Old 05-28-2007, 10:02 PM   #73
captainzerocool
CAMRY FTW!
captainzerocool's Avatar
Drives: Camry LE V-6 (225,000+ miles)
Here is the better seller from ebay.
http://motors.search.ebay.com/_W0QQsassZsterlingda
I hope that link works.
I drive a Camry.
I have no imagination.
captainzerocool is offline   Reply With Quote
Old 05-29-2007, 11:13 AM   #74
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
thanks bro..
thanks for the tips.. i actually have toyota to look a it tomorrow they have to bring in another yaris manual in there to compare that noise during acceleration.. we chall see soon..
The only things that will let you adjust the VVT-i timing are the Camcon:
http://www.powerenterpriseusa.net/pr...con/camcon.htm
Or Greddy's new V-Manage:
http://www.greddy.com/products/displ...SubCategory=72
Honestly, I don't think a timing adjustment will resolve your engine noises, but you can always give it a try...
Old 05-29-2007, 11:59 AM   #75
marcus
toyota
marcus's Avatar
what the fastest 0-100km.hr or 0-60 m.h on your scangauge guys??
Old 05-30-2007, 04:12 PM   #76
marcus
toyota
marcus's Avatar
does scangauge 2 have a shift light or shift alarm on it??
Old 05-30-2007, 08:33 PM   #77
uncleyaris
no.
Old 05-31-2007, 11:11 AM   #78
marcus
toyota
marcus's Avatar
daym!
Old 06-07-2007, 09:18 PM   #79
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I think I found some velcor that won't melt got it at home depot say's it's dashboard velcor it was over 90F here today didn't melt .
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 06-08-2007, 02:38 PM   #80
365Motorwerks
Drives: Small and Black
Nice now we got to get some of the folks in Arizona to try it out they always seem to have the crazy temps!
365Motorwerks is offline   Reply With Quote
Old 06-08-2007, 05:13 PM   #81
MudBug
Drives: 07 Yaris
My SGII constantly slides down the steering column because the glue melts.
I'm making a mount for it from some kydex I have. I'll post pics when it's done.
MudBug is offline   Reply With Quote
Old 06-10-2007, 05:05 AM   #82
Thedunpeal
Drives: Yaris LB
Send a message via AIM to Thedunpeal
post results quicker before it gets 120 here
Thedunpeal is offline   Reply With Quote
Old 06-14-2007, 11:53 AM   #83
marcus
toyota
marcus's Avatar
what can you guys scan.. on your scan gauge..
1. air intake temp
2. engine coolant temp.
3. ???
Old 06-14-2007, 01:00 PM   #84
BailOut
Steals terrorist's lunch
BailOut's Avatar
http://www.scangauge.com/features/digitalgauges.shtml
My current default setup is like this:
Code:
MPG	RPM
WT	V
I like the WT (water temperature) because I use an engine block heater and because I can go for long distances with the engine turned off (FAS), and I like the V (battery voltage) because I use a solar charger and because I restart the engine a lot (due to FAS'ing).
This Fall/Winter I will trade the V display for IAT because I plan on insulating my engine and blocking the grills to help keep the block and fluids warm (this helps with fuel efficiency in the cold months), so I'll need to monitor how the IAT affects the WT for a while, at least until I get it all "dialed in". I'll need to use the IAT reading again in the Spring to help determine when to un-block the griils and whatnot.
- Brian
Share the Road
Old 06-14-2007, 02:50 PM   #85
MudBug
Drives: 07 Yaris
1. air intake temp
3. ???
Code:
MPH       RPM
MPG       V
I rarely use the speedo on the car, the displey is so course I can't tell if I'm doing 71mph or 76mph quickly and since I'm surrounded by speed cameras I need to know for sure I'm doing under 10mph over, that when the camera gets you. So I use the speedo on the scanguage.
Old 06-27-2007, 11:52 PM   #86
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Sorry fo bumping this thread up again...but i have a quick question....
Does the scanguage function as a tach as in, tell you your rpm? I know it tells me max rpms on a trip, but I'm wondering can it tell me my rpm as I go from a complete stop to cruising to changing gears before redline....?
Thanks ~
Old 06-28-2007, 12:04 PM   #87
seriousfun
Drives: 2007 Yaris Liftback Black
Does the scanguage function as a tach ....?
Yes!
seriousfun is offline   Reply With Quote
Old 06-28-2007, 12:13 PM   #88
marcus
toyota
marcus's Avatar
DOES scangauge read our yaris timing degree would it show if it retarding or advancing???????
Old 06-28-2007, 12:16 PM   #89
marcus
toyota
marcus's Avatar
timing on scangauge.!!
Old 06-28-2007, 12:24 PM   #90
BailOut
BailOut's Avatar
It shows timing but I haven't quite figured out how to read it yet. My commute can bring it all the way down to 3 or all the way up to 32, and it seems to hang around 22-23 when driving with steady throttle on flat ground and calm RPM.
- Brian
Share the Road
