Old 08-10-2014, 12:08 PM   #55
aspro
install
Very easy. Jack up the car and remove the front wheels. Remove the tower brackets from the tanabe bar and and bolt up each bracket on the two strut towers (two bolts per bracket). It gets tight under the wheel well when trying to tighten the bolts up for the brackets but it works if you have the right tools. Then attach the bar to the brackets and adjust and tighten accordingly. Then re install the wheels and drop the car. Then inspect the install and make sure everything is still nice and tight. Then drive and enjoy. Also, after a couple hundred kilometers check everything again and make sure everything is still tight and secure. Its a really easy install with basic tools don't be intimidated by it. But its very important that you do the entire install with the car in the air and the load off of the front wheels.
Good luck!
aspro is offline   Reply With Quote
Old 08-10-2014, 12:11 PM   #56
aspro
Looks good!
Thanks Garm! Thanks for the product!
Old 08-10-2014, 04:18 PM   #57
[EDIT] whoops, cross post
1. jack up the front of the car, remove front wheels.
2. Remove fender liner (OR separate enough so you can reach up underneath
3. Install left and right brackets (black ones). Two people is way easier so you can get to the top of the bolt and the nut underneath, but I have done this alone before.
4. Adjust threaded end pieces to line up with bracket holes.
5. Install bar to the brackets.
6. Tighten everything, put wheels on, lower car. DONE.
Did I miss anything?
Old 08-15-2014, 02:41 AM   #58
aspro
Nope you got everything. I would suggest to just inspect the install after driving the car around a bit to make sure everything is still tight and secure.
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
**NEW ITEM** Tanabe Sustec Front strut bars C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-27-2007 09:54 PM
