Old 06-22-2013, 02:01 PM   #721
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
welcome po sa mga newbie...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 06-23-2013, 12:14 AM   #722
cutie patuti
cutie patuti's Avatar
Drives: 2011 Yaris Y
sir ask ko lang po kung pwede 195/55 R15 sa yaris ko, right now ung gamit ko ngayn stock tires 175//65/R14 82T
cutie patuti is offline   Reply With Quote
Old 06-25-2013, 03:19 AM   #723
syntax
syntax's Avatar
@ cutie paki follow po sa thread na ito
http://www.yarisworld.com/forums/sho...postcount=2717
Old 08-08-2013, 02:51 PM   #724
AVIATOR
Drives: toyota yaris
Mga kayaris newbie po ako sa Forum na ito from Jeddah po ako ang sasakyan ko po Yaris 2012. I think very impormative po itong group na ito sana po maging member po ako dito sa Jeddah.
AVIATOR is offline   Reply With Quote
Old 11-12-2013, 12:05 PM   #725
EddieCabael
Drives: Sedan_Toyota_Yaris_2010_Manual
Ito po ang message kong naka post parang naka remove yata, paano mag kakaroon ng replies for me to get answer for my idea to solve my problem. Pero mayroon pong isang nag reply taga US, I consulted the printout po ng nag reply doon sa mga kakilala kong mekaniko pero ang sabi ay common trouble shooting lang ang naka present nang nag reply. Ang sakin ay iba daw pero ang problema talaga mga kayaris ay ang pabugsobugsong amoy galing sa AC Blower.
The below is my orginal posting with detailed problems po:
Unique Smell from Air Going Through AC Blower
Whoever has the same problem of mine and got solved or you haven't had an experience for the same problem with me --- but you have idea, please come out and please help get solve my problem:
Please do reply in English or Tagalog, although I used English Version here:
Problem Details and situation/scenario:
At the beginning of this year in late Feb-2013 I started to smell like burnt plastic or like metal to metal friction smell coming from my AC Blower.
I just ignored until June-2013. But I am not relaxed because I know there's already an accumulation of car air pollution with me.
When my Clutch Pedal was making noise I brought my car for maintenance and the company did repair my clutch telling they replaced the clutch disk with new one but they just made a machine works for the affected area of the Ply Wheel or whatever you may call it. After this the clutch noise was removed and made Big OK.
But the problem is --- the smell still there.
Around August-2013 my AC Cooling system has a poor cooling and I brought my car to the company for checking and they replaced my AC Compressor.
Around September-2013 my AC Cooling system has still a failure and that the smoke direct from the Panel (from AC Blower) is coming out but there is not enough cooling inside the car. I brought my car to the company for checking and they replaced my AC Freezer or Talaja as they call it. The car cooling now is excellent.
I remembered I hit one big plastic, the one being used in wrapping big carton, and it wrapped my exhaust pipe, that time I cut some but most have remained wrapping my exhaust pipe, lately when I checked --- the plastic remains got melted and wrapped around my exhaust pipe and I brought to outside shop to remove the same. And the exhaust pipe was cleaned and that melted plastic around my exhaust pipe from rear side was completely removed.
I checked my dashboard and opened all to see which one is not closing or opening whenever there is a switching from AC Blower recycling or not recycling. I found out all are in good order and all are functioning.
I checked my AC Drainage system and found OK and nothing is blocked and that AC moisture water is going through that AC Drainage system or AC Moisture hose completely OK.
I checked my AC blower air filter in front of passenger side and found empty but there's a slot for a purpose and I inquired from many and they said there must be filter in it and I bought new one and I fixed by myself through Internet Tutorial. And I was able to have it done. The Talaja is still new and being used in less than a month for now, so late providing for the AC Blower Air Filter is not a big deal.
What is left now on how to find the source of that smell nobody knows.
My Sedan Yaris 2010 Car was purchased on October-26-2010 and is no longer in warranty period after such long trouble shoot, the smell problem remains.
I found just today 06-Nov-2013, that my AC Valve is exposed, leaving spaces from left/right/top/bottom of the AC Valve --- which I am thinking maybe it will cause to suck the air and throw it to the car inside because of air pressure from the engine. If the pressure from the air engine while ON could not penetrate through the created surrounding spaces from the AC Valve because the blower is set to close or in recycling air setting (where it is taking air from inside the car only and rotating therein) and not the one if open (taking from front side air and throwing at the rear side).
But if there is such kind of smell in case the smell is coming from the accumulated hot air from the engine --- then the smell never stops and it will go through the car inside regardless of AC Blower setting whether recycling or not --- because of such surrounding spaces from the AC Valve.
I remember before, I was searching my AC Valve location and I cannot find because the AC Valve was concealed and covered --- only piping was exposed --- but now, the AC Valve itself is also exposed --- maybe some mechanic did forget to have it covered. Or maybe the AC Valve is by manufacturer's default is really exposed, this I don't know.
I went crazy thinking because of this unwanted smell is mostly occurring while the car moves from the it’s parking being parked of around 3 hours --- means while the car came from cool engine, when the smell is coming out, it’s not continues and the smell is gone but it is sometimes worst. When the car is in stop position but engine and AC are working, it never gives that smell.
While car is running, only two functions are smell suspects: From the Clutch and From the Brake --- but clutch and brake functions now are excellent.
And even also my back compartment is clean.
What is left now to find solution and get solve this unwanted smell going through my AC Blower in my front side and going into my lungs in almost more than half year now.
Thanks to all of you,
Edito Tizon Cabael (Eddie Cabael)
EddieCabael is offline   Reply With Quote
Old 12-25-2013, 07:56 AM   #726
stress
Drives: Yaris Black 2014
mga bosing baka may alam kayo ditto in Riyadh kung meron near batha na base sa experience niyo n ok gumawa ng dent at pain- ayaw ko na kasi ipagawa sa Toyota workshop kasi super tagal nila gawin (dahil madami talaga nagpapagawa sa kanila)
baka may makatulong naman mga kayaris ditto sa Riyadh?
black naman ang yaris ko. (kung meron sana na pinoy if wala oks lang na ibang lahi na based sa experience nio na ok naman gumawa ng DENT AT PAINT.
stress is offline   Reply With Quote
Old 03-24-2014, 08:26 AM   #727
yorikojg
Yoriko
Drives: Yaris 2013 model
new joiner
salamat po at welcome kami dito
yorikojg is offline   Reply With Quote
Old 03-25-2014, 02:37 AM   #728
yorikojg
Yoriko
mga sirs of khobar baka po pwedeng patulong? baka po may kakilala o katropa kayung nag dedent and paint paki refer naman po ako.
Old 03-25-2014, 03:58 AM   #729
yorikojg
Yoriko
Magandang Araw po sa inyo lahat, anu po ba ang next step pag nakapag register na po dito.magjoin po sana ako. khobar po location ko.
Old 04-27-2014, 03:42 AM   #730
KarMeo
Drives: Light Green Sedan Yaris 2008
Welome Bro :)
KarMeo is offline   Reply With Quote
Old 05-09-2014, 05:04 PM   #731
alexutlang
Drives: Toyota yaris Y
2011 Toyota Yaris for sale
> Still under Al Yuser 60 months installment plan
> 32 months already paid 28 more remaining with a total amount of SAR
> 30,548 and last payment of SAR 8,919
> monthly fee is SAR 1,091 including comprehensive insurance
> Only 59,000 km mileage
> Automatic gear and power lock and windows
> All maintenance services are documented
> orig PJ Johnson window tint worth sar 2,000
> 16 " wheels worth sar 2,000
> expected expenses
> SAR 3,000 for me
> up to SAR 1,200 to Al yuser for admin fee and transfer fee
> Advance 2 months payment to Al Yuser - SAR 2,182
Interested call 0545408181
alexutlang is offline   Reply With Quote
Old 05-29-2014, 04:58 AM   #732
Lenso
Drives: Toyota Yaris 2010 Sedan
sir kaka sign in ko lang dito. pano maki join sa group?
Lenso is offline   Reply With Quote
Old 07-10-2014, 10:40 AM   #733
Yarisko2014
Drives: Yaris2014
Hi
New bee here.........
Yarisko2014 is offline   Reply With Quote
Old 08-08-2014, 03:32 AM   #734
xyntax
Drives: Toyota Yaris Sedan YX
new be in town.. hi mga kayaris!
xyntax is offline   Reply With Quote
Old 08-28-2014, 11:11 PM   #735
kokoyJDM
Drives: Yaris Sedan 2009
hello po bago lang po ako, ask ko lang sana if how much lowering springs jan po. thanks po
kokoyJDM is offline   Reply With Quote
Old 10-22-2014, 10:35 AM   #736
chanotski
Drives: Yaris Sedan 2013
Bago ako dito
Hello guys,
tanong ko lng san ba kayo nakakabili ng mga body kit and aftermarket parts para sa yaris ?
chanotski is offline   Reply With Quote
Old 02-03-2015, 09:01 AM   #737
sethjibrail
God is Good.!
sethjibrail's Avatar
Drives: Yaris 2014 Sedan
I'm a newbie..good afternoon po sa inyo,!!!
sethjibrail is offline   Reply With Quote
Old 03-29-2015, 12:59 AM   #738
jetpal
Drives: toyota yaris 2010
newbie
Mga brod,
Updated pa po ba ang site na to?
jetpal is offline   Reply With Quote
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Ano sports ng mga Kayaris sa Riyadh? ubospawis Middle East 168 05-09-2014 05:05 PM
mga ka yaris post ko lang po yung old yaris ko d2 sa K.S.A kiel12 Middle East 71 12-25-2013 07:57 AM
kayaris monthly meet syntax Middle East 89 11-29-2010 12:52 AM
Mini Meet Kayaris syntax Middle East 77 07-04-2010 12:01 AM
