Old 11-20-2008, 06:24 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by Nexus1155 View Post
A yaris towing a yaris, that will be a hoot to see...the car explode from its insides out! :P
I would pick up the parts that dropped out of his car and try to re-sell them on here.
Old 11-20-2008, 05:11 PM   #2
hmmm, this could be arranged
Old 11-20-2008, 06:35 PM   #3
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
hahah you and me both, but everyone is in Cali for some reason... got to bring this extravaganza down here
Old 11-21-2008, 03:00 AM   #4
LtNoogie
LtNoogie's Avatar
Tonight we took it kinda easy. I still had the combination wrench stuck on a bolt from last night. My brother went to Harbor Freight to buy some really long locking pliers and a magnetic picker upper while I went to Pep Boys to buy a two-foot gripper. I also picked up one foot of vacuum hose.
We were able to free the tool and eventually get the screw completely out of the very tight space.
We are still having problems with the interference that the metal A/C lines are causing with the new belt. There's a compression fitting block which is so close to the belt that the belt will tear itself apart on it when the engine rocks front to rear.
We spent an hour pulling and pushing on the entire A/C line but could not get it to move very far from the belt path. At this time, I am willing to find an auto air conditioning shop to see if they can replace the metal lines with flexible lines and reroute them away from the pulleys and the belt. Tomorrow I'll see if my mechanic can recommend someone.
Since there was very little we could do there, I undid the bolt that held the L bracket between the manifold and the blower. This was done by feel because the L bracket is now underneath and out of site. The new hinged inspection mirror I bought at Pep Boys was useful here.
With the bolt removed, I was able to install the dipstick tube support bracket and then bolt that bracket to the one attached to the dipstick tube. Yeah!!! One minor victory.
It would have been much easier to have installed the dipstick tube support bracket when the manifold/blower was still on the bench.
The vacuum hoses go onto the intake tube easy, now that I have the right length.
The throttle body goes onto the intake tube.
The water hose support goes onto the throttle body.
The CAI attaches to the throttle body and a few more hoses connect to the CAI.
And voila, the roadside of the motor is back together. It looks pretty and ready to run if you ignore the fact that the belt still isn't on.
Here are a few views of the engine bay with the supercharger installed.
Isn't that purdy?
The supercharger sits so high that the stock engine cover will not fit anymore. We will have to cut the engine cover so that it will fit flat on top of the valve cover. There are only two studs where I can fasten it down with the original nuts.
Here is a before shot for comparison. There used to be four studs that held the engine cover down.
See how much clearance there is between the altenator pulley and the A/C lines when the alternator is in its stock position. Once you flip it upside down and move it lower, that's when you get into trouble. Make sure you move all your A/C lines right after you removed the alternator while you still have plenty of room to work. Loosen the screw on the clamp and the A/C line will slide around when you push or pull on it.
I don't know when we will do the electrical installation. I really need to take care of the A/C line interference first so I can install the belt.
It certainly looks the the supercharger pictures that others have posted but it's not running yet. Perhaps by Monday.
Old 11-21-2008, 03:19 AM   #5
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
forget the engine cover....the blower looks sexy, great job and have fun!
Old 11-21-2008, 03:23 AM   #6
LtNoogie
LtNoogie's Avatar
Thanks, Malaya. Someone said that the engine cover prevents the heat from the engine from discoloring your hood right overhead that spot.
Old 11-21-2008, 09:28 AM   #7
As soon as I saw the CAI I also questoned it. I will also try to get an answer about that for you today.
Old 11-23-2008, 02:31 PM   #8
mrbond
mrbond's Avatar
Hey Garm, did you ever get in contact with Blitz to see if the compressor was compatible with the 2 pc CAI's?
Old 11-21-2008, 04:10 PM   #9
LtNoogie
LtNoogie's Avatar
Garm dropped by today to look at the S/C project. While I was explaining how I was having new A/C lines fabbed to clear the belt, he reached in and yanked the A/C line out of the way.
I should have had my Wheaties that day.
Number one: I've already admitted to being a moron in an earlier post.
Number two: We were trying to pull the line forward. He pulled it sideways.
I owe him a sushi lunch.
Old 11-21-2008, 04:55 PM   #10
aw shucks... :flex:
Old 11-21-2008, 06:47 PM   #11
LtNoogie
LtNoogie's Avatar
Garm, can you do the electrical for me?
Old 11-21-2008, 08:45 PM   #12
LtNoogie
LtNoogie's Avatar
My brother wants the night off so no updates tonight. Thanks for checking in.
Old 11-21-2008, 11:37 PM   #13
I'm better at beating stuff up than finessing wires. Sorry!
No updates tonight? What am I supposed to do instead of watch this thread?
No No No !!
Old 11-22-2008, 11:41 AM   #14
LtNoogie
LtNoogie's Avatar
Did you guys find the belt to be too long or too short? We got the belt on and the tensioner went to the bottom of the slot. I'm going to get a shorter belt.
Old 11-22-2008, 11:43 AM   #15
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
I love this thread.
Lisa
aka SIPNGAS
Old 11-22-2008, 12:20 PM   #16
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
how long till the wiring is done?
Old 11-22-2008, 12:23 PM   #17
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
i think i read that the belt was too long on other installs, but i swear cali yaris said the new kits come with a belt that fits? don't quote me.
Old 11-22-2008, 12:46 PM   #18
LtNoogie
LtNoogie's Avatar
Now that I know how to read the numbers on belts, my kit came with a 4-rib 69" belt. We went to three auto parts stores before we found an 8-rib 66" belt. We're about to start splitting it into two 4-rib belts.
I should have read Doc's and Camell's posts closer.
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
Blitz S/C on 08 Yaris whooppee777 Forced Induction Forum 12 11-26-2008 01:45 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
