#73 | |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
#74 |
![]() Drives: 08 Yaris Sedan Join Date: May 2009
There is no local Toyota dealer here. The closest one is over 130 miles away.
Will 85 octane damage the engine? |
#75 |
I love momentum.
87 octane is the lowest recommended isn't it? I wouldn't go lower than that, esp. at higher altitudes.
#76 | |
![]() ![]() Drives: '09 Meteorite Metallic 3 dr MT Join Date: Jan 2009
I always run 87 and almost always get 90+ miles from the first bar w/o topping off. |
#77 |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
No. 85 octane is used in locations with high altitudes because it behaves like 87 does at lower altitudes/sea level. I live in Colorado and regular is 85, mid is 87 and premium is 91.
So.....to clarify a bit, high altitude 85 octane= the 87 octane that all the low-landers use, so using mid-grade 87 is not necessary. |
#78 |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
As the altitude goes up, the requirement for high octane goes down.
#79 |
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
With the cost of gas going up so quickly, yesterday, May 29th it was 2.60 for 87 and 3.00 for highest oct., I would stick to the recommended gas at the lower price.
#80 |
when i first got mine i ran preimum once and the car ran like shittocky mushrooms and when i went to fill up i put regular back in it and it ran better so i just been running reg had no probs here but im moving back to pa has ne one had any probs woth thier CAI in the snow pm me and let me know
#81 |
OK thanks for the info
#82 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
How far you go on the first bar depends heavily on how full you fill the tank. I run the pump fast till it clicks off, wait a few seconds, start it back at a trickle and let it click off again. (It barely puts in a dollop of gas the second time, but it makes for a pretty consistent fill without overfilling.) I usually get close to 100 miles on the first bar.
#83 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
We've never put in anything other than 87 octane. We purchased the Yaris to reduce travel expenses and given it's performance over the first 79 fill ups 87 octane suits it quite well.
We do only fill at top tier stations though. |
#84 |
![]() ![]() Drives: 2010 Yaris 5-Door LB AT MM Join Date: Jun 2010
91 octane will make your penis larger. yeah i've also read anything above 87 is harmful for your engine. Makes sense, these cars have sensitive timings. But i can't imagine with how many computer chips they put into these cars nowadays, that the ECU would detect the 91 octane that some idiot put in their car and adjusted the timings of fuel injection so it doesn't cause engine knock/build-up.
#85 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
HOLY THREAD REVIVAL.
#86 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Compression dictates octane
#87 |
Drives: 07 sedan Join Date: Mar 2010
#88 | |
![]() Drives: 2010 3D LB 5spd Join Date: Mar 2011
I just spent 35 minutes reading this pissing contest so I absolutely HAVE to make some kind of comment to revive it. You ready....? Here it is.........comment.Quote:
#89 |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
Speaking of diesel: I was at a gas station in SE Idaho the other day, fueling up my 22 ton boom truck. I was astonded to see they were offering straight diesel ($3.86 per gallon), off road/non dyed (and you do NOT want to get caught with that in your tank) for $3.64, and lastly bio diesel for $3.86. The owner of the station must be a diesel freak! As everywhere else was elling diesel for $3.97 or higher, I was a happy camper.
A few days earlier, while also fueling the boom truck, I struck up a conversation with a VW Jetta driver: 47 to 49 MPG, and he had over, well over, 200,000 miles on it. Without even doing the math (in general higher priced diesel V. gasoline) the Yaris compares well...( in the low 40's, my own results) plus I trust Toyota more then VW! |
#90 | |
), went back to Carmax and bought mine for $5k off of sticker with 12k miles on it. |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
