#1 | |
Been a long time messing with cars.. |
#2 | |
now in HD
either that or we're both really confused for no reason- just confused due to the nature of your build. i mean, it is awd, therefore awd dyno would work? or is it not that simple due to the setup? or am i thinking in a loop?
#3 | |
but dynoing the engines separately works as well (remember the SCC twin engine'd tiburon of years past)
#4 |
Beast
hmm wait a second... does the 1st gen have more space than us?? or can we easily fit a black top in our car?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#5 |
![]() Drives: Silver 07 LB Join Date: Jan 2007
what about a functional roof scoop with a radiator for the rear engine
#6 |
37HSSV
There should be plenty of room in the back of the Yaris, more room than the engine bay, plus you dont have to worry about steering or much...biggest issue is making a RWD setup for the rear wheels, but it should be easier than making the car a Front engine, RWD...
Notice all what I can say is Should...I mean I cant say for sure because no one really have invested heavily in doing this in a NEW Yaris... We can only say this for sure, if you got a bank account with lots of money in it, you can make it happen! One day I can only dream of having my WRX motor shoved in the back of my Yaris
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
#7 | |
2GRFE ?
#8 |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
Project Update...
Been ages since ive been active on the forum. Life is keeping me busy which is a good thing! Keeps me out of trouble. With another 2 projects on the go its hard for me to focus time and money on the echo but i do have some photos and insight on what to expect from it. First off id like to thank everyone for the positive comments and the numerous emails i have receieved pretaining to my twin engine setup. I am hoping the next few pics and straighten out some of the questions. The echo has been running well :) But its currently down right now as we are fixing some issues i have with it. The clutch is the number one issue. It is hard to press even though its hydro. It feels like i am pressing down 75lbs on the leg press with one leg... The solution is to change the pressure plates to make it alittle more managable and streetable while sacrificing a bit of performance. In order to run both clutches the stock clutch cylinder was removed and replaced with a master brake cylinder. The exhaust is another issue.... Its HUGE and in the middle of the bumper. It wasnt a big deal before with the stock bumper but i now have a jdm rear bumper to install and it has a factory molded lip with an exhaust cut out from the bottom right. So the exhaust will have to be changed. The charging system has to be modified. Currently i cannot run just the rear motor since the front is only charging the single battery we are using... but thats no big deal. The shifter assembly has to be replaced... the stock plastic shifter housing just wont take the abuse. A custom piece will be made out of aluminum in its place. The turbo manifolds, downpipe, brackets and other steel bits have been rusting over the last year. The good news is i picked up a massive compressor, eastwood dual voltage powder coating gun, sand blasting cabinet and a few different colored powders :) but thats last on the list of things to do. The front engine still needs to have an Air to Water intercooler setup but thats not a priority right now...A rear strut bar has to be fabricated to trianglulate the shocktowers to the chasis. Aside from the JDM front and rear bumpers, the jdm led tails, trd wing, and carbonfiber hood the outside is basically complete minus the factory or trd sideskirts. As far as rims and tires go i picked up some goodies :) I got some lightweight 16 inch rota sub zeros and some falken azenia rubber to start off with. Until i burn them down testing and get some good r-compounds. Now the question is do i even bother to drive it for a couple of months in summer or should i just order some new parts and drop the compression and out some bigger turbos on the car... I am leaning more towards the later option. Ultimately i want to see 1002whp out of the car. Its not an easy task either... Here is a list of current performance modifications: 4age 20v engines (currently stock 11.1:1 compression) 6 speed transmissions 1.5way TRD LSDs Custom Spec stage 3+ clutches Megasquirt(s) GT28 Turbos Currently 503hp Even though a huge amount of work has been done and the car was running there is still a huge amount of work to be completed... Enjoy the attached photos :)
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress Last edited by turboecho2005; 04-05-2010 at 08:08 AM. |
#9 |
Well today the car was at the ICARS (http://www.circuiticar.com) speedway in montreal. It was there for a photo shoot and filming. It will be featured on some video. When i know more details i'll let you guys know. I cant speak a word of french so i wasn't sure the exact details but it was a fairly high budget setup. Helicopter and multipoint camera shots. There were some amazing cars there also including a 600hp supercharged NSX.
Here are some photos. The echo ran great. The pro driver who took it out said the car was unbelievable to drive. We did have a mishap in the afternoon. Ive been running stock struts and springs in the rear... on a hard corner the spring lifted off the strut seat and shredded the tire. I guess its about time i bite the bullet and go buy some coilovers. Here are some photos. I'll get the video once its done in september. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
#10 |
looks like a great time out there, but c'mon...MORE PICS (don't make me beg, it's really not pretty)
#11 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
#12 |
I'll get some photos when i recieve them... the photos i took were with my camera phone. Although i do have some small 10 second video. i'll try to upload it.
EDIT... uploaded them... they aren't the best but you get the idea. i was filming this with my phone lol. http://s781.photobucket.com/albums/y...t=MOV_0349.mp4 http://s781.photobucket.com/albums/y...t=MOV_0343.mp4
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress Last edited by turboecho2005; 07-06-2010 at 07:55 PM. |
#13 |
http://www.ztele.com/emissions/equipe-pour-rouler/205499759-cathy-gauthier-et-la-porsche-panamera/
8 minute mark you can see the echo :) Wish i could spreak french so i could understand it. Going to get the echo ready for some winter driving EDIT.... USE THIS LINK: http://www.ztele.com/webtele/cathy-gauthier-et-la-porsche-panamera-12949/ Its a bit easier then the top one..
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress Last edited by turboecho2005; 10-26-2010 at 11:10 PM. |
#14 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
![]() Quote:
Why didn't you shared this link to us? http://www.turbinetech.ca/projet_det...759445779b65b6 |
#15 | |
The detected pay code is not valid for this video AKA Video isnt' working =( |
#16 |
Sweeeeeet!!
HAHA, I'm glad I was chatting with you the other day. From the video, they talked about, "why put 2 motors in an Echo?" Answer, "why not".... blah blah blah, then take for a test ride. LOL |
#17 |
NICE, unless you speak French, jump to 2:11
#18 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Most of the pictures are broke now :(
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
| New audio + Today's DIY project | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 23 | 03-03-2009 11:37 AM |
| New Project AE86...! | CASTREX | Photo-Video-Media Gallery | 29 | 02-01-2009 03:09 AM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
| Project Yaris. | RodimusPrime | General Yaris / Vitz Discussion | 8 | 07-02-2007 12:19 AM |
| My Stage 2,3,4 tuning list | Hyde | General Yaris / Vitz Discussion | 17 | 08-06-2006 05:32 AM |
