Old 08-17-2009, 02:40 PM   #73
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Anyone have any comments on the ECU question?
Galavoxx is offline   Reply With Quote
Old 08-17-2009, 02:58 PM   #74
Well, you have changed the amount of air (and fuel) passing through the motor. So your ECU will definitely "notice" that and be making some adjustments (= "relearn"). I'm not sure you have to reset it for it to do that, but it's not a bad idea.
Old 08-17-2009, 03:11 PM   #75
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
I may be thinking wrong but any time you perform a mod that is supposed to increase power you are supposed to disconnect the battery to reset the ECU? Like I said I'm not 100% sure about that
You should. When I installed the headers for the first time I didnt d/c the battery and I got CEL after a few minutes driving. Reset the battery and you shouldn't get a CEL ever assuming installation was done correctly. Running some crap ebay headers with no problems for a month now. :)
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 08-17-2009, 03:27 PM   #76
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I didn't throw a CEL but I'll disconnect overnight and see how it feels afterward.
Old 08-17-2009, 07:52 PM   #77
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
You may want to rev it up acouple time after you start it back up to help the ECU out a little.
Old 08-17-2009, 08:05 PM   #78
DerFlosser
DerFlosser's Avatar
Fantastic write-up! I will definitely hold off on this mod. Thanks again for the great post.
DerFlosser is offline   Reply With Quote
Old 08-17-2009, 08:06 PM   #79
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Hmmm... I read about that trick. I'm a little skeptical but I'll definitely go on a drive afterward, give it some juice.
Old 08-18-2009, 12:38 PM   #80
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Can someone please explain the physics of why would you lose some low-end torque with a less restrictive header? It's not quite intuitive to me, as to why that would happen, but I admit I'm not a mechanic
It's too late for me anyway, as I ordered mine last week but I'd still like to understand what happens there.
Old 08-18-2009, 04:15 PM   #81
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I don't know the physics behind it but I'm assuming it has to do the scavenging properties of the new header. The header doesn't take the exhaust gasses away fast enough at low RPMS due to an increased volume in tubing. The pressure in the manifold is probably too low. Once the engine begins to rev higher and the exhaust pressure begins to rise, that additional volume gets put to use and allows for the exhaust gasses to be expelled more quickly and freely than that stock header that was on there. I could be completely wrong but that's my experience with two-stroke motorcycle stuff talking. I imagine the principles are the same.
Old 08-18-2009, 08:09 PM   #82
DerFlosser
DerFlosser's Avatar
slimmer tube....faster flow and the interior geometry and surface finish also matters. A fatter tube with such a weak motor and you will feel the loss in torque due to less velocity. Don't forget, the car was designed/engineered as a whole unit which means that the overall efficiency is probably maximized with the stock exhaust header. Add some other modifications and well....that story might not hold truth any longer.
Old 08-20-2009, 09:41 PM   #83
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Originally Posted by Galavoxx View Post
...I tried to drive the car as much as possible this weekend but was pretty busy. Based on about an hour of driving, maybe a little more, I have to agree with others that I have definitely lost some low end torque. The car does not want to climb hills below 3000 rpms in second gear, which I used to be able to do. I'm in San Francisco so this matters. There are many hills...
...If you simply must have a header I would hit up one of the cheaper options. I'm glad I bought this header because I wanted a header and like a quality product and this is definitely both. I wasn't expecting huge gains so I'm not disappointed. I think I will miss that little bit of low end torque though...
Galavoxx - Based upon your write up, particulary regarding your comments above, I changed my order with Garm from the DC to the Megan. The Megan header arrived yesterday and looks good to me (thanks Garm!). We'll see if I made the right decision. I did save some coin by switching and perhaps I'll use the difference to buy a higher flowing air filter. I hope to find an hour or two this weekend to do the install. I think I will pick up some of that Permatex Ultra Copper first.
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 08-21-2009, 11:01 PM   #84
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I disconnected the battery for a couple of hours today and went for a heavy footed drive up and down highway 280 and then up and down some hills.
At first it seemed like nothing was different. This is probably because I was skeptical the ECU would change anything given I had already driven the car for 100 miles or so.
Well, I was totally wrong. The low end torque feels like it's back! I did some "tests" up some of the steeper hills in my neighborhood and I can definitely feel more power down low. I don't know the exact extent of the change when compared to the stock header but the throttle response really is better and the engine just feels like it has better pull than before the ECU reset. I can say that disconnecting the ECU definitely helped things and anyone adding a header should probably perform the reset. I'm going to go on an early drive up highway 1 to Tamales Bay tomorrow morning, grab some breakfast and see if it gets even better!! Thank you all for the suggestion.
Old 08-21-2009, 11:03 PM   #85
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Hey Herb (haha)... I'm curious to know if your low end suffers at all. After the ECU reset mine feels like is probably back to where it was at stock. Let us know what you think after you've installed.
Old 08-21-2009, 11:36 PM   #86
Herbicidal
Herbicidal's Avatar
Will do! Enjoy your drive up hwy 1!
Old 08-21-2009, 11:56 PM   #87
lilredrocket
Slowy getting there
Drives: 08 Liftback
Glad to hear that helped
Old 08-22-2009, 06:08 PM   #88
rac23
Drives: 2007 Yaris Hatchback
Galavoxx
Great to hear. I hope it gets even better for you tomorrow.
rac23 is offline   Reply With Quote
Old 08-22-2009, 09:22 PM   #89
fmicle
fmicle's Avatar
whew, good, 'cause I've already ordered mine
Old 08-24-2009, 12:08 PM   #90
Herbicidal
Herbicidal's Avatar
Galavoxx -how was your drive up hwy 1?
I having removal issues with my air/fuel sensor (on the stock manifold), so my car is still up on jack stands while my Toyota mechanic buddy tries to get it un-stuck. He has the old manifold at his house. I think I'll need to post up my experience with the Megan install. It was going fine until the stuck sensor. Oh well, there is always something! Oh yeah, air tools are your friend!
