from virtually all other exhaust manufacturers who are still utilizing various types of fiberglass packs. Please see http://www.tanabe-usa.com/tech/techtest.asp
![]() Tanabe Racing Development USA, Inc. "We engineer performance!" http://www.tanabe-usa.com Performance parts for the Yaris/Vitz available 6-17-06. Please check forum or email us at info@tanabe-usa.com for updates and information. |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
| Tanabe USA needs SoCal Yaris for R&D | Tanabe USA | General Yaris / Vitz Discussion | 5 | 06-09-2006 09:11 PM |
| Exhaust -- | Ziv | General Yaris / Vitz Discussion | 1 | 02-06-2006 12:57 PM |
