Old 06-22-2010, 12:15 AM   #73
myt
myt's Avatar
Drives: Blazing Blue 07 YAris
Big thanks for this thread!! The lithium solved my issue!! Smooth shifting and no squeaking!
MYT
myt is offline   Reply With Quote
Old 06-22-2010, 01:24 AM   #74
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
^ ditto I had the now infamous squeak problem and after a long drawn out argument with the Toyota dealership I went home to fix it myself! Squeak killed + confidence increased!
Score: Dealership - 0
Me - 1
bkndacn is offline   Reply With Quote
Old 06-22-2010, 02:44 PM   #75
Focus_Sh1ft
Focus_Sh1ft's Avatar
Anyone have this problem on an automatic? I definitely have this squeak issue but don't have that linkage that MT's have.
Old 06-23-2010, 07:37 AM   #76
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
squeaky transmission in MMT yaris.
hello,
I have a Multi-mode yaris since august 2009,and the gears started to squeak (well-not exactly squeaking but it's sounds like 2 metals grinding to each other for a second while trying to shift) .
this occurs mostly in 1st to 3rd gears shifts,both upshifting and downshifting,and it appears randomly ever since i bought the car.this happens also when i start the car either in automatic or manual mode, but also happen when i'm engine-breaking while using manual down shifts.
Can the lithium grease also work in MMT? Is the place to spray it identical to the picture posted here?
has anyone bumped into this phenomena in MMT?
thanks in advance,
Matan.
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 06-30-2010, 10:50 PM   #77
xr_austin
Drives: 2008 Yaris HB MT
Thanks Kou, that fixed it! It's easy to see how this part can squeak if you watch the movement while moving the manual trans shift lever. The lube probably gets washed out with exposure to elements, definitely want to do this every oil change.
xr_austin is offline   Reply With Quote
Old 07-01-2010, 03:38 PM   #78
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Make sure they realign the cables , mine did the ssme thin. And toyota fixed the problem by first realigning the cables then lubing them up, if they just lube them up it will reappear.
Thank you for that advice. I will ask them to realize the cables too before the lube them on my next service appt.
Merci.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 07-04-2010, 03:58 AM   #79
ruimond
Drives: Yaris YR
Found this thread again, but it was back in late 2008 that i had this problem. Its come back recently and started squeeking from 1st to neutral. I decided to give it a go myself this time rather then getting the toyota mech to spray it. So bought a can of this stuff as recommended and gave it a spray while moving it into different positions. Was kinda hard to get into the gap even with the straw tube extension. So i just sprayed in the general direction but hopefully that went into it enough.
There's no noise now when i shift the gears, so hopefully it lasts awhile before needing to re-do it. Cheers.
Old 08-01-2010, 07:45 PM   #80
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
wow.... I just did the silicon spray on both the clutch fork hinge and the gear shift hinge... I NEVER KNEW SHIFTING COULD GET EASIER! It is amazing how much nicer shifting is now... .and best of all, the spray on the clutch fork hinge got rid of the squeak I was getting when pushing the clutch down. Almost feels like a new car.
Old 08-03-2010, 09:47 PM   #81
VZLA
Drives: 2007 Sedan S type
Man, mine is doing that too!! its been doing it for a while and the car just hit its 50000 mile mark. I will Do it myself instead of wasting my time at the dealer. Thanks for the tips!
VZLA is offline   Reply With Quote
Old 08-04-2010, 04:45 PM   #82
Javi
Drives: 07 Yaris sedan
Originally Posted by ScubaSteve View Post
I can't believe I had been living with that for almost 2 years when it was such an easy fix. Thanks for the post
ha ha me too!!!
Javi is offline   Reply With Quote
Old 08-15-2010, 10:23 PM   #83
VZLA
Dude! I just fixed mine! it only took a few second and the squeak is GONE!!! Thanks for the post.
Old 08-16-2010, 09:25 PM   #84
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
the shifter is acting up now.... i'm wondering if it ever would've made noise had I never sprayed it in the first place... (if its not broke don't fix it)... clutch isn't making noise tho, and that's good. I'll spray the shifter next time i do an oil filter change (sometime in the next week or two).
Old 08-21-2010, 07:01 PM   #85
Jerkratt
Jerkratt's Avatar
Finally got around to doing this. Much better. 1 question wtf if the clutch fort thing ur talking about a few posts up my clutch makes a squeak as well
"It hurts more when its wet"
Old 09-11-2010, 05:34 PM   #86
sleey0
Drives: 2008 Yaris LB
My squeak keeps coming back and mine isn't the shifted but the clutch fork.
I sprayed some dry molt inside the boot but i guess that was a ten fix.
Off to thedealer i go sadly.
sleey0 is offline   Reply With Quote
Old 09-11-2010, 05:35 PM   #87
sleey0
My squeak keeps coming back and mine isn't the shift but the clutch fork.
I sprayed some dry moly nside the boot but i guess that was a temp fix.
Off to the dealer i go sadly.
Old 09-16-2010, 11:19 AM   #88
Kal-El
Kal-El's Avatar
Just asked the service advisor at my dealer about lubricating the manual transmission components and he said they never need lubrication because they are all sealed.
Huh?
Old 09-16-2010, 03:19 PM   #89
bkndacn
bkndacn's Avatar
^ from my experience I've learned that 90% of what dealers say is complete BS!
I got a ride in Garms' Yaris and got on a plane within 24 hours of each other.... his yaris was faster! I bet if he put wings on it he could get passed all that L.A. traffic!
Old 09-16-2010, 03:53 PM   #90
Kal-El
Kal-El's Avatar
But usually it's the type of BS that tries to sell you something. I was ready to pay a reasonable price to perform the lubrication described in this thread. Go figure.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
