Old 09-12-2010, 03:56 AM   #55
FcukThis
Drives: yaris
Meet Mr.ugly.
Here's the underside of speaker baffle,
Spectrum'd a few layers.
Added that 3/4" ring.
Put up a ghetto dowel fence.. to act as a frame for when i glass.
It was a pain in the ass.. I had to trim every individual piece to size, then hot glue them into place..
side
The top being mounted. Glued, screwed, clamped.
I regret buying gorilla glue over titebond. Polyurethane glue is such a beezneetch to work with.. not to mention only half the strength as titebond.
Here you can see what i have to repair :[.
The gap which i must fill.. because i did a sloppy trim job.
Lesson learned, FOR SURE.
I would just wrap the side of the plug w/ cloth.. and reglass. but if i did, it would create a hump that wouldn't sit flush with the trunk.
speaker ring rounded
FcukThis is offline   Reply With Quote
Old 09-12-2010, 09:41 AM   #56
sqcomp
Roadrunner Jr.
sqcomp's Avatar
What happened with the backside so that you needed to raise the baffle? Was it just how you cut it down?
I would imagine that you're going to find it difficult to just lay mat over the outside and achieve the result you're looking for. Do you have some kitty hair (long strand fiberglass filler)? I think that's what the 1/2" long strand fiberglass filler is in one of your pictures (don't forget the hardener). I would fill it from the inside if at all possible THEN trim it down from the outside. This is what I did to fill all my seams...eF titebond or silicone. I just glassed my seams.
This is what I used:
I'm thinking that'll solve the issue. No sweat needed.
― Thomas Paine
Old 09-12-2010, 11:56 PM   #57
FcukThis
Drives: yaris
Yeah, i was going to create a kitty hair mix.
It's essentially thick milkshake with long strand fiberglass correct ?
[body filler , resin. both hardeners.]
That's a good idea though-- starting from the inside of the plug. I was really only going to do it from the outside.. Silly me. I'll probably end up doing it from the inside as best i can, then the outside. Then trim it down.
The ring on the backside of the baffle is only there to reinforce the speaker ring.
The top ring is simply a vanity piece.
Old 09-13-2010, 01:07 AM   #58
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I think that 1/2" stuff you bought will work without adding resin.
Just to test it, add some cream hardener to a small little dab and see how it finishes.
I'm thinking that you'll do fine with the inside-out plugging...okay, that just sounded wrong. ANYWAY, you know what I mean. Let's see some progress pics with that when you have some.
― Thomas Paine
Old 09-14-2010, 12:14 AM   #59
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
I don't seem to remember Kicker ever telling me that my old Solo D 15's were only to be put in sealed enclosures...That's what I did, but still...
I know what you mean, this comes from the manual...
Manual link
Old 09-14-2010, 05:05 AM   #60
FcukThis
Drives: yaris
I may be moving my build log to diyma.
I'll post a link if any one is interested to follow ?
Old 09-14-2010, 10:13 AM   #61
derickveliz2
Yes, don't forget the link!
D.
CLA 250, 4MATIC
Old 09-14-2010, 09:14 PM   #62
nx04
Drives: Mazda RX8 gt
yea post the link this is interesting
nx04 is offline   Reply With Quote
Old 09-15-2010, 03:00 AM   #63
FcukThis
Drives: yaris
http://www.diymobileaudio.com/forum/...ris-build.html
Here you go all !
Toyota.com build your car bullshit gaffo General Yaris / Vitz Discussion 1 09-23-2007 02:16 PM
Recent box build spkrman In Car Entertainment + Electronics (audio / video / alarm) 8 01-26-2007 03:14 PM
Enduro - Yaris BUILD! EnduroMTS Cosmetic Modifications (Exterior/Interior) 3 10-17-2006 02:33 AM
Build Your Yaris, toyota.com artyin General Yaris / Vitz Discussion 3 05-03-2006 04:52 PM
we can build our yaris now!!! hhcchen General Yaris / Vitz Discussion 8 03-05-2006 06:38 PM
