Old 08-10-2009, 09:26 PM   #73
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
It won't void warranty unless it IS the cause of the damaged area to your car. But you can always take the bar off before going into dealers to check if something near the rear was damaged....
Seriously, all in all, TRD bar is the same as the UR that Garm sells.....lol
I didnt notice a difference w/ my TRD vs Garm's UR bar...i just wanted ONE TRD part on my car :P
Old 08-11-2009, 12:50 AM   #74
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Same reason why I bought a TRD radiator cap.
Old 08-11-2009, 01:03 AM   #75
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Damn, should've gone w/ that instead, would've cost me less
Old 08-11-2009, 01:03 AM   #76
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
well, i have no damage to the area.
i just dont want to order the TRD suspension stuff, and have kendall jack my car up and see that i have added a component, or modified from factory spec. and void the warranty that would be otherwise kept intact installing TRD components by a toyota dealer.
Inspector14 is offline   Reply With Quote
Old 08-11-2009, 01:11 AM   #77
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Well, most mechanics dont care what you have inside/outside the car....its those stupid service people that get you setup for a check-up that whine like little girls about non Toyota aftermarket parts...
I mean....there is a front sway bar on the Yaris, would a rear sway bar cause so much damage/ void warranty? Nope, not at all....
Usually adding components to engine bay or modifying movable suspension parts voids warranty ie.... aftermarket lowering springs, coilovers, struts/shocks, etc.... a simply 19mm bar? They're b.s you if they say anything, honestly..
Old 08-12-2009, 05:44 PM   #78
DOMAV
Drives: Yaris 09 T-spirit 1.33
how will this effect the ride??
forget how well the road holding is (its hard but try) how will the car drive in normal driving speeds in the city, and over bump roads??
is there a front sway bar too?
DOMAV is offline   Reply With Quote
Old 08-12-2009, 05:49 PM   #79
^ I don't notice any difference in a straight line, only in turns and against crosswinds.
There is a front sway bar available in a 24mm size, made by AOE.
Old 08-12-2009, 07:45 PM   #80
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Our cars already have a front sway bar...its 22mm or 23mm last i read somewhere when they measured it.
My experience SO FAR, driving/owning it for 7 days straight......it doesnt make a difference on bumps, only your tire psi will make a difference w/ that~ Mine are at 42 psi so i feel everything :P
Like cali yaris has said, only differences noticed during turns and big SUVs passing you up on freeway.....
Old 08-12-2009, 08:01 PM   #81
YAR1S
YAR1S's Avatar
Just an update w/ my situation...i got the sway bar today and put it on without removal of tires...barely squeezed it in, hell yes~
All that remains is to torque the two bolts above the shock bolts... :( if its possible
Can't believe how little room is below this car, ughh
Sway bar review will be done by tomorrow :)
EDIT: no band aid needed Garm haha.
And YAR1S, its easy to install, trust me...i'm lame at diy stuff...if i can do it, it'll be piece of cake for you :)
awww thanks... I will try this out soon ... I hope.
-Jen <3
Old 08-13-2009, 03:29 AM   #82
RedRide
RedRide's Avatar
It wiil make the rear suspension seem slightly stiffer at times but in a good way.
IMO without the sway bar, the rear suspension seems much too soft.
With the sway bar, it no longer seems like you are driving a boat.
To me, it simply makes the car more fun to drive.
Old 08-13-2009, 06:20 AM   #83
DOMAV
and what does the upper front strut do?
in event of an accident the rear sway bar can cause more damage IMO cause if you get hit on one on the wheel the other side is effected, Am i right or not?
cheers
Old 08-15-2009, 02:07 PM   #84
RedRide
RedRide's Avatar
cheers
Not really. Since we have a beam axle, both sides of the rear suspension are already conected.
It can be argued that a rear sway bar can possibly prevent some damage as it strengthens the whole rear axle/suspension assembly.
Old 08-16-2009, 03:24 AM   #85
DOMAV
thanks a lot i'm new to yaris i had it only for 2 weeks and i find the handling very good maybe cause its lowered on the tte, still i say my alfaromeo 156 handles better but for what i paid for its very good
Old 08-16-2009, 03:04 PM   #86
2+2
Drives: 09 3Dr Manual
Shrewd, very shrewd. I like your thinking.
2+2 is offline   Reply With Quote
Old 08-17-2009, 09:47 AM   #87
Revsson
Or are they frugal?
Old 08-17-2009, 07:20 PM   #88
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by Revsson View Post
Or are they frugal?
Not really... I just like spending the big bucks where it counts. Spending 300% extra on a part that says "TRD" and that won't even be visible most of the time is not my idea of a good investment.
Sorry for the
Getting back to the UR sway bar, I have been using it for a couple of months now, and I must say it is one of the best handling mods you can make, along with lowering springs.
Old 08-29-2009, 06:03 PM   #89
sternz
Drives: 08 Blazing Blue LB
Thanks cali yaris, just installed my 23mm sway bar.
sternz is offline   Reply With Quote
Old 08-29-2009, 08:40 PM   #90
omendt
omendt's Avatar
Drives: 2008 Yaris Liftback
Thanks garm, just installed my 19mm sway bar and it makes a HUGE difference. I can't believe what a difference this makes! 19mm is just perfect for my driving style, and you cant' beat the price.
Thanks to everyone that left their opinions and recommended this upgrade!
omendt is offline   Reply With Quote
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
