Old 07-11-2011, 12:27 PM   #1
Jason@SportsCar
Got the old stuff out this weekend, went much quicker than I thought it would. Unfortunately some parts are on back order so I could not start putting the new motor in yet, hopefully I can knock it out next weekend.
Old 07-18-2011, 12:42 PM   #2
Jason@SportsCar
Shiny new motor in place - you could eat off this thing. Should have it back on the ground next weekend, then off to the dyno, and finally a test day at the track.
Old 07-18-2011, 05:26 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Sad! Wish I could swap out the drivers side mirror with mine. Mine was broken at the swivel point and is gorilla glued, and when the glue did set it sagged a quarter inch. Toyota won't sell me the broken part, I need to buy the whole damn mirror.
Originally Posted by Jason@SportsCar View Post
Yeah, the whole thing. It's a weld in cage anyway, no way you could salvage and reuse it. The amount of hours that would take does not justify the few dollars saved versus getting a new one built.
The 98 car will stick around for a while, just in case they come up with a use for it - the 98 was supposed to go to the U.S. dealer meeting in Vegas this week, but they took something else.
Old 07-18-2011, 02:21 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
amazing.. looks so fresh
Old 07-19-2011, 12:27 PM   #5
They bypass also help let through any trapped air bubbles.
Old 07-28-2011, 02:07 PM   #6
MMTS-TC05 is listed for newer model Corolla and Celica; is that the one you got?
61C deg = 140F deg (Mishimoto rating)
82C deg = 180F deg (Toyota OEM according to Mishimoto)
I don't see a reference to Yaris specifically.
Old 07-28-2011, 02:23 PM   #7
Jason@SportsCar
No, MMTS-SUP-93T, its the Supra unit. I hope it is really not a 140, (perhaps a metric to English translation error on their part) that will be a little to cool. I will have to put it on the stove and test it.
Old 07-28-2011, 02:44 PM   #8
^ hehe, that makes me chuckle, but it's a great way to see how it works.
Old 07-28-2011, 02:51 PM   #9
Jason@SportsCar
Do it when the wife is not around... They never understand car parts in their cookware.
And now I am thinking it would not be bad if it was really cold... I might be able to tape up the top grill for better aero.
Old 07-28-2011, 03:59 PM   #10
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
conversion charts reads 140......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 08-01-2011, 06:44 PM   #11
Jason@SportsCar
It's alive... Finally got around to starting it up with the new motor. Now we just need to get it back on the dyno, then out to the track.
Old 08-01-2011, 07:03 PM   #12
are you allowed to post dyno sheets? if you are, could you?
Old 08-02-2011, 01:01 PM   #13
Jason@SportsCar
What should I do with this? Approx 2k miles on everything except the head and fuel injectors, which have about half that.
My plan is to keep the head, we have a lot of work in to it, and may want to revisit it later.
Old 08-02-2011, 01:10 PM   #14
Jason@SportsCar
New parts are fun. Beatrush crank pulley. Hopefully a bit more durable than the last piece we had. Unfortunately, it's not an under drive unit, and it is a bit heavier than the last one, but if I don't have to pick up the pieces on the side of the track it will be worth it.
Stock 3lbs
Beatrush 1lb 4oz
Old 08-08-2011, 03:09 PM   #15
Jason@SportsCar
And unfortunately as advertized it does open at 140. I had hoped that it might have been a math/conversion/marketing error, because who would need one that cold? But that was not the case. Oh well.
Old 08-10-2011, 04:41 PM   #16
ilikerice
ilikerice's Avatar
oh the envy
Old 08-12-2011, 03:16 PM   #17
Jason@SportsCar
Due to a scheduling issue we ended up tuning the car early this AM. As expected we gave up some HP going to the stock engine... But OMG, the TQ more than makes up for it.
Peak HP is now 132@5500rpm (a full 1000rpm earlier than the old motor), and at 5000rpm I have 20lb-ft more TQ than the old setup.
While it sucks to give up the HP, nearly all of it was from 6500-7300rpm, so it wont be missed that much. The TQ increase will make a big difference on the start, corner exit, and every time I shift up a gear I will no longer be waiting for the engine to get back on the cam.
This should also make life easier on all the parts, as we no longer have any reason to spin past 7k.
Comparing this chart to the original (stock engine with the Camcon), shows how close the relatively inexpensive Camcon can get this car. The AEM got us about 2hp more, 8lb-ft more TQ, and another useable 500rpm. If we did not need every bit of power I would just use a Camcon. It gets you 95% of the way there, for about $1800 less.
Old 08-13-2011, 07:44 PM   #18
nice!
have a dyno chart?
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
