Old 12-12-2010, 04:06 PM   #1
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
The injectors could quite well be getting max'd out cause the fuel pressure system has no reference to manifold pressure in a stock (return-less) fuel system. If you can raise the fuel pressure as boost increases, it would give you substantial headroom in that side of things. The other problem is that the injectors may not be spraying optimally when having to fight against the boost pressure in the manifold.
rob323 is offline   Reply With Quote
Old 12-12-2010, 05:08 PM   #2
I just thought of another problem you guys might be having with tunning... the stock fuel pump is a 2 speed unit. I forget exactly how it operates, but it goes something like, "low speed at idle and cruse" and "high speed under acceleration".
If someone has a repair manual, they should be able to confirm this. Because this could be causing the fuel pressure to jump around
Old 12-12-2010, 08:24 PM   #3
Has anyone else had trouble with fuel pressure or the pump at low boost? Seems like everyone would, or no one would.
Old 12-12-2010, 10:06 PM   #4
rob323
But has anyone with a stock system monitored the fuel pressure while under boost? no point having 40 psi of fuel pressure at idle if the injectors are just dribbling fuel out when under boost even when at 100% duty cycle.
I don't know over there, but the one Aussie Yaris pump I have pulled out was about the same size as a D cell battery. The pump in the Echo is almost twice the size in comparison.
Old 12-13-2010, 10:09 AM   #5
I had 100% stock fuel system at 8 psi. With larger injectors.
I still don't understand why only one person would experience the problem, nor did you explain that point, since you say injectors can't be his problem.
Your experience is helpful -- Just quoting a pressure number doesn't help me understand.
Like Rob said before me, not one person here is monitoring fuel pressure.
I am now, but I don't think that's what you guys meant.
Old 12-13-2010, 02:50 PM   #6
It's not that difficult to upgrade to a Walbro 255. Can you do that without a return line?
The stock fuel pump is the size of a "D" cell battery, LOL. I posted a pic somewhere of it!
Old 12-14-2010, 10:26 PM   #7
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
greddy emanage ultimate. Still trying to talk to the tuner about all of this...
Old 12-15-2010, 12:09 AM   #8
PETERPOOP
PETERPOOP's Avatar
Ok. Well I talked vaguely to the tuner via email and he suggested the walbro 255. however, i don't know if he is putting much thought into it or not whether i need to run a return fuel line or not. i mentioned it to him, but he didn't address it via email.
Question. Would the tuner be able to successfully tune with the walbro 255/larger injectors in place, and no return system?
Wondering if i should just try the larger injectors first, and see if that fixes the problem. Then if not, get a larger fuel pump and go from there.
I'll be going with the spec stage 2+ clutch and flywheel; also a Kaaz LSD.
Old 12-15-2010, 01:38 AM   #9
injectors go on in minutes, you'll know if you're on the right track. Installing and running a fuel pump and especially a return line is a pain in the butt.
Old 12-15-2010, 12:14 PM   #10
Another option is to lower the boost which will in turn require less fuel demand.
How dare you give him these silly ideas? That is not an option!
Old 02-08-2011, 10:21 PM   #11
PETERPOOP
PETERPOOP's Avatar
Just put in a Spec stage 2+ clutch, Spec lightened flywheel, and Kaaz LSD. Feels gooooood.
ps: Sorry tamango.
Old 12-13-2010, 01:50 PM   #12
Focus_Sh1ft
Focus_Sh1ft's Avatar
I really think it's the fuel pump as well, but I can't offer any explanation as to why. Wouldn't all the blitz people experience similar problems?
The injectors maxing out just doesn't make sense though. 1ZZ should easily cover 8 psi of boost...
What's the life expectancy on a fuel pump? Maybe Peter's is on its last legs?
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
