Old 09-08-2010, 07:38 AM   #55
krolos
Drives: 2008 yaris sedan
Originally Posted by RedRide View Post
I have no idea why now, some are saying that you shouldn't add oil to the full mark. That's what the *&%* mark is for!
In fact, if it's slightly above the full mark it perfectly OK.
Als long as there is no indication of oil foaming when the engine is run hard, you are fine no matter how high the level is.
If you fill it to factory spec. it is going to be a little above the full mark, {4qt}
anyone who says otherwise is just simply wrong.
krolos is offline   Reply With Quote
Old 10-26-2010, 05:03 PM   #56
2007yariz
Drives: Yaris sedan
Hey guys! Just to be sure, the oil pan and its drain plug are underneath the front passenger seat(shotgun)??
I am so jealous that the OP has a metal dipstick, mine is plastic plus the color is YELLOW! Why Toyota? Motor oil is YELLOW!
What kind of dipstick do you guys have(metal or plastic)?
2007yariz is offline   Reply With Quote
Old 10-26-2010, 08:54 PM   #57
Klink10
Klink10's Avatar
Plastic
Old 10-26-2010, 09:31 PM   #58
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
2007Yariz,
Yes the oil pan and the drain are under the passenger side. I'm sorry about the metal dipstick, lol. Maybe 2008 was when they changed the dipstick?
Good luck with the change!
Old 10-26-2010, 10:01 PM   #59
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
2008 - Metal dipstick.
Old 10-28-2010, 08:09 AM   #60
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
2009-metal.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 10-28-2010, 12:44 PM   #61
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
is it bad i don't know this?
Colin Chapman disciple
Old 10-30-2010, 09:46 PM   #62
bail_w
Drives: 2007 Toyota Yaris LB
Why no Fram?
bail_w is offline   Reply With Quote
Old 10-30-2010, 10:08 PM   #63
rningonfumes
Why? - Nothing wrong with the plastic dipsticks.
Bail - In the past regarding the lower end Fram filters, they aren't very high quality in relation to their competitors.
Old 10-31-2010, 05:00 AM   #64
bail_w
How about now then?
Old 10-31-2010, 10:50 AM   #65
Klink10
Klink10's Avatar
Not to but in....but Frams are out. I know Wally World sells them in abundance but they also sell Supertech which gets much better reviews. Check my garage for the size as I don't remember right off hand.
Old 10-31-2010, 11:54 AM   #66
bail_w
Yep, Wally World sells them. I was looking into the Fram Xtended Guard series, and i don't think it was as bad as the Extra and Tough Guard series filters. Anyway, I installed a Xtended Guard on my 98 Corolla, i will cut it out for inspection after 3k mileage.
Old 08-12-2011, 09:56 PM   #67
TXyaris
Drives: Currently stock '09 Sedan.
Yes. Most service depts and local garages do not prefill a filter.
While it is a good thing to do no harm will come to an engine if you don't.
As Yaris Hilton said, it only takes a couple of seconds for it to fill and oil pressur to build up.
Just don't redline it the second you start it and it will be fine.
damn.. thats what i always do! lol
TXyaris is offline   Reply With Quote
Old 07-18-2012, 07:33 PM   #68
biggyjiggy
Drives: 07 Red Yaris LB
just did my first oil change on my yaris :) since ive had it. Thank you very much for the write up it helped alot :)
biggyjiggy is offline   Reply With Quote
Old 07-18-2012, 10:15 PM   #69
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I have worn the thread of my sump bolt.Anyone know where i can get a new one?
Old 07-19-2012, 12:18 AM   #70
rningonfumes
Try your local autoparts sort, the worse they can say is "no". Then you'll have to try the dealership.
Old 07-19-2012, 12:24 AM   #71
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I have a plastic dipstick ... I was shocked when I first saw it. Even my old 87 Honda Accord had a metal dipstick.
edmscan is offline   Reply With Quote
Old 07-19-2012, 12:57 AM   #72
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Mine is metal (2012)... I put 4 quarts in and run it a little high with no foaming issues. On the first oil change I drilled the drain plug and stuck in a really strong neodymium magnet to catch the iron powder.
Yaris oil change appreciation flagmunkey DIY / Maintenance / Service 18 07-19-2007 02:46 PM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 09:32 AM
