Old 06-26-2010, 05:35 AM   #1
ddongbap
But Hilton puts out a good point. The Syncros are going to try to sync while the clutch is connected to the engine. It will try to spin, but it can't spin the engine. That's a sure recipe for some DIZZ ASS STAAA
Old 06-26-2010, 05:37 AM   #2
ddongbap
ok guys last 9 posts, not really on topic so i'll soft delete them ok. now kiss and make up, oh and not really nice to be critiquing someone's language skills if their native tongue is not English.
Soo.. was I making fun of the guy's langauge?
Old 06-26-2010, 11:11 AM   #3
Billiam
Drives: '10 White Yaris 4D LB
Wow...is this an oil thread?
Old 06-30-2010, 03:21 PM   #4
ddongbap
you were criticizing his "mistakes".
I said something along the lines of
LOL U SAID POOF BUT I ASSUMED YOU SAID PROOF ANYWAYS. He made TONS more mistakes than that. I just went along with what I thought he meant he said. But the POOF one cracked me up cause I missed it. Wheres the insults?
Old 07-12-2010, 08:56 PM   #5
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Just shift with the clutch....it's there why?.duh.
frog13 is offline   Reply With Quote
Old 06-26-2010, 07:24 AM   #6
mark293
Drives: 2007 THREE DOOR 5 SPEED
Wow, never thought this post would go this long. I gave up a long time ago and just decided to peek my head in here. Yall be safe.
mark293 is offline   Reply With Quote
Old 06-22-2010, 04:24 PM   #7
ddongbap
Anyone else know why clutchless shifting is bad for syncros?
Last edited by PK198105; 06-22-2010 at 06:14 PM. Reason: non relevant parts deleted
Old 06-23-2010, 12:31 AM   #8
SAV912
Pirate Yaaaaris
SAV912's Avatar
It was just explained to you above. Synchromesh is there to help ease the transition between gear changes. The gears in the half of the transmission that can freely rotate are the ones that come into factor when you rev match and the shift lever freely slides into place. Those gears of the transmission can be freely rotating, or locked to the shaft. The synchros ensure that the speeds of the two shafts/gears are matched perfectly before letting the gears engage.
When you rev match, you are doing the work of the synchros by yourself but still putting excess force on the synchros, but if you mis-rev even slightly and still attempt to shove the shifter into gear and get an awful grinding noise, you are putting wear on not only the synchros, but the gears themselves as well. Sooner or later, you'll start wearing teeth off the gear itself, and eventually, whether or not you rev match perfectly, you will grenade that gear in the transmission. And other gears in the transmission don't like it when there is bits of broken gear roaming freely.
By all means, if you think you can rev match perfectly each and EVERY single time, go nuts. It's not my synchros you're eventually going to destroy. It's yours. So if giving your left leg an exercise during a drive is not worth it to you, then best of luck footing that new transmission bill. You probably should've invested the extra money in an automatic Yaris anyway, if that's the case.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-23-2010, 01:05 AM   #9
ddongbap
-SAV
Ok, so say I'm at 60 mph. I know that third gear falls around 4kish rpm. If I revved to 5, and pushed the gear into third and waited for the revs to drop till 4. Then thrid gear would take it. Is that still bad?
I understand how that'll be bad for the gears it self, but wouldn't that take the work off of the syncros?
Btw, idk what the other guys problem was. I just wanted an answer like this.
Old 06-23-2010, 03:21 AM   #10
SAV912
Pirate Yaaaaris
SAV912's Avatar
If you rev'd to 5K and tried shoving it into gear (because it wouldn't just slot right in), it wouldn't go in unless you forced it. If you succeed in forcing it, that's where the wear on your synchros and gear grinding comes in. Hence why the people above mentioned why you have to be absolutely spot on with your rev-matching.
Now if you know that 60 mph is about 4K in 3rd gear (I wouldn't know for sure, my Yaris doesn't have a tach) and held the car at exactly this engine speed in neutral with the gas pedal, then yes. The gear lever should slot right into 3rd gear with no problem. This action of being correct is not really a problem. It's much easier to upshift without the clutch than it is to downshift. It's the fact that every single human being will eventually blip the throttle wrong, mis-shift and force it in, causing excess wear on the synchros since the gear speed and output shaft speed are not correctly matched. Forcing it all the way in will just get gears grinding, just as what happens when missing a shift like we all did once upon a time when we were noob stickshift drivers.
Bottom line, you can try it and you can even become good at it. But that doesn't change the fact that our cars come with clutch pedals for a reason.
-SAV
Georgia Bulldogs!
Old 06-23-2010, 03:52 AM   #11
ddongbap
-SAV
Well, some cars come with other crap nobody ever use sometimes.
Sorry of my questions seem like I'm trying to prove you wrong. I'm just trying to figure it out.
Btw, the gear accepts the shifter because its the right RPM range. Theres no grinding as it goes it. It just goes POP and takes it in. And only at the right RPM range, consistently.
Now, you may be right, but I think its kinda hard to mis shift w/o the clutch, seeing as the gates won't open if you're at the wrong speed range.
Anyways, long story short. Syncros are used to match difference in speeds on the clutch and the different gears. But if you go clutch-less, and use the engine to act as syncros, how would that put wear on the syncros?
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
