Old 03-16-2009, 06:41 PM   #73
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by whooppee777 View Post
so if we got the cam com we could adjust the cams to cope with the crazy a/f readings?
No, the cam has nothing to do with it.
Old 03-16-2009, 07:59 PM   #74
kurokoma-kun
Drives: 2007 Yaris HB
Originally Posted by largeorangefont View Post
You can control EGT by adding more coolant (fuel) or turning down the intensity of the flame (ignition retard).
Crap, I have got to get off my a$$ and install my gauges! Without knowing the AFR, seems like knowing the ignition timing means nothing
Currently I just gave a tach and scangauage on volt, ign, tps, and cycle through others (load, loop, temps). I have boost/vac and wideband a/f and oil press. still in their boxes
Cruising around at 2500-3500 rpm, the tps is ~25, load is say 50, ign timing is usually ~30. Under boost (load 99 and tps 25+) it quickly drops to half that... is that normal?
Old 03-16-2009, 08:38 PM   #75
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I cannot fault you for being slow. I started the thread about gauges for boosted applications at the end of October. It's now mid-March and I just got two of my three gauges working (boost/vac & wideband a/f). Oil pressure should be done next weekend...maybe.
As for the scangauge, I normally set it to trip MPG, instant MPG, RPM, & fWt
Old 03-16-2009, 09:09 PM   #76
largeorangefont
Break'em off some.
Yes that sounds correct.
Old 03-16-2009, 09:48 PM   #77
kurokoma-kun
thanks... this whole project has taken me forever though. I'm a terribly slow weekend mechanic and even slower electrician, plus it's taken me a long time to get a mental grip on the basics of boost--had a lot to learn and still do, but experience is the best teacher I guess
thank you for the reassurance
Old 03-16-2009, 10:22 PM   #78
kurokoma-kun
Originally Posted by camelll View Post
These are pretty much the numbers I see as well jo.
Interesting! now I'm very curious to know what Long and others are getting, and how to interpret it all.
Old 03-16-2009, 10:41 PM   #79
LtNoogie
LtNoogie's Avatar
I was seeing ign timing dropping to single digits under boost this evening.
Old 03-17-2009, 02:20 AM   #80
rpalai
Drives: 2008 NEW Yaris 2-door Liftback
I have to agree with the comments posted by most of the members. Slightly larger injectors, or is there any way of possibly increasing fuel pressure to the injectors under boost to a higher level than the controller is allowing? Perhaps an Apexi-II unit or something similar that can work alongside the Blitz fuel controller? This lean condition is a real concern and has to be fixed! If it is happening in your car, it most likely is happening to everyone who has this system installed, like me! This will probably be an interesting and do-able fix, hopefully. Thanks! RPALAI
rpalai is offline   Reply With Quote
Old 03-17-2009, 02:27 AM   #81
would be pretty easy to throw a set of Scion tC injectors (about a hundred bucks on eBay) and see what happens.
Old 03-17-2009, 12:05 PM   #82
largeorangefont
Break'em off some.
Yea, the car is fine then... Don't loose any sleep over it.
Old 03-17-2009, 12:06 PM   #83
largeorangefont
Break'em off some.
That would be the worst thing he could do at this point. If he is seeing single digits for timing under load, he does not want to add more fuel.
Old 03-17-2009, 12:10 PM   #84
largeorangefont
Break'em off some.
I am not seeing a lean condition, my wideband show's between 11 and 12 under wot and stoich at idle. my scangauge readings are on par with korokuma kun's. I was however experiencing pre ignition but that has been stopped with the lucas octane booster and 93 octane in the tank. Noogie however was seeing a lean condition when his car was on the dyno and is showing a condition now but does not have the sensor in the optimal spot.
I am gonna have to mess with the camera and check out its video settings or just break down and by a camcorder.
I could not tell you why the 2 of you are seeing differences. Is your black box hooked up properly? Noogie is stting stoich at idle and during cruise as well, so again, his wideband is close to accurate.
Noogie is seeing low timing, so I am assuming that the black box is offsetting timing under load. What kind of timing values do you see under boost?
Old 03-17-2009, 02:36 PM   #85
kurokoma-kun
Lieutenant, your readings indicate a warp core breach is imminent... you've got to shut down the reactor now, then run a level 3 diagnostic on the matter/antimatter reaction control system
sorry Long, not to make light of your concerns, I've just been wanting to say that to you for some time and now seemed like the right moment
Old 03-17-2009, 02:47 PM   #86
See Long, and you make fun of me when I speak Klingon
Old 03-17-2009, 03:06 PM   #87
LtNoogie
LtNoogie's Avatar
I tried to make a video last night while driving and hand holding the camera. Not recommended. I'll install the camera mount tonight and shoot another video.
Old 03-17-2009, 05:34 PM   #88
largeorangefont
Break'em off some.
I will say though that I have a different fuel controller than most, there are only 3 people that have the same fuel controller I do (that I am aware of). I was one of the first people to get this kit.
Well there you go. That probably explains some of the differences. If all of you were getting knock, they probably made some revisions to future kits.
Old 03-17-2009, 08:42 PM   #89
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I'd like to chime in with my a/f readings, but I don't got a wideband a/f gauge yet. However, it is true that I have not experienced pre-ignition. But, I did put in lucas oil's octane booster with shell's 92 before i got the kit installed and running. I'm not sure if this is preventing the pre-ignition, but I am not experiencing any. I don't know if I don't use the boost octane if I will experience it or not, but I don't plan on not using the boost octane for a long time.
I'm also not experiencing the noise that occurs when the car is in idle and the a/c is on. I don't know if I have a lucky kit, or a newer kit, or what not, but my kit seems to run flawless as of now. We'll see if the story changes once I see my a/f readings.
Old 03-18-2009, 09:32 AM   #90
LtNoogie
LtNoogie's Avatar
The video was too shaky to post.
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
WTB or free front bumper any condition in SOCal Walter Items for Sale by private party 3 09-14-2007 12:56 AM
